Newb with some questions.... - Mustang Evolution
Old 11-21-2006, 11:05 AM   #1
Send a message via Yahoo to CreativeCustoms
I have a 1996 v6 mustang lets say completely stock that i rebuilt from a wreck. I got a 302 for it with bad heads. So here is my question, well a couple really. What kind of heads should i look for? And does anyone know the parts that i need to change out to convert to the car to the 302? Thank s for any help i can get on this.
-CreativeCustoms
:wstupid:
1996 v6 3.8L --- soon to be a 302!
Help its Stock!
CreativeCustoms is offline   Reply With Quote
Old 11-21-2006, 11:08 AM   #2
Justin's Avatar
Send a message via AIM to Justin Send a message via Yahoo to Justin
Re: Newb with some questions....
I personally like Edlebrock heads.. Go to SummitRacing.com and look on there and see what u can get for your price and everything...
http://www.mustangevolution.com/forum/signatureuploads/sigpic5474_2.gif
(Project "TORQUE"):burnout:
Mods - Off Road H w/ Flowmaster 40s and 3" x 22" Tips, Shiftkit, Shorties, and 4.10s
Soon to come - UDPs, Off Road X-Pipe, A/T Cooler, and 03' Cobra Rims
Club - Tha Crew Leader of Muscle Car Division
Justin is offline   Reply With Quote
Old 11-21-2006, 11:34 AM   #3
bluemustang's Avatar
i have no clue if hes still around on the v6 boards but look for a board member called StylinV6 he swapped over to a 302 and such, as for heads first figure out what type of intake your gonna also want cause just doing heads wont be worth all that work
Old 11-21-2006, 04:32 PM   #4
Send a message via Yahoo to xtremben
cheapest route would be to find an explorer 302 from say 96-2000 and use the heads, intake and possibly nearly the whole engine. I have a Explorer long block in my 91 and it runs great.You'll have to change out the front assoceries, and oil pan/pickup/oil pump, but its basically straight forward and someone here should be able to help, if not PM me and I will.
good luck
Ben
xtremben is offline   Reply With Quote
Old 11-21-2006, 05:15 PM   #5
silverstangboy's Avatar
its alot of trouble, if your doing it as a novice and am interested in learning I say "THE BEST OF LUCK TO YOU!" not because you'll need it but because I think it'll be an excellent learning experience.
however if you just want some V8 POW in your pants, its much cheaper and easier to sell your car and buy V8, even if someone is giving some of the parts to do it with.
93 mustang notch
~450hp 331 stroker - Sold
Old 11-22-2006, 07:24 AM   #6
yea you have no idea what all it takes until you get into it and realize it wasnt as easy as it seemed lol. Before I did anything I would establish a budget and determine what you can / cant do. Also realize that you WILL run into issues so you will need side money for that as well. Finally, realize that if you half *** things or take short cuts they will come back to bite you in the butt.
Old 12-28-2006, 07:28 PM   #7
I had the 302 tanked, bored 30 over, crank turned, basicly an overhaul. I got new heads, crank(turned .010), pistons, cam (288 @ 460), just stuff like that. I had to get a bellhousing, flywheel. I am now in need to know if i can use my wireing harness if i am putting a 2 barrel carborator on it. But for the computer should i get one from a 5.0 or can i use a GT or can i just use my computer and get a programmer that will have a setting so it will fire all 8 cylinders...? if anyone can help me out with these questions or an suggestions it would be appreciated. I am new at this but the motor was free and the mustang cost me about 1500 bucks. So the cost is actually cheaper then buying a GT. Thank you for your help.
-CreativeCustoms
:wstupid:
Help its Stock!
Old 12-29-2006, 07:57 AM   #8
If you are going through all that work I would get the EFI conversion kit from SUMMIT racing. It comes with the harness the computer and the mass air meter that you will need.
trickflow5 is offline   Reply With Quote
Old 12-29-2006, 09:13 AM   #9
bbunt302's Avatar
I agree 100%, especially if this is a daily driver.
Scary stuff.
Old 12-29-2006, 12:44 PM   #10
+1 as B said esp if its your daily
Old 12-29-2006, 06:44 PM   #11
What if i carberate it?? or is it just smarter to go ahead and get the EFI conversion kit? ad after the block work and upgrades to it you all have a guess on rwhp it will put out?
-CreativeCustoms
:wstupid:
Help its Stock!
Yet another Newb! sly5.0 New Member Introductions & Greetings 14 06-04-2008 05:48 AM
Newb! Stang_B!tch New Member Introductions & Greetings 35 03-08-2007 09:22 AM
Oil changing questions. For a mod newb saleen0027 1996-2004 Mustang GT 22 07-15-2005 04:56 PM
Some Newb Questions about Stock 3.8L Ibanezplayer272 Pre-2005 V6 Mustang 7 06-26-2004 08:35 PM
Supercharger Newb Questions... Russ Pre-2005 V6 Mustang 11 05-25-2004 08:54 PM
09:42 PM
