questions on heads - Mustang Evolution
Old 12-31-2006, 01:43 PM   #1
questions on heads
I have a 93 gt with the following mods trickflow intake edlebrock 70mm throttle body 73 mm c&l meter and tube 24lb injectors long tube headers off road h pipe bbk pullies. My questions are about the heads I just purchased a E303 cam and was wanting to know what the best heads are to purchase and if anything needs to be done to them before I install them
cowboy72 is offline   Reply With Quote
Old 12-31-2006, 07:22 PM   #2
silverstangboy's Avatar
Re: questions on heads
well... thats personal preference
with a 302 AFR or eldebrock are going to be the best options, trick flow seems to be a good head as well when the cubic inches start to go up, though in reality all these manufacturers are going to be very close to each other in performance... regardless of which head you buy, carefully match your springs to the camshaft and roller rockers that you're going to use, and reconsider using an E-303, unless your just wanting a cam that'll shake you to death there are much better options.
93 mustang notch
~450hp 331 stroker - Sold
Old 12-31-2006, 07:25 PM   #3
yeah I have already bought that cam the E-303 so I am looking at AFR 185 do I need to do anything special to them ported polished I dont know
Old 12-31-2006, 07:40 PM   #4
185's are large for a 302, I'd get 165's if this is a daily driver, all out track car turning 7,500+ RPMs 185's
93 mustang notch
Old 01-01-2007, 12:01 AM   #5
bbunt302's Avatar
Just get the AFR 165s, and you want have to touch them. They will bolt straight on.
However... I would recommend selling the E-303 cam and getting something with a split duration and decent ramp rates.
Scary stuff.
Old 01-03-2007, 10:07 AM   #6
91GTstroked's Avatar
I would also maybe consider the RHS heads whom use to be Pro-Topline, now part owned by comp cams, so they have all comp springs retainers, locks ect. They are a very reasonable price and flow just as well as the AFR. Actually the flow a bit better. Heres a link to there website, and also a link to my boys at HI-Tec Motorsport, ask for Bart or Brian they can recommend the right head and give you a great price!
Racing Head Service - RHS Performance Cylinder Heads - Home Page
HiTech Motorsport Inc
2003 REDFIRE SVT COBRA
455rwhp/480tq
91GTstroked is offline   Reply With Quote
Old 01-03-2007, 10:34 AM   #7
Trickflow heads were always my choice. I have had 2 sets now problem free. When I upgraded the motor in my 5.0 I used the trickflow stage one camshaft with the trickflow heads. After taking a little while to get everything properly tuned it seems this is a good setup. It has a nice sound at idle and the motor pulls through to 6400-6500 RPM. If i had to do it over though I would use the cobra FMS intake or the trickflow street intake. I used the track heat intake which is good from 1500 up and it makes you want step on it all the time. the other intake would have been a little more streetable.
trickflow5 is offline   Reply With Quote
Old 01-03-2007, 05:33 PM   #8
yeah, i've heard alot of talk about the RHS heads, seems to be getting more respect now that comp owns them.. perhaps an option I would take in the future, but I like to stick with the tried and true platforms.
I do remember a few people complaining about them back when they were pro-topline's about having to do alot of mach-up work to get them ready.
93 mustang notch
Old 01-03-2007, 09:36 PM   #9
so what cam would I need if i get rid of the e cam
another question is there a way I can tell what gears I have without taking the differential cover off the guy told me it had 3:73's but I swear if you dont have it in the right gear it jerks alot so I was wondering if it was higher
Old 01-03-2007, 11:59 PM   #10
yeah you can, jack up the back of the car and put it in netral, mark your tires and mark the driveshaft, if you believe you have 3.73's then turn the driveshaft 3 and 3/4's full turn and your wheels should have made one compete turn.
