93 cobra intake - Mustang Evolution
Old 11-13-2006, 11:18 PM   #1
93 cobra intake
What is the throttle body opening for this manifold..I have a 70 mm and wondered if this intake would work??
Jay Rod 5.0 is offline   Reply With Quote
Old 11-14-2006, 08:09 AM   #2
Re: 93 cobra intake
Stock i think it is a 65 mm but your 70mm should fit and should work. depending on how much horsepower you have the 70 might be a little too large for your application.
trickflow5 is offline   Reply With Quote
Old 11-14-2006, 08:24 AM   #3
Re: 93 cobra intake
I have sh*t load of bolt ons...do I need an upgraded Mass Air to get the most out of it..if so which one?? I still have stock injectors and pump. thanx
Old 11-14-2006, 10:02 AM   #4
Re: 93 cobra intake
As long as it has the 19 lbs. sample tube in it it will work. I have one for sale with the 19 lbs. sample tube. It is a 77 mm Pro M meter with the 19 lbs. tube and the stock sensor on top. You would just have to pay me and pay the shipping to wherever you are. This one worked good one mine when it was stock except for the 65 mm throttle body and e 303 cam. Now I have 24 lbs. injectors so it doesn't work right anymore. It was around 260 new.
Old 11-14-2006, 12:59 PM   #5
bluemustang's Avatar
Re: 93 cobra intake
stock is 65mm....you get the 5.0 mag? cause in this months issue they show you how to make the opening bigger on the intake. I suggest you take a quick look at it
Old 11-14-2006, 01:07 PM   #6
Zim
You want to **** me?
Zim's Avatar
Re: 93 cobra intake
I have a 70mm on my 94 intake... dunno how much different they are though
I like toys
Old 11-14-2006, 08:38 PM   #7
Re: 93 cobra intake
I'm in PA also trickflow5...are you anywhere near me?? I'm close to York,Pa ..??
Old 11-14-2006, 08:53 PM   #8
Re: 93 cobra intake
I was just surfin' around and came across the typhoon intake...will this work with my set up...or is it too much for the stock heads and cam and mass??? thanx again!!
Old 11-14-2006, 09:07 PM   #9
Re: 93 cobra intake
i personally reccomend just saving your cash and doing h/c/i all at once
but thats just me.
Old 11-14-2006, 09:40 PM   #10
bbunt302's Avatar
Re: 93 cobra intake
but thats just me.
x20
Scary stuff.
Old 11-15-2006, 06:40 AM   #11
Re: 93 cobra intake
I am located near altoona pa
Old 11-15-2006, 08:09 AM   #12
Re: 93 cobra intake
I have tooo many other car projects right now to really do h/c/i all at once..I just wanted an intake to sit there and look pretty and give me a bit more horse...so which would you do and would you upgrade you mass?? Does it bolt-on to my Mac coldair intake?? Sorry for all the questions guys but I'm new to the game...after my other 2 cars are done...the mustang will get all new stuff with prob. a turbo setup...
Old 11-15-2006, 09:30 AM   #13
Re: 93 cobra intake
OffTopic:
i feel bad for ya jk i used to go to school over in the armpit of that section of PA grand ol blairsville
If u want suttin to look pretty why not just go on the juice thats always purdy
Old 11-15-2006, 10:35 AM   #14
Re: 93 cobra intake
Blairsville has a dragway there now. It has probably been there a long time. They need a track out closer to Altoona. There isn't anything closer than Blairsville. Ebensburg airport has an event once a year for drag racing an eighth mile on the runway. I hope my car is all dialed in till then. I need to get the computer tuned and some NOS till then.
Old 11-15-2006, 10:41 AM   #15
Re: 93 cobra intake
yeah that dragways been there for a bit. when i was down in school down there a bunch of us always went to the track.
Old 11-15-2006, 10:42 AM   #16
Re: 93 cobra intake
Anyone...help!! I just wanna get rid of this ugly stocker!!
Old 11-15-2006, 10:57 AM   #17
Re: 93 cobra intake
use the ford motorsport cobra intake summit racing sells a polished model
Old 11-15-2006, 11:48 AM   #18
Re: 93 cobra intake
will this work with the stock mass air and with my 70mm throttle body??
