Erratic Idle problem solved-Intake manifold vacuum leak - Mustang Evolution
Old 06-01-2010, 09:26 AM   #1
Mercedez L.'s Avatar
Thumbs up Erratic Idle problem solved-Intake manifold vacuum leak
Finally
Found out from mechanic what was causing erratic high idle in neutral from 1,500 rpms to 2,000 rpms even did this when driving vehicle as you could hear it when shifting the 5spd.
Mechanic installed new intake manifold gasket. He did a smoke test and showed me where all the leaks were.
Mercedez L. is offline   Reply With Quote
Old 06-01-2010, 11:29 AM   #2
Loc: Austin,TX
Re: Erratic Idle problem solved-Intake manifold vacuum leak
I had the same problem with my olds about ten yrs ago. She wouldn't idle,changed one gasket and BAM!......fixed.
Old 06-01-2010, 01:25 PM   #3
But in this case it was like this for over a year.
The ECT sensor and ACT sensor were both replaced with Ford parts. The Throttle Body was cleaned along with a new IAC Valve and gasket replaced.
After all of that now it works.
Old 07-29-2010, 09:10 PM   #4
95YellowGT_5.0's Avatar
Send a message via AIM to 95YellowGT_5.0
its funny what a little gasket will do
1995 Mustang GT, 5.0 302 Cubic Inch, K&N filter, Short Throw Shifter, Off Road X-Pipe, Flowmaster American Thunder cat-back, MSD Cap and Rotor Kit, MSD Coil & Wires
95YellowGT_5.0 is offline   Reply With Quote
Old 07-29-2010, 10:14 PM   #5
Smile Re: Erratic Idle problem solved-Intake manifold vacuum leak
The ten cent part cost the race
Old 07-30-2010, 08:56 AM   #6
Herbstang's Avatar
Sweet love to hear problem solved
Old 07-30-2010, 08:58 AM   #7
glad to hear that it is fixed
zztop1234 is offline   Reply With Quote
Old 07-30-2010, 09:08 AM   #8
Question Re: Erratic Idle problem solved-Intake manifold vacuum leak
Thanks
Now it has a dead battery
Was running great hours before.
You guys with idle issues (possible vacume leak) try this SpectorV Pre-2005 V6 Mustang 3 06-01-2010 01:28 PM
Muffler Problem Solved SaturnMan8227 Pre-2005 V6 Mustang 16 04-03-2010 11:18 PM
Antifreeze Leak -- Ford Says There ISN'T A Problem superstarjade 1996-2004 Mustang GT 13 02-28-2010 07:49 PM
Exhaust leak to bigger problem? mrjones3133 Pre-2005 V6 Mustang 17 04-29-2009 08:29 AM
weird vacuum problem jedwards242000 Pre-2005 V6 Mustang 7 05-04-2008 12:56 PM
10:15 PM
