question for the pros here - Mustang Evolution
Old 12-27-2006, 09:51 PM   #1
Exclamation question for the pros here
I have a 93 gt 5 speed 5.0 ok now the mods it has a trickflow intake edelbrock 70mm throttle body C&L meter and tube 24lb injectors adj. fuel pressure regulator bbk pullies bbk long tube headers off road h pipe no cats flowmasters roller rockers. Now my question is the check engine light keeps on flashing off and on doesnt come on coasting or idleing or changing gears. My temp stays around 150-160 oh yeah it has a aftermarket radiator too and the oil temp is on the like the 2nd or 3rd mark from the top idles fine
ID:	15616   Click image for larger version
cowboy72 is offline   Reply With Quote
Old 12-27-2006, 09:55 PM   #2
bbunt302's Avatar
Re: question for the pros here
Go to your local parts store and have them pull the codes. It's free at most places, and it will give us a much better idea of what's going on.
BTW, that's a nice, clean fox you have there.
Scary stuff.
Old 12-27-2006, 09:57 PM   #3
yeah but when its idleing the light is not on will it still give a code ????
oh thanks just bought it about a month ago it only has 61,559 original miles too next is the wheels
Old 12-28-2006, 01:05 AM   #4
x2.
Yes.
JROC is offline   Reply With Quote
Old 12-28-2006, 10:28 AM   #5
Scut95's Avatar
Do the parts stores in your area do OBD I checks? Around here they only do OBD II for you which sucks.
Old 12-28-2006, 10:36 AM   #6
nope I think all they do is II
Old 12-28-2006, 02:09 PM   #7
bluemustang's Avatar
personally my car always threw codes for whatever stupid reason i went and spent like 35 bucks on a Ford Reader let me see if i can find the link. Its one of the better investments i made honestly
Old 12-28-2006, 02:15 PM   #8
here is what i bought, never have to worry bout running to Autozone or whatever
EQUUS DIGITAL FORD CODE READER (3145)
Old 12-28-2006, 06:03 PM   #9
but if the light is flashing off and on will it still read the code if the light is off? It doesnt do it unless your are driving down the road
Old 12-29-2006, 12:45 PM   #10
if theres any code being thrown it should be able to catch it
Old 01-05-2007, 04:46 PM   #11
well I got the code reader and not to be dumb or what But I looked for the place to plug it in and I cant find it anyone know where it is
Old 01-05-2007, 06:01 PM   #12
Scut95's Avatar
OBD I is under the hood on the right (Passenger) rear of the engine bay, towards the firewall. It should have some kind of cover on the connector to protect it from the elements.
Old 01-05-2007, 06:15 PM   #13
i looked for it but couldnt find it it got dark on me I will check tommorrow thanks so your saying its in the corner near the wiper motor?
Old 01-05-2007, 07:27 PM   #14
MonteCitan's Avatar
yeah, on the drivers side, near the strut tower
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 01-05-2007, 08:55 PM   #15
i did see a cover that went over the positive battery cable but I didnt remove the cover thats probably it
thanks guys big help
Old 01-06-2007, 04:26 PM   #16
Scut95's Avatar
Foxes are different than 94-95 models. The connector in my car is on the passenger side.
Old 01-07-2007, 11:49 AM   #17
on an 89 its on the passenger side
trickflow5 is offline   Reply With Quote
Old 01-08-2007, 02:53 PM   #18
when i went to check mine it still had the cover over the connection just take it off and pull her in
i have an 89 and it was on the drivers side, next to the strut tower
Old 01-08-2007, 02:58 PM   #19
well i found it its in the corner of the drivers side and I got 4 or 5 different codes dont remember I will right them down and let you guys know them I have the book to let me know what the codes mean
Old 01-08-2007, 03:00 PM   #20
good ish, wasnt that reader a good investment esp that it comes wit a book that tells you the deal
Old 01-08-2007, 05:34 PM   #21
yeah now I just have to translate what they mean
Old 01-09-2007, 06:53 AM   #22
I'm sorry that was a different car I remembered reading from the passenger side wheel well. My mistake. Hope it didn't cost ya much time.
Old 01-09-2007, 07:32 AM   #23
10 minutes maybe its all cool any help is appreciated
the codes I got were 10,29,31,96 and after I started it I got 40 also
Old 01-09-2007, 01:23 PM   #24
what did the book say the codes were? im not at my house or id look them up in that book you got
Old 01-09-2007, 01:36 PM   #25
there are 2 for 29 insufficient input from vehicle speed sensor
and the same for speedomotor /odomotor module
31 evp or pfe circuit below minimum voltage
96 fuel pump secondary circuit fault/high speed fuel pump relay open
I didnt start the engine and let it run the cylinder check I will do that later
i have a question 93yellowgt 1979-1995 Mustang GT 8 06-07-2009 10:17 AM
BBunt302's Manual on the Pros/Cons of Using Proper Grammar on the Internet bbunt302 The Bar 15 04-13-2009 09:01 AM
old V6 question plstktnkr2 Pre-2005 V6 Mustang 11 03-24-2006 08:52 PM
1/4 question.... douGT General Mustang Discussion 7 02-09-2006 04:02 PM
Pros and cons NorwegianMustang Pre-2005 V6 Mustang 12 02-26-2005 11:53 AM
06:59 AM