Old 11-15-2006, 04:12 PM   #19
bbunt302's Avatar
Re: 93 cobra intake
Yes, it will work fine. I'd also recommend the polished Cobra intake.
Scary stuff.
Old 11-15-2006, 08:56 PM   #20
12second5.0's Avatar
Send a message via AIM to 12second5.0
Re: 93 cobra intake
Yes,it will work but the 70mm throttle body is overkill for a fairly stock application.
12second5.0 is offline   Reply With Quote
Old 11-15-2006, 09:19 PM   #21
Re: 93 cobra intake
i also notion to get teh cobra intake but id see if u can get rid of that 70 for a 65 be tons more efficient for sure
Old 11-16-2006, 07:07 AM   #22
Re: 93 cobra intake
Well...I really dont wanna get rid of this 70mm...may come in handy depending what direction I go in...thanx
Old 11-16-2006, 12:10 PM   #23
Re: 93 cobra intake
well go over at corral and find a 65 cause im sure theres plenty of peeps seeling them for cheap
Old 11-16-2006, 03:57 PM   #24
bbunt302's Avatar
Re: 93 cobra intake
Don't worry about getting rid of the 70. It will be fine. It really does not make that much of a difference. You do not lose that much air velocity due to an oversized TB. Plus, if you ever upgrade later, it will be nice to have.
Scary stuff.
Old 11-16-2006, 09:58 PM   #25
Re: 93 cobra intake
Thanx peps...anything else I should do to this car...I also got a 70mm mass air from a 93 cobra comin' to me...picked it up for next to nothing...its old but almost brand new if you know what I mean...its cal. for 19lb. injector too.. ....after this I'm gonna enjoy the car for awhile...then BIGGG Power...Turbo...or Big SC.....what do you think this car could run...13.5 with slicks???cant really find out till spring now that the tracks are closed!!
Old 11-17-2006, 06:51 AM   #26
Re: 93 cobra intake
What other mods do you have? Does it have the stock gears?
Old 11-17-2006, 08:21 AM   #27
Re: 93 cobra intake
3.73 gears,Mac equal length shorty headers,Mac h-pipe,Flowmaster catback,Underdrive pullies,Mac coldair intake,NGK wires and plugs,aluminum radiator and electric fans and 93 cobra intake and 70mm throttle and 93 70mm mass air to that i need to put on..(no i didnt get the 93 stuff yet but its coming.. ) I think the stock fuel system is prob. max out ..
Old 11-17-2006, 08:32 AM   #28
Re: 93 cobra intake
Your car should be into the 13's. The fuel system shouldn't be too much of an issue yet. The stock pump is made to work with the 19 lbs. injectors. Summit sales a summit brand in tank pump in 190 and 255 lph. The 190 is only about 94 bucks which is a pretty good deal considering what FMS wants for one. Holley sales an adjustable fuel pressure regulator from 25-85 lbs of pressure for below 40 bucks. That would be a good start on that. It doesn't come with a gauge though to read what you have it set at. I am currently running way to rich. I am probably running to much fuel pressure, along with my computer needing a good tuning, and I am ordering a new mass air meter which should straighten it all out.
Old 11-20-2006, 08:17 PM   #29
silverstangboy's Avatar
Re: 93 cobra intake
going too large on the TB doesn't really effect power, but it does make drivability a *****
A typhoon and a GT-40 intake are two large for stock heads
especially the typhoon, its a really awful version of the edelbrock RPM (think BIG headed high RPM 302, or unatural aspiration)
93 mustang notch
~450hp 331 stroker - Sold
Old 11-21-2006, 02:20 PM   #30
Re: 93 cobra intake
Why is drivability a *****?? Less throttle response??
04' Cobra intake and supercharger PICS. needed if anyone can help!!! pan 1996-2004 Mustang GT 24 02-10-2009 03:33 PM
cobra intake swap 95stang_gt 1979-1995 Mustang GT 14 07-22-2008 05:40 PM
10:50 PM
