POWERR - Mustang Evolution
Old 09-19-2006, 11:41 PM   #1
powerhungry966's Avatar
Send a message via AIM to powerhungry966
Question POWERR
alright guys i have officially put my headers and a mac prochamber with some flowmasters on..(american thunder) it sounds ****ing great.. to me it sounds better then the 05 gt--> it has slp o/r pipe and bassani.. sounds..ehh.. what should i go and do next to the notch performance wise.. what do you guys think? im on a budget being a college student n all.. p.s. its an auto..
1989 coupe 5.0 yeessur.
"Shake n bake"
powerhungry966 is offline   Reply With Quote
Old 09-19-2006, 11:51 PM   #2
Re: POWERR
How about some knew heads, or maybe a cam, or an intake manifold.
JROC is offline   Reply With Quote
Old 09-19-2006, 11:57 PM   #3
Re: POWERR
mmm pricey tho.. heads are in the 1k alone! and cam is cheap, but install is gonna hurt abit, manifold.. mmm sounds like a plann.. YO bbunt! what chu think bruh
"Shake n bake"
Old 09-20-2006, 06:09 AM   #4
bbunt302's Avatar
Re: POWERR
AFR 165s.
Save up and buy them. You'll be a lot happier with them than you will spending 1.3k on little bolt-ons here and there. The little bolt-ons can always come later. You can also do the cam and intake later, preferably at the same time.
Scary stuff.
Old 09-20-2006, 08:13 AM   #5
MonteCitan's Avatar
Re: POWERR
Nice exhaust combo! our cars sound sweet with prochamber & flowbastids...
hear the exhaust clip of my car yet?
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 09-20-2006, 06:12 PM   #6
silverstangboy's Avatar
Re: POWERR
you got gears in that *****?
that'll be worth your wild, until as BBunt said aftermarket heads.
an intake on an otherwise stock car will just make the bottom end torque soft.
93 mustang notch
~450hp 331 stroker - Sold
Old 09-20-2006, 08:56 PM   #7
Re: POWERR
YESSSIR! yes our cars doo sound awesome.. shes a little peppyer and free reving.. monecitan last i heard was that clip that you give me a while back! did you do anything new or something? if u did lemme HEAR IT!! WHICH should i go first tho guys gears? or heads??? if do heads what "supporting" parts would i need, and will i need a tune?
"Shake n bake"
Old 09-21-2006, 07:53 AM   #8
Bane-'s Avatar
Re: POWERR
gears are one of the best bangs for your buck, also suspension parts could be addressed.
Old 09-21-2006, 08:14 AM   #9
MonteCitan's Avatar
Re: POWERR
Aside from a freer flowing intake, which didn't change the sound of the idle at all, no I haven't changed it.. was just checking ...
I'll bet your car sounds great now
Old 09-21-2006, 11:13 PM   #10
Thomas91169's Avatar
Re: POWERR
Gears
then adress the intake. its gonna cost, but you gotta pay to play the game.
-Thomas-
Old 09-22-2006, 06:21 AM   #11
bbunt302's Avatar
Re: POWERR
Gears aren't a bad idea before heads. With the heads you won't need any "supporting parts" if you stay pedestal mount. No tune, no bigger fuel injectors, no bigger TB or MAF is necessary. You may want to go ahead and get an AFPR to bump up the pressure a little. You may or may not want to upgrade the valve springs depending on what cam you are planning to go with in the future. I didn't change mine. You also may or may not want to go ahead and change pushrods. I just did it for the sake of knowing I did it.
Finally, it would also be a good time to buy a good set of roller rockers. You'll absolutely have to if you go with the stud mount heads. I went with the pedestal mounts and kept my stock rockers, but I kinda wish I would have went ahead and changed them because the stock ones look pretty cheaply made. I haven't had any problems from them though.
Scary stuff.
Old 09-22-2006, 12:11 PM   #12
MonteCitan's Avatar
Re: POWERR
I'm using the cobra stock 1.7 RRs.. they seem to be fine
Old 09-23-2006, 01:27 AM   #13
Re: POWERR
thanks b! u rock.. i plann on running YES YET ANOTHER E303, why? because its smog legal.. =) so heads and rockers and pushrods.. ey? how much hp is that good for?
"Shake n bake"
Old 09-23-2006, 07:54 AM   #14
bbunt302's Avatar
Re: POWERR
Read and learn:
Air Flow Research
Then buy.
I can guarantee you that there are no other bolt-ons (other than nitrous or cheap-*** used blower) that you can get for $1300 that will add up to that kind of gains. Plus, you already have the most important piece of any combo. Anything you add from there is gonna see riduculous gains compared to what you would see on a stock motor.
In fact, in some cases you'll see even bigger gains than some of the crazy claims manufacturers make. Especially for the cam and intake.
Scary stuff.
Old 09-23-2006, 10:32 AM   #15
Re: POWERR
yes sensay *bows*
"Shake n bake"
Old 09-23-2006, 10:35 AM   #16
Re: POWERR
HOLY CRAP...now that is a gain! 100+
"Shake n bake"
Old 09-23-2006, 11:20 AM   #17
bbunt302's Avatar
Re: POWERR
Yup, notice that the 100+ wasn't peak horsepower though. It's still quite impressive. They got 72 peak rwhp from stock to the heads, TB, intake, etc.
Also remember, that's still with the stock cam. Throw a decent cam in there with a bigger MAF and 24# injectors, and you'll be looking at another 50 or so at the wheels.
Scary stuff.
Old 09-24-2006, 04:56 AM   #18
Re: POWERR
i was watching horse power tv.. and they had this segment on a 4to7 cam swap.. all the cam did was switch the firing order.. where the seventh cylinder would fire first over the fourth one... and it gave him an extra 50 hP!!!!!!
"Shake n bake"
Old 10-01-2006, 08:40 PM   #19
Re: POWERR
yeah... HO 302's already share the firging order of a 351W
93 mustang notch
02:54 AM
