can't keep my belt on driving a stang - Mustang Evolution
Old 07-21-2006, 10:12 AM   #1
hey guys problem. i have an under drive pulley system on my 5.0 and i have bypassed the air pump for the cats as there are none anymore. the ac is also axed. my problem is i can't seem to get any belts to last. the stocker is and 83 something but i need a 69. the 69 fits perfect when i first put it on. but after awhile it streches out and rubs the eventually breaks. a 68.5 is too tight and will not fit. suggestions?. are there any preformance belts that don't stretch out?
Clay89lxcoupe is offline   Reply With Quote
Old 07-21-2006, 11:11 AM   #2
Danger Dude's Avatar
Re: can't keep my belt on driving a stang
A. You have a pulley not in alignment with the rest of the accessories
B. One of your accessories is dragging
C. One of your pulley bearing/bushings is going bad
D. Evil Gremlins are sabotaging your car when you least expecting it.
Old 07-21-2006, 11:15 AM   #3
So to fix this.
A. You need to spin all the accessories by hand to make sure they spin freely.
B. Put a belt on and watch it go around and look to see if it is rubbing hard to one side of any of the pulley's
C. Check all the pulley's for sharp nicks or damage to the pulley
D. Put a very bright light out in front of your car. Gremlins hate bright light
Old 07-21-2006, 11:44 AM   #4
ya i have spun all of the pulleys by hand. they all move freely. have watched the belt turn and nothing is rubbing to one side or another. it seems like the tensioner stretches the belt out after a few days then it starts to rub, eventually breaks down and shreds.????????
Old 07-21-2006, 11:45 AM   #5
Zim
You want to **** me?
Zim's Avatar
I had problems with my belt falling off, it was because my power steering pulley shaft had cracked and when it spun it wobbled. You could order a set of march pulley's that have lips around them so nothing falls off... but those arent cheap.
I like toys
Old 07-21-2006, 01:15 PM   #6
bbunt302's Avatar
Get the car running with no A/C or defroster on and pop the hood. Check under there and make sure all the pulleys are turning smoothly and there are no hiccups. Then turn your A/C on and check again. Watch the A/C compressor pulley and make sure it isn't locking up.
If it does, your A/C compressor has seized up.
This is just one of many possible causes that I have encountered personally.
Scary stuff.
Old 07-21-2006, 01:27 PM   #7
The other problem is a bad bearing or bushing where when it is cold it will spin freely but underload it is worn and builds up heat and starts to drag and the belt starts to slowly slip that creates heat and will destroy the belt.
Sure you dont have Gremlins?????
Old 07-21-2006, 01:30 PM   #8
Kind of hard to do when he doesn't have an A/C lol
Old 07-21-2006, 01:31 PM   #9
bbunt302's Avatar
I really should read more often.
Scary stuff.
Old 07-21-2006, 02:11 PM   #10
Zim
Zim's Avatar
:yup:
I like toys
Old 07-21-2006, 09:58 PM   #11
MonteCitan's Avatar
I'm having this same problem.. no smog pump, no AC, and my tensioner eventually forces the belt at the tensioner pulley into contact with the part going up to the alternator pulley.. I have stock pulleys and use a 70.5 70 is too tight.. as it is with the 70.5 I have to loosen the power steering pump and lean it over to the side to get the belt on.. I'm trying to find a tensioner or see if I can't modify it to rest up higher..
But until then I am also open to suggestions
oh and its not a pulley nor alignment problem.. its that the belt, with tension, runs within a 1/8th inch of another part of the belt.. with the tensioner at the end of its travel (full spring strength) it doesn't take long to stretch the belt and contacts - with the tensioner pushing it towards the lower part... I bought a smog pump idler pulley (which would cure this) but I cannot find the lower bracket anywhere's (the one for the lower bolt on the smog pump..) so I'm SOL myself for the moment..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 07-24-2006, 11:51 AM   #12
Send a message via Yahoo to skeaheytexas
when you remove the a/c compressor the top axis of the s-belt drops down to the p/s pump and allows the belt to rub itself, by the tensioner, after it streaches. if im not mistaken UPR products makes a p/s pump relocation kit that moves the pump up in order to compensate for the lack of an a/c compreessor. by raisin gthe p/s pump up it brings the belt geometry back to where it works well. hope this info helps out.
skeaheytexas is offline   Reply With Quote
Old 07-24-2006, 03:50 PM   #13
MonteCitan's Avatar
its on the other side of the motor..
+ I used a bracket off a non-AC 5.0 so my power steering is in the proper spot..
Old 07-24-2006, 07:35 PM   #14
Instead of moving the PS pump, Buy a AC delete with the pulley and or a smog pump eliminator. They also make complete eliminator kits.
A/C Eliminators - Latemodel Restoration Supply
smog pump - Latemodel Restoration Supply
Old 07-24-2006, 07:55 PM   #15
MonteCitan's Avatar
smog pump eliminator would solve my problem
BUT I do not have the support brace that goes to the bottom bolt on the smog pulley
Old 07-24-2006, 07:56 PM   #16
bbunt302's Avatar
So does that A/C delete kit keep the PS pump in the factory position? Most of the ones I've ever seen move it up to where the A/C was. But from reading the description, that one doesn't...
Scary stuff.
Old 07-25-2006, 11:16 AM   #17
Zim
Zim's Avatar
Call up your local junkyard, or look on 50resto or something of that nature.
I like toys
Old 07-26-2006, 08:29 AM   #18
fast64's Avatar
ASP Pulleys has some nice shiney ones for about the same price from summit if you like shiney
Auto Specialties Air Conditioning Eliminator Kits: ASP-028200 - summitracing.com
Auto Specialties Smog Pump Eliminator Brackets: ASP-025030 - summitracing.com
GO BRAVES
Old 07-31-2006, 12:15 PM   #19
thanks for the advice everybody. bought a smog pump eliminator from ford racing. seems to have solved the problem.
Old 07-31-2006, 06:44 PM   #20
rocknbronco's Avatar
It honestly sounds like the the belt tentioner to me how sharp are the groves on your pulleys I have seen sharp bulleys kill belts in a few days before.
Mustang wanted for here...
rocknbronco is offline   Reply With Quote
Old 08-01-2006, 09:07 AM   #21
Zim
Zim's Avatar
good deal
I like toys
Old 08-01-2006, 10:53 AM   #22
yea it moves the p/s pump up some not quite to the a/c pos. though. you might also try slotting the tensioner mount so that it can rotate clockwise slightly to allow you to install a slightly shorter belt after you relocate the pump.
also if you have power pullies and don't have any overheating problems you might consider trying the factory water pump pully. it's smaller diameter might give you the needed clearence on the belt.
i have also ran a belt so small i had to pull the top alternator bolt to install it then pull it into position with a little help from a pry bar but don't overdo it. when the belt gets hot the first time it streaches a bit but not real bad. i ran like this on my gt for aprox. a year on a previous motor.
How hard are you on driving your stang? I_luv_HP&trq The Bar 22 12-09-2005 09:55 AM
belt squeeking Zim 1979-1995 Mustang GT 8 12-07-2005 01:12 PM
serpentine belt greenpony02 Pre-2005 V6 Mustang 13 10-21-2004 07:04 PM
Retired the stang from daily driving Dan The Bar 19 01-05-2004 07:54 AM
I am new here, please dont belt me. 98GreenStallion The Bar 40 08-19-2003 03:21 PM
12:34 PM
