BBk Headers, and Throttle body... - Mustang Evolution
Old 06-21-2006, 06:30 PM   #1
Fast93Coupe's Avatar
How many horses would I free up with BBK shorty headers and a 70mm Throttle body w/spacer. My 93 5.0 is stock except for BBk cold air, Mac H Pipe, and 2 chamber Flows. What would my estimated Hp be?
---1993 Ford Mustang Lx Coupe-performane bolt ons, BBK Cold air intake, B&M Ripper shifter, King cobra clutch kit, Steeda adjustable clutch kit, basically stock...
*1994 Ford escort Lx- working on it
*1991 Mercury Grand Marquis- Dead...
*1995 Ford escort Lx- Parts car
----Cant find 'em, Grind 'em
Fast93Coupe is offline   Reply With Quote
Old 06-21-2006, 07:08 PM   #2
12second5.0's Avatar
Send a message via AIM to 12second5.0
Re: BBk Headers, and Throttle body...
First off.A 70mm throttle body is too big for a stock 302.You don't need it.If you wanna upgrade then I'd suggest the 65mm tb.You'd be very lucky if you picked up 10 rwhp.
12second5.0 is offline   Reply With Quote
Old 06-21-2006, 07:16 PM   #3
Send a message via MSN to 1996stang Send a message via Yahoo to 1996stang
257 but only if you remove the converters<<<notice the sarcasm but honestly not enough for the price.
1996stang is offline   Reply With Quote
Old 06-21-2006, 07:51 PM   #4
What if I threw this on it also...More than just a basic bolt on, I know I'll need bigger injectors, etc. Help me out here
Competition Cams Xtreme Energy Cam and Lifter Kits: CCA-K35-522-8 - summitracing.com
I like the idea of my power band be a little higher in the RPM's
Old 06-21-2006, 08:05 PM   #5
bbunt302's Avatar
That cam is way too big for a stock motor.
By moving your powerband up in the RPMs on a stock motor, you are effectively going to make your car slower. The reason being, your current heads and intake are not capable of flowing enough air to make any decent amount of power at higher RPMs. The 5.0L HO cam is actually a decent cam for the parts it was designed to run with.
If you really want to move your powerband up, start saving up for a decent pair of heads and then work from there. A set of AFR 165s on a stock motor will make a lot more power than the little nickel and dime mods that can quickly add up to the same $1300.
Scary stuff.
Old 06-21-2006, 08:24 PM   #6
i know where a twin turbo 351 windsor is buy that.
Old 06-21-2006, 08:51 PM   #7
Thanks for the input... learning more as I go Along. What heads and Intake would outfit the comp cam package. I was looking at a 351 Stroker, but all the extra work is a little out of my price range. I'm looking for 350-400 out of my 5.0.
Old 06-21-2006, 09:19 PM   #8
well this motor is forsale for 1500 i think not positive and you'll spend alot more than that to get 350-400
Old 06-21-2006, 09:54 PM   #9
Is it an 351Ho Motor? Whats the estimated price for a 350-400hp 5.0...
Old 06-21-2006, 10:25 PM   #10
To make it reliably and if that is the 350-400 rwhp you are gonna have to go with a 302 based stroker and you'll spend 5k or more to achieve this.
Old 06-22-2006, 07:11 AM   #11
i also know where a 347 stroker is it would be alot cheaper probably.
Old 06-22-2006, 03:48 PM   #12
Tbird232ci's Avatar
Youve been very helpful in this thread
For 350-400hp, its gonna cost you a lot.
Where did you come up with that number? do you realize how much power that really is? If you go from a stock 5.0, to that much power, youll wreck it.
Old 06-22-2006, 04:04 PM   #13
bbunt302's Avatar
Agreed. A 300 rwhp fox body is a low 12-second car (given the proper supsension, driver, blah blah blah blah blah).
Simply put, it is capable of being a low 12-second car with that amount of power. Actually I've seen them down in the 11's, but who's counting?
300 rwhp can be achieved quite easily with the stock bottom end:
Good aluminum heads + custom cam + decent flowing intake + supporting parts = 300 rwhp.
Just note that "supporting parts" is a pretty damn big list and can get expensive pretty quick.
Scary stuff.
Old 06-22-2006, 09:20 PM   #14
I have just enough money to do all this, and just need some pointers. I'm looking for a weekend rocket... I like the sound of a big cam. I like top end power, What would accomidate this cam and lifter set up. I have $4500 saved just for this. Is it possible to pull 400 hp with out a turbo out of the stock motor with 4500?
Old 06-22-2006, 09:22 PM   #15
With $4500 I can guarantee you 400 rwhp if you are patient
Old 06-24-2006, 08:18 AM   #16
Bane-'s Avatar
4500 would be cake for 300+...get a tfs(or other similar kits) h/c/i kit and a blower
btw, that cam you posted earlier, I know its already been said that its to big for a stock motor....but that wont even work in your motor regardless.
Old 06-25-2006, 05:17 PM   #17
Ok I ordered my first bolt on...(65mm Throttle Body). Whats everyone think of the Trick Flow Track heat engine kit? Or the EFI Kit? Other than Trick Flow
who makes kits, and are they better? I'm ordering sometime this week... Do I need a MAF and injectors? I'll stop there, looks like you just nodded off. Too many damn questions.
Old 06-25-2006, 09:31 PM   #18
Zim
You want to **** me?
Zim's Avatar
If you plan for 350-400hp I would say yes, look for new MAF and injectors as your 19#ers are def. going to be maxed out. Get some 36-42lb injectors and a 75-80mm Maf, you should be good with that. If I had 4500 bucks... this is how I would mod a 5.0:
-AFR 165's $1000-1300 (You may find them used with better valve springs, etc already installed.. thats what id do)
-Some sort of custom grind cam -dunno price we'll say $250
-Edelbrock/trickflow/holley/cobra intakes $3-600
-Long tubes $?
-Exhaust $3-800
-1.7 rockers $?
-used vortech $1500
Thats what Id do building from scratch right there. Youll easily be over 350whp, probably closer to the 450 mark.
I like toys
Old 09-16-2006, 12:25 AM   #19
I spent about 3,500 on mine,and Im running 12.60's.The first things you need are bigger gears(at least 3:73),headers and a full exhaust.Then you should think about a nice set of drag radials,because hooking up makes all the difference in the world.
1quickgt is offline   Reply With Quote
BBK 65mm Throttle Body SonicBlueV6 Pre-2005 V6 Mustang 21 01-08-2010 08:11 AM
BBK 70mm Throttle Body install rstewart Pre-2005 V6 Mustang 11 11-18-2008 12:16 PM
94-98 BBK 56mm Throttle body rydog Mustang Parts for Sale and Wanted 4 06-29-2007 09:05 AM
BBK Throttle Body and Cold Air Kit rbwheeler 2005-2010 Mustang GT 21 06-20-2006 06:47 PM
04:31 PM
