will it fit? - Mustang Evolution
Old 06-02-2006, 03:06 AM   #1
powerhungry966's Avatar
Send a message via AIM to powerhungry966
will it fit?
i was wondering (since im pretty much new to this 5.0 thing) if a cobra intake manifold would fit? also would a gt front bumper from 89-93 fit a lx coupe? my front bumper needs replacing, and i found a guy who will sell it to me.. would those two fit?
1989 coupe 5.0 yeessur.
"Shake n bake"
powerhungry966 is offline   Reply With Quote
Old 06-02-2006, 07:02 AM   #2
bbunt302's Avatar
Re: will it fit?
The intake will. I believe the bumper will also "fit" but will look incredibly stupid for a number of reasons, the main one being that the moldings on the GTs and LXs are actually different sizes. So, the size of the "molding" on the front bumper will no longer match the size of the ones going down the side of the car.
Besides, LX coupes are too clean of a car to need body mods. Maybe a small cowl hood, but that's it. I've seen coupes with the full GT body kit, and they just do not look right.
Scary stuff.
Old 06-02-2006, 09:04 AM   #3
RGR
Send a message via AIM to RGR
Re: will it fit?
The cobra intakes fit any 5.0, 94-95 needs the elbow adapter or a custom
air inlet tubing made for it. If you are saying you want to put a 89-93 front
bumper on your sig pic car then forget it, it looks stupid even if done "properly".
Keep the 79-93 parts on 79-93 cars only
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 06-02-2006, 04:27 PM   #4
Zim
You want to **** me?
Zim's Avatar
Re: will it fit?
The cobra intakes fit, but you have to use both the upper and lower intake. For example, just a cobra upper intake wont fit on the GT lower. Its an all or nothing deal. They will bolt up to the GT heads though.
I like toys
Old 06-03-2006, 05:43 AM   #5
Re: will it fit?
so what is the main difference between the cobra's motor and the regular 5.0 aside from the amount of BHP its pushing out? or it is a 5.8? iknow the 95 are the 5.8's (cobra R)..
yeah i agree those gt bumpers would look dumb on the coupe.. what the hell was i thinking! maybe its because i havent slept in a while eversince i got the 5.0.. i just want to do everything to it.. haha i just replaced the accuators for it..smogged it and registered it.. might i add that the car passed with flying colors..better then my original car..
"Shake n bake"
Old 06-03-2006, 07:25 AM   #6
RGR
Re: will it fit?
5.0 Cobra engine differences:
GT40 Heads (1.84/1.54 valves, better exhaust port design).
GT40 cast aluminum intakes (Cobra) Staggered round port.
Different Cam, still a wimpy FMS-style grind with waaay slow ramps
That's the major stuff, it also had a slightly higher CR like 9.5:1 I think.
Old 06-03-2006, 08:33 AM   #7
bbunt302's Avatar
Re: will it fit?
The Cobra also had 24# injectors a different mass air, a different ECU, and a 65mm throttle body. They still had the same CR of 9.0:1.
Also, the intake on them wasn't actually a "GT40 intake". They came with the "Cobra intake". The GT40 intake was released a couple of years later and has the tubular runners.
Scary stuff.
Old 06-03-2006, 10:04 AM   #8
RGR
Re: will it fit?
Originally Posted by bbunt302
1. The Cobra also had 24# injectors a different mass air, a different ECU, and a 65mm throttle body. They still had the same CR of 9.0:1.
2. Also, the intake on them wasn't actually a "GT40 intake". They came with the "Cobra intake". The GT40 intake was released a couple of years later and has the tubular runners.
1. Yep, those are the support pieces for the HP parts I listed. Thx BBunt
2.
"GT40 cast aluminum intakes" (Cobra) Staggered round port.
GT40 pre-dated the cast Cobra intakes, the Cobra version was a low-buck type
for the mass-produced cars. I shoulda put it in quotes like I did after quoting it
cuz you are right, there was not a "cast GT40"
Old 06-03-2006, 11:15 AM   #9
bbunt302's Avatar
Re: will it fit?
Originally Posted by RGR
GT40 pre-dated the cast Cobra intakes, the Cobra version was a low-buck type for the mass-produced cars. I shoulda put it in quotes like I did after quoting it cuz you are right, there was not a "cast GT40"
Do you happen to know when the tubular GT40 intake came out and what it was used for? I tried searching for it on Google and couldn't find anything. I'm just interested to see what they originally intended it for.
Scary stuff.
Old 06-03-2006, 03:21 PM   #10
RGR
Re: will it fit?
I'm thinking maybe 1989 or very early 90's, in fact, the ?SCCA? White/Blue
collector car had it from the customizer... I'm thinking that was a 25th
anniversary model??? It was not a Ford built car, more like a tuner car.
It was highly sought after, about the only game in town was Ford and Saleen.
Rich Kopek, I think, got #001... It was a car in honor of Carroll Shelby.
I'll google some things, and get back to ya!
