Aluminum heads - Mustang Evolution
Old 10-20-2006, 10:14 PM   #1
powerhungry966's Avatar
Send a message via AIM to powerhungry966
Aluminum heads
will afr 165's work with stock components? like stock pistons and etc. would i have to get a tune? would i have to update my injectors and MAF?
1989 coupe 5.0 yeessur.
"Shake n bake"
powerhungry966 is offline   Reply With Quote
Old 10-21-2006, 06:19 AM   #2
bbunt302's Avatar
Re: Alumminum heads
Yes. No. And no.
You can throw them on an otherwise 100% car and be good to go.
Now... if you also have an aftermarket cam and intake, you may want to look into upgrading to 24# injectors and a MAF tuned for them. With just the AFRs, you may also want to buy an AFPR and bump the PSI (or bars for our gay friends out there in TV land) up a little.
Also, the stock pistons thing is kinda dependent on the cam. With the stock cam, there will be absolutely no problem. With a mild aftermarket cam, there should also be no problem, but you'll want to check your piston to valve clearance to be sure. Every engine is built slightly different (factory tolerances aren't the greatest), so what clears on one may not on another.
Finally, a tune is always a good idea, but it is not necessary. My car has never been tuned, other than my own adjustments of fuel pressure and timing. With a good aftermarket mass air meter (i.e. Pro-M), the fuel mappings should be pretty damn close to what you will need. My car has over 25k miles on the motor now. I know it's running a little rich because the 30# injectors are a little big for my combo. But when I pulled the plugs last weekend, they all looked to be in pretty good shape. Well, except for the couple that you could tell there had been some oil in the combustion chamber, but that's another issue all together.
Basically what it comes down to is this: Buy 'em. I promise you won't regret. My AFRs are without question the best $1275 I ever spent.
Scary stuff.
Old 10-22-2006, 01:14 AM   #3
Re: Alumminum heads
with a e303 cam would that be okay? what about those roller rockers? adjustables and non? what is the difference? i mean do i really need to be adjusting ****?
"Shake n bake"
Old 10-22-2006, 01:19 AM   #4
bbunt302's Avatar
Re: Alumminum heads
E303 should be fine, but...
If I was you, I'd take the E cam out and use it as a club to wield off stalker chicks or something. There are much better cams out there.
The stock roller rockers will work fine. That's what I still have in my car. If you want to use the stock rockers, be sure to get the pedestal mount heads. Otherwise, you'll have to change to stud mount rockers and do all the adjustments. For a street car, I'd much rather have pedestal mount. If you do want to upgrade to a better pedestal mount rocker though, I'd stay with a 1.6 ratio.
A 1.7 ratio is pretty much a stupid mod if you are buying a cam at the same time. All it does is worsen your valve train geometry. Get the cam ground with the lift you want instead of using higher ratio rockers to get the extra lift.
Scary stuff.
Old 10-22-2006, 01:59 AM   #5
Re: Alumminum heads
**** god damn sucks to be a nub... so whats new with ur coupe b
"Shake n bake"
Old 10-22-2006, 08:10 AM   #6
bbunt302's Avatar
Re: Alumminum heads
Nothing as of yet. My dad hasn't had time to do anything with it.
Scary stuff.
Old 11-29-2006, 05:50 AM   #7
Re: Alumminum heads
yes I know what you mean. I am a newbie too. I just bought a 93gt last nigt and as far as I can tell he told me it had a trick flow intake ram air kit bbk pullies rollor rockers a roller cam bbk chrome long tube headers o/r h-pipe 24lb injectors I think there blue 70mm maf.Now it puffs light gray smoke when you romp on it he says its running to rich and that it needs a tune now what do I do and how can I tell if its the stock heads?
cowboy72 is offline   Reply With Quote
Old 11-29-2006, 05:13 PM   #8
silverstangboy's Avatar
Re: Aluminum heads
casting number will tell you what heads you have..
aftermarket will most likely be aluminum.
all 302 HO's have roller cams...
you can see roller rockers from the oil spout.
if it's running rich you'll need a fuel pressure regulator and a shop with wideband.
93 mustang notch
~450hp 331 stroker - Sold
Old 11-29-2006, 05:18 PM   #9
Re: Aluminum heads
it has a pressure gauge tied into the fuel rail. where is the casting number
Old 11-29-2006, 06:36 PM   #10
Re: Aluminum heads
usually if there is a gauge then there is also regulator, this is a good thing.
I believe the casting number is stamped somewhere near the bottom of the head by the spark plug..
stock is E7TE-PA
cobra is F3ZE-AA and F4ZE-AA
GT-40 explorer F1ZE-AA
GT-40P explorer is F7ZE-AA
93 mustang notch
Old 11-29-2006, 08:13 PM   #11
Re: Aluminum heads
thanks I will look for that tommorrow
79-93 Be Cool Aluminum 2-row radiator w/ aluminum cap fast64 Mustang Parts for Sale and Wanted 6 07-22-2009 02:14 PM
heads 05+ 4.0L V6 2007STANG Mustang Parts for Sale and Wanted 1 07-22-2009 12:02 AM
need help with heads johnnyc 1996-2004 Mustang GT 2 06-08-2009 01:15 AM
FS: BV Heads, 173's,Cam, and Stock Heads petrey10 Mustang Parts for Sale and Wanted 4 06-26-2006 11:15 PM
heads 93stanger 1979-1995 Mustang GT 12 05-24-2006 08:05 PM
05:02 AM