a camshaft profile is something that is hard to sugest, going custom will be the way to ensure you get the best profile for your goals, but if you want off the shelf parts I would suggest you contact a professional builder (wether its local or not) and let them know your goals for the car and they should be able to match you a good camshaft, usually most builders don't mind doing this so long as you intend on buying from them, and this is what I suggest, even if it ends up a little more than mail order... don't skimp on the camshaft, its the brains of your engine
oh and just so you know, if you decide to keep the E-303 it will work best with a head that has flow numbers that are very close to each other on the intake and exhaust, AFR 165's qualify here
93 mustang notch
Old 01-13-2007, 02:13 PM   #11
Titus Wadicus
svtlx's Avatar
hey, wut do u not like about the e-cam....i have one with ported stock heads, .560 valve springs, & aluminum 1.7 roller rockers..(i think pushes lift to .529)...anyway i think it freak'n rocks.....i just want your opinion, im always open to new schools of thought......i have a torque link installed, and u r right, itsa a lil un-nerving watching your moutain dew act like it's magicaly shake'n itself when the car is idleing....but im only 29 and valve overlap is still a pretty cool concept to me, besides for soft drinks prematurley getting flat, i think it's cool...i wanna hear your thoughts though.
Old 01-13-2007, 03:25 PM   #12
bbunt302's Avatar
The main things wrong with the E303 are the lack of split duration (which really helps on Ford heads with poor exhaust flow) and the slow ramp rates (the rate at which maximum lift is reached which affects optimization of cylinder pressure).
Check out this site if you want to learn more about cams: Cam Truth
Scary stuff.
Old 01-14-2007, 09:27 AM   #13
Titus Wadicus
svtlx's Avatar
i read the article...i understand about 48% of it...lol...anyway, i really don't want all dat torque down low cause i cant really use it. i am doing some more work to the runners and some work to the bowls...im try'n to git rid of some of the low rpm torque in order gain grip, my stall is only 2500rpm....i cant get grip without more than a half tank of fuel.....the e-cam is very predictable when the power band kiks in...(feels like a turbo spooling up)...i want the power at 3k and up. wut do u think about split ratio rockers?....im run'n 1.7 aluminum rollers on intake and exhaust, i have sum 1.65 stamped roller tips i considered putting on the intakes, and leaving the 1.7 on the exhaust.....wut do u think? off subject...i am so surprised at the results i have gotten from ported stock heads.....my friends r so mad when i spank their *** cause they got those $2500 top end kits and git whooped (or cant shake me) by stock heads wit e-cam....im addicted to highway race'n ever since the porche couldnt shake me @130mph (the one wit the wing dat goes up when da car goes faster)......i'll take any advice you have cause im still pretty new to this
Old 01-17-2007, 08:40 AM   #14
Your friends cars aren't running right.
Old 01-17-2007, 09:19 AM   #15
Titus Wadicus
svtlx's Avatar
i think they're cars r improperly tuned......run'n trick flow head and intake wit 19lbs. injectors.......i have ported e7te's and run 24#inj, adj fuel pressure reg, adj. tps., 3.73 gears.....most of these guys r run'n 3.55 gears or less.......i agree, i shoulda got my *** waxed....a 4.6 stang wit 4.10 gears and cam (big cam) will work me...(not hard though)......stock 4.6 stangs get walked on though.....when i get my motor reassembled i will give yall a quarter mi. time and dyno....i think when the car was run'n, i guesstimate 300-320 @ the crank.....i set up my motor as close as i could to jegs crate motor minus the gt-40 heads.....hoping that the porting and 1.7 rockers will make up for the valve size and the compression differance from the gt-40......im doin sum bowl work to the heads, i'm try'n to get rid of sum of the bottom end torque and trade for top end power....it chirps tires up to 3rd gear wit stock converter and valve body, it is very scary if it is wet outside....the car has tendacy to get sideways when getting on highway if wet....i have new trac lok...hopefuly it will fix dat....im always open to yalls suggestions and opinions. my public profile has my set-up if anyone interested
Old 01-17-2007, 02:52 PM   #16
bullitt482's Avatar
Agreed. I have the Trick flow top end kit, long tubes, 24 lb injectors(can't figure out why svtlx needs 24 pounders) 190 lph pump, pullies, 70 mm throttle body, and have beaten an 03-04 cobra with full exhaust from 60-100. Granted not a real race, but from a stop would have been worse since we got the new meats for the back. I'd say 300ish whp here and hopefully have lots more after an upcoming tune.
01 Bullitt
Old 01-17-2007, 06:30 PM   #17
the trick flow kit should be good to 300-325 RWHP... which is realistically the best you can do with a street driven 302 provided your not reving it to the moon. and what I mean is Congrats!, sounds like you have a bad *** car
I also wanted to add that that was an excellent find Bbunt, I read that whole article a few times over and it really shed some light to a few things i've been bouncing around in my head lately.