Old 06-03-2006, 03:37 PM   #11
RGR
Re: will it fit?
Can't really find anything, but it was a 295 BHP 5.0 engine.
It WAS the SAAC Shelby American Auto Club, and it's
spelled Kopec, he was president at the time this special
"Shelby" tuner car was built, by the club, not the MAN. But
it was a very sweet version and CS put his stamp of approval
on it as I rremember. Later, CS and Ford got back together.
Try SAAC and 1989 or 1990 Shelby Mustang...
Old 06-03-2006, 03:49 PM   #12
RGR
Re: will it fit?
SUCCESSSSSS!!!!!
SUPERCARS.NET - 1992 SAAC MK II
There it is, a 1992, stupid me!
Old 06-03-2006, 03:52 PM   #13
RGR
Re: will it fit?
In Detail:
price $41995
valvetrain OHV, 2 Valves per Cyl
fuel feed Ford EFI Fuel Injection
bore 101.6 mm / 4.00 in
stroke 76.2 mm / 3.00 in
compression 9.2:1
power 220.0 kw / 295 bhp @ 5500 rpm
bhp/weight 203.59 bhp per weight
torque 442.0 nm / 326 ft lbs @ 4200 rpm
drive wheels RWD w/8.8 Traction-Lok Differential
front brakes Discs
f brake size 279 mm / 11 in
rear brakes Discs
r brake size 279 mm / 11 in
front tire size 245/45ZR17
rear tire size 245/45ZR17
steering Rack & Pinion w/Power Assist
weight 1449 kg / 3195 lbs
wheelbase 2553 mm / 100.5 in
transmission Mustang 5-Speed
gear ratios 3.35:1, 1.99:1, 1.33:1, 1.00:1, 0.68:1
final drive 3.27:1
0 - 60 mph 5.2 seconds
0 - 100 mph 12.9 seconds
0 - 1/4 mile 13.6 seconds
Supercar Spotlight!
Old 06-03-2006, 04:19 PM   #14
bbunt302's Avatar
Re: will it fit?
Ah... I remember reading about those cars now. It's been a long time though.
Scary stuff.
Old 06-03-2006, 05:25 PM   #15
Zim
Zim's Avatar
Re: will it fit?
I never heard of that car, thanks for the info robert.
Also, the Cobra came with 1.7 rockers and 3.08 gears in all of them
I like toys
Old 06-03-2006, 07:06 PM   #16
MonteCitan's Avatar
Re: will it fit?
25th anniversary model was stock with an emblem on the dash.. nothing else.. I have GT40s.. and I'm putting down 373 HP to the wheels.. port matched, nothing else... on a rather mild 331 build..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 06-03-2006, 08:36 PM   #17
Zim
Zim's Avatar
Re: will it fit?
for gt40 heads
I like toys
Old 06-03-2006, 09:03 PM   #18
Re: will it fit?
i bet that car is worth a **** load..does anyone know the specs of an LX ? is it one legged? and what kind of rear end does it have?
"Shake n bake"
Old 06-05-2006, 01:58 PM   #19
Bane-'s Avatar
Re: will it fit?
all the v8s are 2 legged..they just have ****ty gears. 2.73 is the majority and 3.08 was a option with AOD cars I believe. might be another ratio but can never find any. So whatever it is, unless the owner put in different gears, count on 2.73s.
Old 06-05-2006, 05:57 PM   #20
RGR
Re: will it fit?
The SAAC MKII cars were 3.27 gears. The 94-95 5.0 Stangs (auto) were also.
Old 06-05-2006, 06:22 PM   #21
bbunt302's Avatar
Re: will it fit?
Some of the other fox 5.0s were also 3.27, although they seem to be quite rare. I've read that they were only optional for automatics. However, I've also seen people swear up and down that their 5 speeds (not special editions like the SAAC's) had them from the factory.
Scary stuff.
Old 06-06-2006, 06:52 AM   #22
RGR
Re: will it fit?
Yes, but officially only the later auto's had a 3.27 gear. I believe that some
3.27 5 speeds made it out of captivity, but that would likely be factory fuggups.
Or assembly line workers doing it just for fun
Old 06-10-2006, 08:36 AM   #23
silverstangboy's Avatar
Re: will it fit?
hehehe, that sounds like something i'd do.... "hey lets make this one faster "
93 mustang notch
~450hp 331 stroker - Sold
Old 06-10-2006, 11:01 AM   #24
RGR
Re: will it fit?
my kinda thinking!
Will it fit? Foxone General Mustang Discussion 3 12-05-2008 11:29 AM
Will those fit? warpspeed1414 Mustang Audio & Video 1 07-21-2006 10:48 PM
Would they fit? Js281GT Mustang Wheels & Tires 19 03-14-2005 05:02 PM
Will it fit? juice300x3 Mustang Audio & Video 1 08-26-2004 08:09 PM
would this fit the 02 v6 STEVE Pre-2005 V6 Mustang 26 07-19-2004 01:15 PM
11:05 PM
