351W, 351C, 351M - Mustang Evolution
Old 08-18-2006, 09:35 PM   #1
Send a message via AIM to 351mod_stang
351W, 351C, 351M
After talking to some of my friends and the people i work with i'm a bit confused on some of the 351 facts. I know that the 351M was based on the 400 industrial block which is a big block. So does that mean that nothing can be swapped between the modified and the C/W since they were based on small blocks?
Appreciate any input anyone has so that i can start looking around for parts.
Just so you know my motor is out of a 78 bronco and i have the original flywheel but i've been told i need to swap that too?
351mod_stang is offline   Reply With Quote
Old 08-18-2006, 10:21 PM   #2
Re: 351W, 351C, 351M
I'm kinda curious about the specifics as well. Trying to figure out what kind of bellhousing I'm gonna need made to team a viper spec t56 to a 351 from a later bronco, early 90's.
Old 08-19-2006, 07:00 AM   #3
bbunt302's Avatar
Read the link again I posted in your first thread, i.e. this one.
The main problem with the 351Ms were crappy stock heads, a horribly low compression ratio, and a ****ty cam. You can use some of the different heads from the 351C to get rid of the first two problems. Your best bet will probably be to find a set of 351C 2V heads (70-74) and then use aftermarket pistons to get your CR to a decent number. Unless of course you wanna put a blower on it. Then just get the 2V heads.
Basically, read the link. It has more information than you probably want.
Scary stuff.
Old 07-19-2008, 08:59 PM   #4
Where can I find the numbers to tell which heads I have? This is a set of heads I acquired with a pile of parts mostly late 60s/ early 70s. Kagy
kagy is offline   Reply With Quote
351m questions bloodyspirit058 1979-1995 Mustang GT 6 06-12-2009 06:27 AM
351C 2V vs. 4V? MaresMotorsport Classic Mustangs 3 06-15-2008 01:55 AM
351C 2v mild2002gt 1979-1995 Mustang GT 12 03-07-2005 06:03 AM
94-95 and 96+ v6 rods, and 351w/351w truck rods tire Pre-2005 V6 Mustang 1 02-21-2004 01:37 PM
05:43 PM
