Wasup? - Mustang Evolution
Old 01-14-2007, 09:10 PM   #1
Wasup?
Hey this is my first postand i have a probly common question but not sure. i have underdrive pulley and will that prevent the car from getting a full charge to the battery?...
TripleBlack is offline   Reply With Quote
Old 01-15-2007, 07:37 AM   #2
rocknbronco's Avatar
Re: Wasup?
No it shouldnt affect it at all go down to Auto Zone or Advanced whom ever screws up the least and get the batt and Alt tested.
rocknbronco is offline   Reply With Quote
Old 01-15-2007, 10:06 AM   #3
Titus Wadicus
svtlx's Avatar
Re: Wasup?
It Shouldn't Affect It, But Some People Do Have Dat Problem...the Under Drive Kits That R Out Today R Supposed To Be Better Than Those Of 5-7 Years Ago...however, I Think It Also Depends On How Much Electricity Your Car Demands....if U Got A Big Stereo And Ignition (i.e. Msd Box & Coil) System U May Wanna Stay Away From A Pulley Kit, Or Upgrade To A Larger Alternater, Or U May Just Need A Fresher Stock Alternator......i Retro Fitted A 130 Amp From 95 Stang & Put A 4cyl. Pulley On It....cause My Stock 75amp Wouldnt Charge At Idle Cause Of Ignition Sytem...now Makes 13 Amps & 550 Rpm....anyway U Shouldnt Have A Problem Wit A Mostly Stock Car
Old 01-15-2007, 10:30 AM   #4
Re: Wasup?
thanks guys that will easemy mind a little
Old 01-19-2007, 08:48 PM   #5
silverstangboy's Avatar
Re: Wasup?
honestly if you have a newer car with a 130G altenator you should be fine...
but also, by that same honesty underdrive pullies are a waste of time the amount of power gained vrs the cost is about as negotiable as putting on a cold air kit.
93 mustang notch
~450hp 331 stroker - Sold
Old 01-20-2007, 07:44 AM   #6
Titus Wadicus
svtlx's Avatar
Re: Wasup?
Originally Posted by silverstangboy View Post
honestly if you have a never car with a 130G altenator you should be fine...
yea, i wasn't going to say nuthin but your right......i figured if he wants a pulley set who am i to judge.
Old 01-20-2007, 12:01 PM   #7
Re: Wasup?
the pulley's and cold air both were are the car when i bought it....but i probly would have put them on anyways
Old 01-21-2007, 07:31 AM   #8
Titus Wadicus
svtlx's Avatar
Re: Wasup?
I won't put none on my car cause i got a 5.0...but the anodized ones do look sweet...like blue....or red....or sea foam....or....
Old 01-21-2007, 10:54 AM   #9
Re: Wasup?
I say any power gain or loss of parasitic drag is a good thing while they are not the biggest bringers of power I would recomend using them.
Old 01-21-2007, 12:04 PM   #10
Titus Wadicus
svtlx's Avatar
Re: Wasup?
i removed a/c and smog pump...dat's as close to a pulley set i'll ever own..lol
Old 01-28-2007, 09:50 PM   #11
Zim
You want to **** me?
Zim's Avatar
Re: Wasup?
What does having a 5.0 have anything to do with it? I have a 5.0 and I have them on my car.
I like toys
Old 01-29-2007, 07:25 AM   #12
Titus Wadicus
svtlx's Avatar
Re: Wasup?
with my stock alternator i had chrging problems @ idle...i think stock is only 75 amp for my generation stang....i already got rid of smog pump and a/c....i finaly retrofited a 95 stang alt. (130 amp) and used a 4 cyl. alt. pulley. i suppose i could use a a underdrive pully set now if i wanted.....i personaly don't recommend using an underdrive set with a stock 75amp alternator....i guesse it all comes down to me being cheap...wit the smog pump and a/c gone, i feel that it negates the need for an underdrive set.....the amount of power u gain from a pulley set verses the cost....i consider them more cosmetic than a power adder....this is only my opinion ...but wit a 9psi supercharger. e-cam, 1.7 r.r. arms, ported heads, bunch of other crap....a pulley set aint gonna make me or break me...waste of money for cost verses performance...but evryone's application is differnt...and again, it's only my opinion.
Old 01-29-2007, 10:04 AM   #13
Zim
Zim's Avatar
Re: Wasup?
Ah well if you're supercharged I understand not using them, as it would decrease your boost.
I like toys
Old 01-30-2007, 05:46 AM   #14
Titus Wadicus
svtlx's Avatar
Re: Wasup?
off subject....but r u run'n e7te (stock) heads?.....if u r, did u port them yourself.....if u did, wut areas did u port and so on...
Old 01-30-2007, 08:09 AM   #15
MonteCitan's Avatar
Re: Wasup?
stock cobra heads are GT 40s
I have 93 cobra heads on the 92.. they're fully ported/ oversized valves/etc
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Wasup everybody! savedbygrace New Member Introductions & Greetings 9 01-06-2009 05:59 AM
10:38 AM
