first mod? - Mustang Evolution
Old 06-09-2006, 04:25 AM   #1
powerhungry966's Avatar
Send a message via AIM to powerhungry966
first mod?
i have a cai with turn down exhausts.. i sure they're stock.. what should be my first mod 5 liter brothers/sensay's
1989 coupe 5.0 yeessur.
"Shake n bake"
powerhungry966 is offline   Reply With Quote
Old 06-09-2006, 05:48 AM   #2
bbunt302's Avatar
Re: first mod?
Put some tailpipes back on it...
Seriously though, the stainless pipe are a big part of what make the 5.0 LXs look so badass.
After that, I'd say gears: 3.73s for a 5 speed and 4.10s for an auto.
Scary stuff.
Old 06-09-2006, 07:51 AM   #3
Re: first mod?
a notch back with out a nice polished stainless set of tail pipes is hardly a notch at all.
Old 06-09-2006, 09:32 AM   #4
Bane-'s Avatar
Re: first mod?
Id go the usual bolton route, UDP, exhaust,gears, etc. Also could up your timing, take off the smog/ac/ps if ya want.
Old 06-09-2006, 09:35 AM   #5
RGR
Send a message via AIM to RGR
Re: first mod?
Previously owned a 25th anniversary GT...
1. Gears.
2. UDP (nice gains for me!)
After that, you gotta spend some $. Most simple boltons will
"nickle & dime you to death" for minor gains. Lay out some ideas
and I'll try and help you avoid the wasted steps and do it right.
Spec is right, tails look nice but in your setup would cost a couple HP possibly.
I'd get a complete exhaust at some point, but for now your good, depending
on how far you want to take it...
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 06-09-2006, 05:18 PM   #6
Re: first mod?
i want to take it pretty damn far.. but just enough to where i can go up to a lot of cars and spank them, including corvettes.. hehe.. but tail pipes i agree.. i hear motive has 390 gears? wouldnt that be a better gear choice since i have an auto, i mean i want to be able to cruise on the freeway, specially where i'm from its mainly freeways..or should i free up the exhaust?
"Shake n bake"
Old 06-10-2006, 05:39 AM   #7
Tbird232ci's Avatar
Re: first mod?
Headers back exhaust would be my first mod on any 5.0 car.
A set of gears, which i hear 3.90's work well for an auto, but you cant trust my word on that, i want to put 5-speeds in everything i own.
Put an electric fan on it. Pulleys. Advance your timing. Then, save up for real mods.
Old 06-10-2006, 08:44 AM   #8
silverstangboy's Avatar
Re: first mod?
390 is an excellent choice for gears if your not quite wanting the steepness that comes with 410's... you probably wouldn't want 3.73's on an auto. my father has been running 390's on his hot rods every since I can remember, he started running those back in the day because you wouldn't have an overdrive tranny in a hot rod (68 fastback, mustang 2's, 70 boss) and turning 4.5-5.5K at 65 miles an hour down the interstate gets old quick... at least this way he was able to keep it around 3-3.5
93 mustang notch
~450hp 331 stroker - Sold
Old 06-10-2006, 09:37 AM   #9
Bane-'s Avatar
Re: first mod?
the damn 3.90s are just damn expensive, Ive only seen motive making them. Id just run a 4.10 with a 28" tire = 3.90 rear basically. then goto the track with 26" tires and you have all of your gearing back.
Old 06-10-2006, 11:06 AM   #10
RGR
Re: first mod?
FYI:
I actually saw an old mag article where they used 3.55's and a shift kit
and had better track times with street tires than 3.73's and shift kit.
Less tire spin. BTW, it will only get worse with more power in most cases.
The key here is "street tires". If you get DR's or slicks, then you can handle more gearing.
Next Mod ? 05RedDevil 2005-2010 Mustang GT 10 06-05-2008 01:29 PM
i need some help on how to mod a v6 tim11 Pre-2005 V6 Mustang 28 11-12-2005 08:24 AM
Best first mod... wiarumas 1996-2004 Mustang GT 11 04-28-2005 12:31 PM
What should my next Mod be? tippie2000 Pre-2005 V6 Mustang 24 04-07-2004 03:49 PM
next mod: Rellik The Bar 11 10-18-2003 08:03 AM
08:02 PM
