Fixed my belt contact problem - Mustang Evolution
Old 09-18-2006, 09:21 PM   #1
MonteCitan's Avatar
The Combo:
Removed smog pump, removed AC, with ford racing A/C delete bracket (moves power steering pump), I was having a problem with the tensioner pushing the belt down onto the stretch of belt going from the water pump pulley to the alternator pulley, causing the belt to burn up.
Here's how it looked at its limit, which with the smaller belt is where it was held.
I needed a fix, so..
Removed the alternator, tensioner, then the bracket for the two (3 bolts in the heads)
matched a drill bit size up to the size of the locator tab on the tensioner, (can get the size drill bit used, if requested) marked a new location for it (which would raise the tensioners lowest point about an inch to an inch and a half from its original location, still applies as much tension, just to a different part of the belt.
Used a vice and an electric drill, it was easy..
I marked/located the hole by using touch up paint on the end of the locator tab, and pressing the tensioner into the place I wanted it, marking the exact size and location of the hole to be drilled
after marking the point, I tapped a punch into the center, indenting it (to guide the drill bit)
Started with a much smaller bit, then switched to the required size, was no problem at all,
put the tensioner back on the car
Belt used was a gates.. # was 60705, its the smallest I can go and still fit around the alternator and power steering pump pulleys- belt now has proper tension on it and has no risk of burning up
--- hope this helps, if you are having issues with the belt, and have removed the smog pump..
And be sure to not go too far, or the tensioner will not reach the belt at all.
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 09-18-2006, 09:22 PM   #2
Re: Fixed my belt contact problem
Nice dude.
Old 09-18-2006, 09:24 PM   #3
Cajun JungleBoy's Avatar
Send a message via AIM to Cajun JungleBoy Send a message via Yahoo to Cajun JungleBoy
very nice indeed
Cajun JungleBoy is offline   Reply With Quote
Old 09-18-2006, 09:25 PM   #4
Fishers Stang's Avatar
sweet!
Charles
Old 09-23-2006, 09:41 PM   #5
Vinnietbird's Avatar
I've got to swap head gaskets,so this is a good time to try that.Great tip.
Vinnietbird is offline   Reply With Quote
Old 09-24-2006, 04:58 AM   #6
powerhungry966's Avatar
Send a message via AIM to powerhungry966
how much hp do u get out of removing the smog (pain in my ***) pump
1989 coupe 5.0 yeessur.
"Shake n bake"
powerhungry966 is offline   Reply With Quote
Old 09-24-2006, 07:03 AM   #7
MonteCitan's Avatar
I have no clue, all I know is I didn't need it, the heads were already plugged off, and the tube going down to the exhaust was removed also.. so the pump came off..
Old 09-27-2006, 08:00 AM   #8
I don't think you gain much horsepower,but removing all of that smog crap really cleans up the engine compartment,and,makes plug changing and header removal/installation on the passenger side a breeze.To remove everything from start to finish only takes 10 or 15 minutes.Get to it.
Old 09-27-2006, 08:51 PM   #9
butbut... i live in cali.. they will put me on the guillotine..
"Shake n bake"
Old 09-27-2006, 09:53 PM   #10
MonteCitan's Avatar
That's the truth!!
Old 09-28-2006, 06:09 AM   #11
bbunt302's Avatar
I wouldn't even think about removing it then. It's not worth the hassle.
Scary stuff.
Old 09-28-2006, 06:58 AM   #12
Luckily,here in Oklahoma,no safety inspections,no smog checks.They just raised the cost of our driver's liscences to $15.00.Fair trade for me.
Old 10-01-2006, 08:37 PM   #13
silverstangboy's Avatar
I dunno, but hearsay claims that 302 fords generally run cleaner without the smog pumps... after the correct tune
93 mustang notch
~450hp 331 stroker - Sold
contact list for jax trip? tedness Regional Mustang Discussion 9 07-12-2005 06:25 PM
Fixed my "rubbing problem" greenflash00 The Bar 2 02-18-2004 10:51 AM
Some Items for Sale for a friend...Look at Contact Info KrazyPony Mustang Parts for Sale and Wanted 1 01-28-2004 09:16 PM
02:58 AM
