5.8(351) E7TE Heads... - Mustang Evolution
Old 11-18-2006, 08:29 AM   #1
Fast93Coupe's Avatar
What kind of changes would I have to make on my 5.0L for 5.8L E7TE Heads?
---1993 Ford Mustang Lx Coupe-performane bolt ons, BBK Cold air intake, B&M Ripper shifter, King cobra clutch kit, Steeda adjustable clutch kit, basically stock...
*1994 Ford escort Lx- working on it
*1991 Mercury Grand Marquis- Dead...
*1995 Ford escort Lx- Parts car
----Cant find 'em, Grind 'em
Fast93Coupe is offline   Reply With Quote
Old 11-18-2006, 03:07 PM   #2
Fox
Fox's Avatar
Send a message via Yahoo to Fox
Re: 5.8(351) E7TE Heads...
Thats a good question,I have them heads too lol of course I do anyway I have been wondering kinda the same thing but I am not going 5.8 liter.I have heard that the E7s are good heads to play with and they are just as dependable as them 1200 dollar ones.You can build the E7s but how much is too much?
Fox is offline   Reply With Quote
Old 11-18-2006, 06:14 PM   #3
bbunt302's Avatar
Personally... I'd junk them and get a decent set of heads. Yes, you can play around with the stock heads, but it probably won't get you very far.
I'm also not sure what you mean by 5.8 E7TE heads. E7TE is the casting for the stock 5.0L Mustang heads from 87-93. I was thinking the 351 heads had a different number, but I could be wrong about this.
Scary stuff.
Old 11-19-2006, 08:49 PM   #4
12second5.0's Avatar
Send a message via AIM to 12second5.0
They have an E7 351 head.Only difference between your existing head and the 351 is the provision for head bolt size.There would be absolutely no advantage in running them.The only 351w series heads that had larger valves and slightly bigger intake ports were the 72 and earlier heads.
12second5.0 is offline   Reply With Quote
Old 11-20-2006, 08:10 PM   #5
silverstangboy's Avatar
in which are probably going to have WAY to low of compression ratio for an NA 302
do some compression height calculations for a 302 vrs 351 and you'll see what I mean.
93 mustang notch
~450hp 331 stroker - Sold
Old 12-08-2006, 09:36 AM   #6
jwyche's Avatar
If you are thinking about using stock heads, do yourself a favor and check out Thumper of Orange Park .
Mike Schultz, at Thumper Performance, is a wizard for making cheap power. His ported heads on basic bolt-on cars run mid to low 12's. With a small shot of nitrous some have gone as fast as the upper 10's. That's customer reports, not Mike talking.
I certainly don't want to get into a debate on which is better, ported stock or aftermarket aluminum, chocolate or vanilla. The answer is always, "That depends". But, fast is always fast.
His packages go from $595 to $995. Here's one:
Thumper Heads and Cam combo #1 :
Thumper Ported E7s (219/155 cfm)
Vassco springs, moley retainers and keepers
For cams to .600 lift
Double roller timing chain and gear set w/9 position key way
FMS "E" ( for AOD cars), "B" , or TFS1 cam
Instructions on installation and Cam phasing for the best power and performance for you application
Proven 12 sec combination
$995.00 + 100.00 refundable core charge**
Quick is quick, regardless of the equipment. Check out his site. There's a ton of tech reports and testimonials on it.
He's doing a 347 for me.
Good luck in what y'all do.
Jim
Jim Wyche:Senior Citizen. 1992 Mustang GT with a few mods. See webpage http://web.mac.com/jwyche or my garage. 2002 Mustang GT with a few mods. Collegedale, Tennessee.
jwyche is offline   Reply With Quote
Old 12-09-2006, 04:39 PM   #7
rocknbronco's Avatar
Jim
OMG Collegedale is representing
Mustang wanted for here...
rocknbronco is offline   Reply With Quote
Old 12-09-2006, 08:05 PM   #8
jwyche's Avatar
Yep, right here in the BIG city. How is the '65?
Jim
Old 12-16-2007, 03:13 PM   #9
I believe the pushrod tubes in the 351 are smaller in diameter that makes this head more attractive for porting but the ports are thinner than the 5.0's. I learned that the hard way after I blew into the water jacket in an intake port.
E-7 1.940 valve info
JimV is offline   Reply With Quote
Old 12-17-2007, 09:20 AM   #10
Titus Wadicus
svtlx's Avatar
yall know i had to comment. it's true, fast is fast regardless of the equipment. i've dusted off aluminum head owners with my ported e7's with stock valves. a properly ported e7 will outflow a gt40p head which has larger valves. i've never owned a "good set of heads - aftermarket". but i dont mind doing the port and bowl work. if u r on a budget, porting stock heads is a cost effective solution, yielding good results, most of the time. especialy if u educate yourself on velocity, volumes, & compression ratios. i've done "e6se...e7te...d8oe" and before ppl start talkn bout the low compression, remember i run 9lbs of boost. however for n/a...i would stay with e7's....or put a set of gt40(p)...if u r on a budget...the most bang for the least buck, if u r a home head porter like me......i like run'n "oem production parts" on my car...just my personal preference...i like see'n how much horse i can squeeze outa them...most ppl will b very surprised with wut u can get outa a set of e7's wit stock valves. alot of aftermarket heads r based on production pieces...dats y i got into head porting to start wit. if u can, i would use a gt40 series head...better compression, larger valves...and pretty cheap..just my opinion.
Old 12-22-2007, 08:39 AM   #11
Ditto on thumper... but I sure as hell wouldn't use e7's... however i've personally seen his work with a set of GT40's on a 347, they flow better than my 185's
you ever seen his big block powered 68?
he hangs out on SBFtech.com, good site..
93 mustang notch
more 351 questions :S bloodyspirit058 1979-1995 Mustang GT 9 08-03-2009 05:02 PM
302 vs 351 . . . . 4thMustang Pre-2005 V6 Mustang 22 08-06-2008 07:15 AM
Combo Help:351 cajun04 1979-1995 Mustang GT 5 03-19-2007 09:53 AM
FS: BV Heads, 173's,Cam, and Stock Heads petrey10 Mustang Parts for Sale and Wanted 4 06-26-2006 11:15 PM
11:08 AM