93 mustang notch
Old 01-18-2007, 07:31 AM   #18
Titus Wadicus
svtlx's Avatar
i have 70mm throttle body, typhoon intake.......runners on my e7's r portmatched..intake & exhaust....my intake ports r chevy size and my exhaust r larger than chevy (runners), valves are stock, but i run 1.7 rockers not 1.6 ....w/ 19# injectors i have to run almost 60lbs of fuel....ran awsome on top end but injectors had too much fuel pressure on them and wouldn,t cycle correctly....21lbs inj. would work but i got 24lbs for $3 a piece @ junk yard. i can run closer to stock fuel pressure now wit slightly better gas milage...i was get'n 11mpg. on highway.....i know u guys don't belive me but to stomp into at highway speeds, it has unbelivable acceleration for e7's.........seriously though, the car will not idle wit stock fuel pressure wit the 1.7 rockers....it will idle but not rev wit the 1.65 rockers...dunno bout the 1.6 cause i got rid of them 2 yrs. ago......out of all the mods i have done...move'n to 1.7 rockers was a differance i could feel.....sum of the best money i spent.....that and port match'n my heads....i have dyno books that say u can get 40-45hp (over stock) out of ported e7's...i can scan and email to anyone who wants to see it....i followed the instructions to a "t", and got rewarded wit sum great heads.....i traded velocity for volume, but in my case it does exactly wut i want. i do highway racing from rolling starts and dont need all the low end torque.
Old 01-18-2007, 08:16 AM   #19
That's awesome. Imagine how it would run with a set of good heads ported and polished. The valve size would make an incredible difference. Be careful with that highway racing. Don't wanna hear about a good mustang ending up all smashed.
Old 01-18-2007, 08:45 AM   #20
Titus Wadicus
svtlx's Avatar
im ex law enforcement.....i went through alota high speed and offensive driving classes. i hang out wit bout 40 guys dat race on weekends on highway we usualy run between 2a.m till 4:30 .....the oshp give us a 8mi. strip were they look the other way....or they herd us to a country rd. where they block off the street for us....it's easier for them to put us in one area than to let us run around the city cause'n trouble at 3a.m.......we r actualy well supervised...it helps when sum of the cops have stangs ....we have sumthing to do and the 3rd shift guys (cops) have sumthing to do.........besides, i got 4cyl. brakes still, and i need plenty of room to stop. therfore i don't do light to light racing....i always remember that there is a time and place for it......
Old 01-18-2007, 09:07 AM   #21
Titus Wadicus
svtlx's Avatar
as far as good heads, im on a budget, dats y i ported the e7's. all the mods u see in my profile took me close to 3.5yrs. to aquire. im self employed now and squiez'n out $200 is a challenge for me....i made alota sacrifices to get my s/c.....it's gonna take me the next 5 months to get the money to punch my block and turn the crank..(hope not). besides, like i said earlier. i luv to see the look on their faces when they see the stock heads....then i say, how's it feel to get walked on by a junk yard motor!...(i don't tell them that the heads r worked)....of course i rub it in more by saying that they got more in their heads than i got in my whole motor......itsa matter of pride cause i did the work myself, now people r ask'n me to their e7's.
Old 01-18-2007, 03:46 PM   #22
bullitt482's Avatar
Some of your idling issue could be solved with a tune, which is exactly where we are headed as soon as taxes get back.
01 Bullitt
Old 01-18-2007, 05:23 PM   #23
I just had mine dyno and tuned for 120.00 bux but it seems to me that I would need a custom chip for it with all the other stuff I have on it
Old 01-28-2007, 04:27 PM   #24
well guys I have decided to put the stang on the market for a fullsize truck prefer 4 door and loaded will consider lifted and ext. cab
how can i tell if i have PI heads or not? redbird2289 1996-2004 Mustang GT 4 08-26-2009 08:56 PM
Heads upton7 Mustang Parts for Sale and Wanted 0 08-11-2009 10:51 PM
Which heads? upton7 1996-2004 Mustang GT 4 07-30-2009 11:14 PM
PI heads jk7208 1996-2004 Mustang GT 3 07-07-2009 07:04 PM
FS: BV Heads, 173's,Cam, and Stock Heads petrey10 Mustang Parts for Sale and Wanted 4 06-26-2006 11:15 PM
10:45 AM
