Stock HO Heads...Suspension! - Mustang Evolution
Old 07-02-2006, 04:11 PM   #1
Fast93Coupe's Avatar
Question Stock HO Heads...Suspension!
I was wondering if it was worth it to port and polish my stock heads, and are there better spring kits for these heads... What upper and lower plenum would match with the ported heads. I was getting ready to order a H/C/I kit, but changed my mind because of tight budget. Off this subject so I dont waste space. I'm looking for the best straight line suspension kit, chassis braces, etc. I want to make my car strong and have good traction when needed. I have a five lug conversion kit off of a 94 mustang, I'm ready except for the rim and tires. I'm not much into road racing so I dont care to much on handling. Any help would be appreciated
---1993 Ford Mustang Lx Coupe-performane bolt ons, BBK Cold air intake, B&M Ripper shifter, King cobra clutch kit, Steeda adjustable clutch kit, basically stock...
*1994 Ford escort Lx- working on it
*1991 Mercury Grand Marquis- Dead...
*1995 Ford escort Lx- Parts car
----Cant find 'em, Grind 'em
Fast93Coupe is offline   Reply With Quote
Old 07-02-2006, 04:33 PM   #2
bbunt302's Avatar
Re: Stock HO Heads...Suspension!
The Ford Racing Cobra intake will work great with the stock heads. The Edelbrock Performer and TFS Street Heat would be two more good options.
As far as porting goes, yes there is more power to be had from porting the stock heads. But you really need to know what you're doing. There is more to it than just whacking out as much iron as possible. I recommend that whoever you have port them has some previous experience with the E7TE heads. As far as the valve springs go, there are millions of aftermarket parts for these cars so finding springs shouldn't not be hard at all. Check out Comp Cams or any other of the big valve-train companies and they should have several different options for upgrades.
As far as the suspension goes, there is a million different ways you could do it. Basically, I'd say some 70/30 struts (for a street car, 90/10 if it's mainly track only), drag shocks, some drag-oriented springs, and some lower control arms. This will get the basic parts of the suspension where they need to be. Once again, there are tons of manufacturer's that make these parts. However, I will recommend that you check out Maximum Motorsports :: The Leader In Mustang Performance Suspensions. I belive they have an entire drag racing suspension package, and their parts are top-notch.
Scary stuff.
Old 07-02-2006, 05:12 PM   #3
Whats the the estimated hp that can be pulled out of stock ported and polished heads, with one of the Intakes mentioned with a 65mm TB. I like the Maxxim Motorsports suspension drag kit, thats probably going kill alot of my money- Ow well It'll be worth it in the end! A little off subject... Whats everyones opinion on the Tremec T-56, I like the sound of a six speed, and its in my price range. I know you have to have a shorter driveshaft... So i'll just up grade to aluminum.
will trade fairings and lowered suspension for stock suspension vincent1 1996-2004 Mustang GT 2 06-22-2009 07:34 AM
FS: BV Heads, 173's,Cam, and Stock Heads petrey10 Mustang Parts for Sale and Wanted 4 06-26-2006 11:15 PM
Wanted: Stock coil springs and stock mufflers for '96 GT inaba116 Mustang Parts for Sale and Wanted 6 02-15-2006 09:19 PM
Stock 03/04 Cobra vs Stock LS1 PureVenom The Bar 46 05-08-2005 05:41 PM
Installing a stock V8 on my stock V6 EXHAUST mrshoss97V6 Pre-2005 V6 Mustang 3 06-30-2004 12:43 PM
08:52 PM
