What kind of computer/mass air set up are you guys using? - Mustang Evolution
Old 10-29-2006, 07:27 AM   #1
I just made some performance upgrades. I changed injector size, heads, intake, cam. Would the FordMotorsports setup work with this? I believe they come calibrated to the 24 lbs. injectors. that is what i use.
trickflow5 is offline   Reply With Quote
Old 10-29-2006, 10:27 AM   #2
bbunt302's Avatar
Re: What kind of computer/mass air set up are you guys using?
I just the stock ECU and a Pro-M MAF. It works great for me. The only problems I ever have is idling on cold mornings. Until the engine gets warmed up it has a pretty bad rolling idle. Once it's warm though, it runs perfect.
Scary stuff.
Old 10-29-2006, 02:30 PM   #3
rocknbronco's Avatar
none
Mustang wanted for here...
rocknbronco is offline   Reply With Quote
Old 11-06-2006, 08:16 PM   #4
MonteCitan's Avatar
What year is your car? 94-95, I would suggest swapping to a fox body PCM (
A9L calibration for example) or getting it tuned.. tune is a must for 94-95s..
for the fox bodies..
I am using pro-M / diablosport chipped ECU --
Stock PCM, pro-M and 24# injectors.. put out 292 HP on a loaded dyno.. on a 15.1 or so A/F ratio (LEAN)
tuned in (diablosport chip + custom dyno tune) its locked in about 13.0:1 A/F and is up to 310 HP..(chart in sig..)
According to the tuner the majority of why I was running lean was due to the aftermarket mass air meter -- bbunt, I'd bet with a tune your car would haul ***, and I had the same cold start idle issue pre-tune
-> as for your question, the FMS mass air will work, but EEC IV is rather .. outdated.. to be sure/for best performance.. have someone tune it/ or at least find someone with a wideband o2 system, and use a mini AFC to dial in the correct A/F ratio..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 11-07-2006, 08:53 AM   #5
My car is an 89. I am going to maybe try a 93 cobra computer. I think they came with 24 lbs. injectors stock. I might try that and try the mass air sensor for the same computer. I will need to order the 24 lbs. sample tube. Do you think this will work.
Old 11-07-2006, 09:21 AM   #6
I will be running a cobra on my red top
Old 11-07-2006, 10:54 AM   #7
MonteCitan's Avatar
That could work..
but regardless of what you go with.. a tune would be your best bet on making sure it all works together
Old 11-07-2006, 11:08 AM   #8
I live in the south western area of PA near Altoona. I am wondering about finding someone in this area that could do a decent tune job. I don't know of anyone offhand.
Old 11-07-2006, 11:18 AM   #9
MonteCitan's Avatar
I would be able to help you out if you lived in eastern PA.. but I don't know anyone out west.. I'm sure they're around though
GT MAss air? 232stang01 Pre-2005 V6 Mustang 16 03-12-2005 05:59 AM
Mass Air Flow and Cold Air Intake Mike's-stang Pre-2005 V6 Mustang 1 08-20-2004 09:24 AM
what kind of **** did u guys get into trouble for? Smokedya95stang The Bar 32 05-06-2004 05:05 PM
Mass air upgrade: ASSEMbler Pre-2005 V6 Mustang 5 11-15-2003 12:50 PM
12:05 AM
