ignition problem on 94 5.0 - Mustang Evolution
Old 05-13-2010, 10:42 AM   #1
my 94 gt 5.0 has an ignition problem. its started out as if it was the ignition controll module, i was driving and just like shutting the key off it died. after cooling down for a few hrs it would start again. so I replaced it. however now after driving it and shutting it off it wont restart untill it has cooled off as if something in the ingnition is overheating and needs to cool down in order to restart. my question for you guys is: what else other than the ICM can cause this what is my next option in terms of repairs?
note. the fuel pump is fine, it still primes up when I turn the key on..
Thanks for your help, you guys are great!!!
Matt
matts94gt is offline   Reply With Quote
Old 05-13-2010, 09:16 PM   #2
Re: ignition problem on 94 5.0
any pros have any suggestions for me? I need to get this fixed asap!!!
thanks
matt
Old 05-14-2010, 04:50 AM   #3
It still could be the icm. Surely sounds like it lol.
Did you use the proper heat resistant product between the icm and dis? It may have fried that one already, won't hurt to pull it off and have it checked.
Old 05-14-2010, 08:20 AM   #4
I changed it again, and it is still doing the same thing, is there inthing thing that could be causeing it to be overheating? It is installed properly...
Matt
Old 05-14-2010, 09:42 AM   #5
racefan966's Avatar
Region: Idaho
Have you checked the coil? If it overheats it will do the same thing. Ohm the coil's primary and secondary and get me the ohms and I will look it up.
racefan966 is offline   Reply With Quote
Old 05-14-2010, 01:43 PM   #6
I have not checked the coil, I didnt realize it could have the same sympoms as the ICM. I dont know how to check the ohm on the coil. what do i need to do that?
Thanks
matt
Old 05-15-2010, 04:23 PM   #7
I believe i have excluded the ICM from the list of possibilities, when it was cool I tested with two of the ICMs to insure they both work. then when it wouldnt start after driving then shutting off i switched the ICM to the other one I confirmed earlier that worked and it still would not start however after sitting for 2 hrs it started again just fine....
so next in line would be?????? Coil????
what else can cause this problem with very similar results to the ICM?
Thanks guys!!!
Matt
Old 05-16-2010, 02:04 PM   #8
well i believe i have fixed the problem, it was the distributer. it started smoking the electronics inside the distributer were overheating. I went ahead and changed the coil out too. so it has a new distributer, ICM, and coil. with all three of these new it better be fixed!
Thanks guys!
Matt
95 mustang wont start, ignition problem? Billy95Gt 1979-1995 Mustang GT 5 07-29-2010 09:03 PM
MSD ignition help blown347ranger 1979-1995 Mustang GT 12 05-30-2007 04:09 PM
Need help with some possible Ignition upgrades Kiljosh Pre-2005 V6 Mustang 10 11-30-2005 11:26 PM
Ignition Lock problem BlueDonkey Pre-2005 V6 Mustang 11 12-31-2004 05:43 PM
Better ignition for 98.... TheSarge Pre-2005 V6 Mustang 2 09-15-2003 09:43 PM
10:42 PM
