Still Missin - Mustang Evolution
Old 10-16-2006, 01:05 PM   #1
Justin's Avatar
Send a message via AIM to Justin Send a message via Yahoo to Justin
Still Missin
I changed my spark plugs, wires, ran some engine cleaner and seafoamed my car and it still has a little miss...any other suggestions
http://www.mustangevolution.com/forum/signatureuploads/sigpic5474_2.gif
(Project "TORQUE"):burnout:
Mods - Off Road H w/ Flowmaster 40s and 3" x 22" Tips, Shiftkit, Shorties, and 4.10s
Soon to come - UDPs, Off Road X-Pipe, A/T Cooler, and 03' Cobra Rims
Club - Tha Crew Leader of Muscle Car Division
Justin is offline   Reply With Quote
Old 10-16-2006, 01:14 PM   #2
Stumpy's Avatar
Re: Still Missin
Did you change or check the cap and rotor? If the points are dirty it will miss.
~Roman~
2003 Mustang V6 Vert with a Flowmaster Super 40 series dual exhaust
I'm not a target in the sights of your mercy. I've never asked for anything. I'm not asking now.
Stumpy is offline   Reply With Quote
Old 10-16-2006, 01:27 PM   #3
Justin's Avatar
Re: Still Missin
yea i checked them...the plug wires looked fairly new....im thinkin about bringin my car to mineke right up the road from my house and seein if they can tell what it is...
Old 10-16-2006, 10:25 PM   #4
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Re: Still Missin
What all have you done to it mod wise? Is there anyway your timing could ahve been changed?
DarkShadow is offline   Reply With Quote
Old 10-17-2006, 07:11 AM   #5
Justin's Avatar
Re: Still Missin
i havent done anything to the motor mod wise....the guy before me put a shift kit in it and i did the exhaust
Old 10-26-2006, 06:30 PM   #6
eagle05's Avatar
Cool Re: Still Missin
I would check for vacuum leaks the hoses that go under the upper part of the intake if they have never been changed could be your problem I had to remove my uper intake to change them. also you can pick up a code reader for the 5.0 95 back for around 35 bucks or so and it will do a balance test on all your cylinders to find which cylinder is the weak one. you could have a bad wire plug bad injector or a burned valve on one cylender. did all your plugs look about the same when you changed them? if so it could be a vacuum leak if one looked different Oily or smutty it could be just one cylinder but I would spend the 35 bucks for a code reader and another 14 for a hanes repair manual it beats paying a mechnic if you don't have to. I was raised poor and we had to fix everything couldn't aford not to.
eagle05 is offline   Reply With Quote
Old 10-27-2006, 03:51 PM   #7
Justin's Avatar
Re: Still Missin
I have a haynes manual and where would i get a code reader at?
Old 10-27-2006, 05:26 PM   #8
eagle05's Avatar
auto zone or any auto parts store "Actron ford code scanner part # I think is CP9015" just read the instruction that come with it. Your hook up is found on the passanger side under the hood between the fire wall and the inner fender wheel well. If its a 95 GT 5.0 I know thats where mine is.You can use it on most older fords but you will find there hook ups on the drivers side on a lot of them. It may be cheeper then 35 buck I think the advance auto parts book spring/summer 2006 shows it for 29.88 bucks on page 143 bottom left hand side of page Hope this helps
Old 10-27-2006, 05:29 PM   #9
Justin's Avatar
Re: Still Missin
Thanks...Ill check it out
Old 10-27-2006, 06:28 PM   #10
Re: Still Missin
You can talk to Cody about it this weekend too at the dyno thing tomorrow. He might could point you in the right direction as well...too bad your car won't be in town, he could check it out then.
I'm missin'.....Plug problems? ChickStang02 1996-2004 Mustang GT 37 05-03-2007 12:46 AM
07:20 AM
