power window not working - Mustang Evolution
Old 07-02-2010, 08:35 AM   #1
just bought a 93 mustang, test drove it everything work fine,got home and the driver's side power window and lock didn't work, cant figure it out, checked all the fuse's there fine, right before i drove it home the guy i bought it from cut the wire's to remove the stereo, does any one have any idears?
rob913 is offline   Reply With Quote
Old 07-02-2010, 12:49 PM   #2
Re: power window not working
get a power tester (little screw driver looking thing thats pointed and has a wire on the back that grounds out) and see if it lights up on the wires if it does you know power is getting to the switch, if it doesnt then its a wiring problem. You can test the wire for when you push the button the wire that tells the motor to turn on will get power as well.
Old 07-03-2010, 07:49 AM   #3
just picked one up, i'm going to check it out today, thanks for the help
Old 07-03-2010, 11:21 AM   #4
Tape's Avatar
open the door and while holding the button for the window shut the door, if it starts working it probably a loose wire
Tape is offline   Reply With Quote
Old 07-17-2010, 10:00 PM   #5
91sleeper's Avatar
correct term is a test light hehe.
331stroked vortech 16psi
91sleeper is offline   Reply With Quote
Old 08-21-2010, 11:28 AM   #6
in my experience just bring it into a shop if they fix it in like 3 mins they wont charge u more then 20 bucks. Id rather spend my time doing something else
wizud222 is offline   Reply With Quote
Power Window Leonard 1996-2004 Mustang GT 3 09-03-2009 08:07 AM
Power window streaking hollywoodgun Pre-2005 V6 Mustang 2 02-17-2009 03:20 PM
rear window defrost not working Cobra GT 1996-2004 Mustang GT 3 12-16-2008 05:26 PM
Passenger Side Power Window Not Working louie7600 General Mustang Discussion 1 07-27-2008 07:36 PM
Working on a high power system but need insight....HELP A MAN OUT PLEASE?!!!! BlueThunder Mustang Audio & Video 1 10-15-2004 10:36 PM
11:05 PM
