87 Mustang has very high idle and running VERY rich. Any ideas? - Mustang Evolution
Old 06-19-2010, 01:37 PM   #1
Hi I have a 1987 Mustang GT Convertible 5.0 High Output and I have a Problem. When my car is in idel it is very high and the car is running real rich. I just replaced my valve covers and my upper intake gasket cover and I fixed the vacum lines that were leaking. I'm not sure why my car is running so high in idel and is running rich, It smells like gas as soon as i turn it on and if i put my foot in the pedal black smoke shoots out. Any suggestions on how to fix this? thanks a bunch!
clannan1 is offline   Reply With Quote
Old 06-24-2010, 11:55 PM   #2
Re: 87 Mustang has very high idle and running VERY rich. Any ideas?
id look at the fuel pressure regulator first cause its easy.
iamdat is offline   Reply With Quote
Old 06-25-2010, 12:54 AM   #3
how do i check that? lol
Old 06-25-2010, 06:36 PM   #4
pull the vacuum line off of it. see if there is any indication of fuel there.
Old 07-17-2010, 11:04 PM   #5
91sleeper's Avatar
Sounds like you still have a vac leak somewhere. For idle reset unplug the IAC set the idle screw to where you want it and then plug the IAC back up. Also clean you maf meter with some Electronics cleaner.
331stroked vortech 16psi
91sleeper is offline   Reply With Quote
Old 08-21-2010, 12:25 PM   #6
timing is up too high?
wizud222 is offline   Reply With Quote
I'm RICH!!!! I'm RICH!!!! PureVenom 1996-2004 Mustang GT 34 04-23-2009 10:23 AM
high idle chris098 1996-2004 Mustang GT 1 05-16-2008 07:33 PM
High RPM idle electricstang Pre-2005 V6 Mustang 4 09-25-2005 01:55 AM
is hollywood running out of original story ideas? fast64 The Bar 21 06-20-2005 08:22 PM
07:00 AM
