stalling 94 gt - Mustang Evolution
Old 06-28-2006, 09:18 PM   #1
Question stalling 94 gt
i have a
94 5.0 5 speed that dies when i stop at stop signs and idels rough the car is stock except a cold air intake if anyone has any advice on this i would apreciate it! thanks in advance
wmustanggt is offline   Reply With Quote
Old 06-29-2006, 06:46 AM   #2
Bane-'s Avatar
Re: stalling 94 gt
you could start by checking connections like the battery,etc. Also pull your IAC off and clean in it, and the port on the manifold it goes to. Im sure theres more but cant think of anything right now. but im willing to bet its your IAC.
Old 06-29-2006, 08:18 AM   #3
Re: stalling 94 gt
also clean your MAF sensor with contact electronic cleaner NO RESIDUE. Also clean your IAC located near your throttle body (actually bolted to I think) its a round cylinder thing.
Old 06-29-2006, 11:05 AM   #4
Re: stalling 94 gt
i will try those things i have already unhooked the battery and let set then hooked back up to see if it was the computer needing set. thanks for the info
Old 06-29-2006, 11:28 AM   #5
Re: stalling 94 gt
sometimes the IAC that controls the idle while you are in neutral goes bad or the maf that controls the a/f goes bad or are simply dirty. It will help either way~
Old 06-29-2006, 04:51 PM   #6
Re: stalling 94 gt
i tried everything tommorow i think i will try spraying cleaner through the intake and see how that works.
Old 07-01-2006, 02:36 PM   #7
Tbird232ci's Avatar
Re: stalling 94 gt
Make sure your cold air isnt leaking any air at the couplers.
Old 07-01-2006, 03:06 PM   #8
Re: stalling 94 gt
i did check the couplings and i did spray intake cleaner in where the intake meets the throttle body it seems to have helped some! preciate the advice
Old 07-02-2006, 01:13 PM   #9
Zim
You want to **** me?
Zim's Avatar
Re: stalling 94 gt
Spray that cleaner in your MAF sensor too if you havnt already.
I like toys
Car Stalling after disconnecting battery nero 1979-1995 Mustang GT 7 01-17-2011 02:01 PM
03 GT engine stalling midgeorgiastang 1996-2004 Mustang GT 5 02-22-2008 05:38 PM
stalling 5.0 vil8er New Member Introductions & Greetings 0 02-16-2008 02:12 PM
Car Stalling megax29 Pre-2005 V6 Mustang 7 01-26-2007 09:46 AM
stalling on startup Deadmeat101 Pre-2005 V6 Mustang 4 09-16-2003 07:00 PM
03:29 PM
