where does your clutch release - Mustang Evolution
Old 09-02-2006, 11:32 PM   #1
eagle05's Avatar
Cool where does your clutch release
I just went through an ordeal of thinking I needed to replace the clutch because I couldn't shift gears only to figure out that my floor mat had gotten under my clutch pedal and the fancy pedel covers screws helped to keep it up a little too made it hard to shift and at time it wouldn't shift at all. It is all factory I did replace the cable not long ago hopeing the old one had streached and it did bring it up a very small amount and yes I have pulled up on the pedal to let it self ajust but I just wonderd has ever one got this low of a complete release?
eagle05 is offline   Reply With Quote
Old 09-03-2006, 08:26 PM   #2
Zim
You want to **** me?
Zim's Avatar
Re: where does your clutch release
somethins not right there, mine lets go pretty quick
I like toys
Old 06-10-2007, 03:17 PM   #3
i replaced my clutch last year. i have a 94 gt vert. i have a stage 3 clutch. it releases a little hight right now. i was told it was the stock nylon quadrant that is the problem. after time it flexes too much causing misshifts and such. tryu replacing the quadrant
Ttlpackage is offline   Reply With Quote
Old 06-10-2007, 05:51 PM   #4
rocknbronco's Avatar
Did you get all the air from the clutch lines?
rocknbronco is offline   Reply With Quote
Old 06-10-2007, 07:11 PM   #5
MonteCitan's Avatar
-bronco, as far as I know until recently all stangs had cable clutches, not hydraulic..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 06-11-2007, 11:26 AM   #6
Black95GT's Avatar
Send a message via AIM to Black95GT
Mine is up top. I only need to put it in a inch or so IF that. Its been like that since the day I got her.
-Jason
2003 DSG Cobra -2.2L KB, 60lbs Injectors, Single Blade TB, SCT2400 MAF, Kook's LT's, Kook's High-Flow Catted X-Pipe, Magnaflow CB, JLT RAI, MGW Short-Throw, H&R Race Springs, MM CC Plates, MM Bumpsteer, BF IRS Brace, BF Idlers, and AFS 18 Chrome Reps w/ R888s
Black95GT is offline   Reply With Quote
Old 06-11-2007, 05:29 PM   #7
bullitt482's Avatar
Yes sir, from day one up until 2005 when they switched, for some stupid dumbass ****ing reason.
01 Bullitt
Old 06-11-2007, 05:58 PM   #8
At the top, with a half inch of travel before the clutch starts to slip. This gives the best life for the cluch.
Old 06-14-2007, 09:57 PM   #9
silverstangboy's Avatar
because the modern day mustang is nothing more than a BMW/Mustang/T-bird hybrid comfort muscle car. 2:
ford mustang 1965-2004 RIP little guy.
93 mustang notch
~450hp 331 stroker - Sold
Old 06-15-2007, 10:12 AM   #10
Herbstang's Avatar
Same Here
Old 06-15-2007, 02:52 PM   #11
bullitt482's Avatar
Yeppers..
01 Bullitt
05-09 Trunk Release Button 05bluestang 2005-2010 Mustang GT 21 08-13-2016 10:44 AM
05 trunk release button obxdude018 Pre-2005 V6 Mustang 4 06-09-2010 10:46 PM
2007 GT release date? GTHorsePower 2005-2010 Mustang GT 2 07-02-2006 04:06 PM
***Important Press Release*** Kyle The Bar 3 05-12-2005 07:35 PM
01:34 PM
