Next mods - Mustang Evolution
Old 10-15-2006, 06:18 PM   #1
Next mods
Well I bought my 89 gt about a year ago and it was stock exept for a k&n filter. So far I've added Mac equal length shorty headers,Mac H-pipe,Flowmaster cat back,Mac cold air intake,Ngk Wires and plugs,3.73 gears,aluminum radiator with electric fans,underdrive pulleys,and I still have a 70mm throttle body to put on but I thought I would do that when I get an aftermarket intake manifold. What should I do next?? In the end I want a 331 stroker with a Vortec S trim or a Procharger...My motor does have 150,000 mile so I'm not sure whats next...intake manifold is what I was thinking....then new motor with H/C...what do you guys think??
Jay Rod 5.0 is offline   Reply With Quote
Old 10-15-2006, 07:41 PM   #2
Re: Next mods
You seem to have a pretty good base right now, I'd look at either buying supporting mods for your ultimate goal, or go ahead and start saving/buying your 331 kit so you can get it sooner.
Old 10-15-2006, 10:44 PM   #3
bluemustang's Avatar
Re: Next mods
yeah id just save for the stroker kit really. will be very very worthwhile and less stressful in the end
Old 10-16-2006, 08:12 AM   #4
MonteCitan's Avatar
Re: Next mods
I did what you're planning -- eventually got a 331 and will eventually get the blower for it.. I started out getting the supporting mods.. then went for the 331 -- I'm using a GT-40 tubular upper/lower intake but I think its choking my car's performance.. get something that can better handle it.. BBK/edelbrock performer RPM, trickflow etc are all better flowing..
Be sure to use a cam that can work well with either NA -or- boost on a 331 to save you from having to change it later on with best performance for the S/C
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 10-16-2006, 11:36 AM   #5
Re: Next mods
How bout in the mean time source some junkyard gt40 heads,and dump the a/c and smog pump?
SwampStang770 is offline   Reply With Quote
Old 10-16-2006, 11:59 AM   #6
Re: Next mods
cant lose wit JY GT40s thats for sure
Old 10-16-2006, 12:59 PM   #7
Re: Next mods
while your yanking them heads,grab the intake too.
Old 10-16-2006, 01:05 PM   #8
powerhungry966's Avatar
Send a message via AIM to powerhungry966
Re: Next mods
afr 165 heads as the mighty b would say haha
1989 coupe 5.0 yeessur.
"Shake n bake"
powerhungry966 is offline   Reply With Quote
Old 10-16-2006, 04:14 PM   #9
bbunt302's Avatar
Re: Next mods
Either that or start saving up for the stroker. I really wouldn't get the 165s with a stroker though, especially with a blower. You'll probably want the 185s for that.
Scary stuff.
Old 10-17-2006, 05:57 PM   #10
Re: Next mods
Thanx guys for the info...where is a good place to buy gt40 heads.what about rockers and new pushrods and all of that stuff??..if stay with the stock motor for awhile(I really dont drive the car much)..what supporting mods do I need...(fuel pump,injectors,ect.) help a newbie out ..
Old 10-18-2006, 07:56 PM   #11
silverstangboy's Avatar
Re: Next mods
from me
GT-40P 1.6FRPP Rollers
93 mustang notch
~450hp 331 stroker - Sold
Old 10-20-2006, 04:01 PM   #12
Re: Next mods
What do you guys think of the Trick Flow top end kit?? what supporting mods would I need for that??? thanx again guys...
Old 10-23-2006, 06:43 PM   #13
Re: Next mods
i've heard a few good things about the trick flow kit, hearsay though.. and from the internet, but all that aside i've only heard good.
93 mustang notch
Old 10-24-2006, 07:01 AM   #14
Re: Next mods
I used a 190 lph fuel pump, 24 lbs. injectors, an adjustable fuel pressure regulator, calibrated mass air meter, and 65 mm throttle body to support the top end kit. I had this set up in an automatic with 4.10's and it ran 12.80's. I am currently installing it into a 5 speed with 4.10's.
trickflow5 is offline   Reply With Quote
Some welcome mods... The Whistler Pictures and Videos 10 03-23-2011 12:24 PM
mods going on lightning 1996-2004 Mustang GT 4 03-23-2011 12:18 PM
New Mods... The Whistler Pictures and Videos 12 10-10-2008 11:24 AM
What mods? 00 V6 smith710 Pre-2005 V6 Mustang 15 05-01-2008 11:03 AM
all mods are done...........almost Kyle Pictures and Videos 26 04-24-2007 02:52 PM
03:11 PM
