WHAT SIZE CARB - Mustang Evolution
Old 05-30-2006, 08:15 PM   #1
WHAT SIZE CARB
I was wondering if someone could help me I have a 91 stang that was fuel injection and now is carb it has a 331 stroker right now it has a holley 750 and its way to much for the engine any suggestions on what size would be good I would appreciate it
andrew mangrum is offline   Reply With Quote
Old 05-30-2006, 08:51 PM   #2
12Pack's Avatar
Re: WHAT SIZE CARB
650
http://img442.imageshack.us/img442/7193/1231cs.jpg
87 Ford Mustang GT 306
Car Domain
12Pack is offline   Reply With Quote
Old 05-31-2006, 09:14 AM   #3
RGR
Send a message via AIM to RGR
Re: WHAT SIZE CARB
Originally Posted by 12Pack
650
Demon 650 would be perfect for it probably.
Demon carbs seem to have better low end than a Holley.
If you want cheap then try a Holley 600 Vacuum Secondary, or a
Holley 650 Double Pumper. Or just get the jetting kits for your 750
and make it work. If it is a vacuum secondary you can make it respond
fairly well on even a 5.0 sized engine. It's all in the tune. Somewhere
out there you can find a jetting chart (starting point) for your setup,
and that will be darn close and it will run good. Good Luck Andrew!
PS: A generic Holley 600 (4160 I think) would probably be really good
since most of them are setup for a mild 350 ch*vy which is about right
for a good 331 stroker. A 4160 for the Ford 5.0 would be a good economy
carb for your 331, getting better mileage but still make good power.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 06-20-2006, 09:24 AM   #4
SilentNoise's Avatar
Send a message via MSN to SilentNoise
Re: WHAT SIZE CARB
On a 331 I wouldn't go as low as a 600 because you may risk running a little lean in the higher RPMs. With a 650 you'd be safe and have a little extra for a comfort zone.
Here's the calculation used to figure out carb sizing: CI x RPM x VE / 3456 = CFM
When it comes to volumetric efficiency, a .9 VE number represents a pretty good combination (usually a good number to use on a stock motor) and a 1.1 VE number pretty much represents an all out assault on the engine block's stress handling capabilities.
I'm not sure what your red line is at, but I'm just going to guess something like 6500 for the hell of it, and I'll go with a 1.0 VE since it is a stroker and puts more pressure on the block, but isn't a monster:
331 x 6500 x 1 / 3456 = 622cfm............ so a 650 would be good.
Wolf Pack Car Club - Domestic V8 Performance Club (Edmonton, AB, Canada)
"If the automobile had followed the same development cycle as the computer, a Rolls-Royce would today cost $100, get a million miles per gallon, and explode once a year, killing everyone inside." -Robert X. Cringely
SilentNoise is offline   Reply With Quote
Old 06-20-2006, 09:59 AM   #5
RGR
Re: WHAT SIZE CARB
Originally Posted by SilentNoise
On a 331 I wouldn't go as low as a 600 because you may risk running a little lean in the higher RPMs. With a 650 you'd be safe and have a little extra for a comfort zone...
...331 x 6500 x 1 / 3456 = 622cfm............ so a 650 would be good.
A 600 will not lean it out at high RPM, any off-the-shelfer will be rich, guaranteed.
All the 600 could do is generate a slightly higher vacuum @ WOT meaning it's
just a tiny bit small. 600 for economy and good power, 650 for max WOT power.
The 650 also has better designed boosters, making better HP. But it's about twice the money as a generic 600 Holley too.
What size Carb saleenman 1979-1995 Mustang GT 4 10-11-2009 12:45 PM
Wheel size & tire size help needed for newbie rayramos Mustang Wheels & Tires 14 09-21-2009 11:45 AM
carb size prive 1979-1995 Mustang GT 5 12-29-2008 07:22 PM
86 5.0 e.f.i. to carb need help ttyree1983 1979-1995 Mustang GT 1 05-25-2008 03:20 PM
carb help nmarlow Classic Mustangs 0 11-22-2006 07:01 PM
09:40 AM
