1989 5.0 starting problems - Mustang Evolution
Old 10-17-2006, 05:50 PM   #1
There is something simple that I am missing with all this. The engine temp started climbing the other day. it got the car home safely and replaced the water pump. i am now having difficulty starting the engine. The fuel pump is operating, the engine turns over and i have spark...? What could i be missing?
Help!!!!
tellico40 is offline   Reply With Quote
Old 10-17-2006, 05:59 PM   #2
bbunt302's Avatar
Re: 1989 5.0 starting problems
Sounds like you may have blown a head gasket and no longer have enough compression to crank it. Check your coolant for oil and vice versa (although if oil was getting in the coolant, you should have seen it while changing the water pump). Just a thought.
Scary stuff.
Old 10-17-2006, 06:12 PM   #3
Can I loose compression if i wrung off the top driverside bolt of the waterpump? I have noticed a leak around that bolt. Does the hole for the bolt run that deep?
Old 10-17-2006, 06:38 PM   #4
bbunt302's Avatar
No, you won't lose any compression due to that.
Scary stuff.
Old 10-18-2006, 07:58 PM   #5
silverstangboy's Avatar
you have warped the heads due to overheating.
it happens it sucks.. and its nothing some new gasgets and a mill job wont fix
sorry mate
93 mustang notch
~450hp 331 stroker - Sold
Old 10-19-2006, 05:21 PM   #6
The vehicle was shutdown to allow it to cool down. Coolant was added and the vehicle, though hotter than normal was driven 9 miles home. It idled and ran fine. The waterpump was determined to be the problem. It has not started since the pump weas replaced. I thought that if engine ran ok until i got it home, the heads or head gasket could be runned out.
I have been trying to figure how I could have goofed up the timing.
These responses are great. I appreciate the support.
Starting problems! 99 SVT Cobra 1996-2004 Mustang GT 2 01-10-2010 04:47 PM
Just starting need help V8HUNTER Pre-2005 V6 Mustang 20 08-08-2008 02:01 PM
Starting Problems Zak Attack 1979-1995 Mustang GT 16 05-17-2006 07:54 PM
1998 Ford Mustang Starting Problems redv6stang Pre-2005 V6 Mustang 4 09-25-2005 02:17 PM
starting off utmusicnut Pre-2005 V6 Mustang 12 08-28-2005 12:28 AM
» Members Mustangs
R1
Untamed5.0
silvia
Smoke
Add your Mustang
10:07 PM
