New intake - Mustang Evolution
Old 09-15-2006, 11:05 PM   #1
Question New intake
Im currently running a GT-40 upper and lower intake,and I saw this upper plenum in Jegs,for use with the GT-40 lower.Its called the max box,and it says its good for 20 rear wheel horsepower.Does anybody know about these before i blow 450 bucks on one.
1quickgt is offline   Reply With Quote
Old 09-15-2006, 11:16 PM   #2
bbunt302's Avatar
Re: New intake
Usually the box style uppers are designed more for high RPM applications. It really depends on the rest of your set-up as to whether or not it is worth buying. I can just about guarantee that you won't get 20 at the wheels from it though. The GT40 upper is a damn good upper, and you are probably better off keeping it.
Scary stuff.
Old 09-15-2006, 11:22 PM   #3
Re: New intake
Thanks for the reply.Im also running a set of edelbrock heads,E-303 cam,1.6 rockers,65mm throttle body,70mm MAF,long tubes,full exhaust and 4:10 gears.
Old 09-15-2006, 11:25 PM   #4
bbunt302's Avatar
Re: New intake
If I were you, I'd just stick with the GT40 upper. It's probably a better match for the rest of your combo anyway.
Scary stuff.
Old 09-15-2006, 11:28 PM   #5
Re: New intake
Sounds good, thanks
Old 09-18-2006, 11:22 PM   #6
silverstangboy's Avatar
Re: New intake
if I were going to do anyting i'd get rid of that E-303
93 mustang notch
~450hp 331 stroker - Sold
Old 09-18-2006, 11:30 PM   #7
Zim
You want to **** me?
Zim's Avatar
Re: New intake
its not a bad cam...
its what i have too
I like toys
Old 09-19-2006, 06:19 AM   #8
bbunt302's Avatar
Re: New intake
It's not a good cam either.
It was designed by a brontasaurus in the late Jurassic period and reached the height of its popularity during the Ming Dynasty.
Silverstangboy knows because he's had one. And knowing is half the battle.
Scary stuff.
intake porting and powdercoating intake(RGR) 232SCstang Pre-2005 V6 Mustang 7 01-11-2004 08:41 AM
10:34 AM
