Gears are in whats next? - Mustang Evolution
Old 01-22-2007, 10:07 AM   #1
Justin's Avatar
Send a message via AIM to Justin Send a message via Yahoo to Justin
Ok have 4.10s in and speed calib on the way.. What can i do to get a little bit of my top end power back. Tuner or a chip of some sort? If you would leave me some suggestions. Thanks
http://www.mustangevolution.com/forum/signatureuploads/sigpic5474_2.gif
(Project "TORQUE"):burnout:
Mods - Off Road H w/ Flowmaster 40s and 3" x 22" Tips, Shiftkit, Shorties, and 4.10s
Soon to come - UDPs, Off Road X-Pipe, A/T Cooler, and 03' Cobra Rims
Club - Tha Crew Leader of Muscle Car Division
Justin is offline   Reply With Quote
Old 01-22-2007, 11:47 AM   #2
Re: Gears are in whats next?
Heads/Cam/Intake
Old 01-22-2007, 11:58 AM   #3
Justin's Avatar
i thought about that but there is a 302 w/ 4 barrels and 93 gt heads that is for sale for 1k through a friend.. just put together... should i get it or no...what exacally do the 4 barrels do?
Old 01-22-2007, 12:07 PM   #4
Herbstang's Avatar
That would be your carburetor You know the little thing on the top of the intake that suppiles fuel to the motor
Old 01-22-2007, 12:19 PM   #5
Justin's Avatar
I know that much.... im just not sure what 4 barrel means.... i hear it i just dont understand it... i never been arond or worked on a carb. engine... always fule injected... so bein it a carb. engine i prolly wanna stay away from it huh?
Old 01-22-2007, 12:36 PM   #6
Herbstang's Avatar
OK I was just F*ckin with ya .4 barell has 2 primary and two secondary. nomal driving your just using the front 2 barrell ,when you go WOT the 2nd 2 kickin and you get kicked back in the seat and enjoy the sound of a carb
Last 4 barrel I used had 1 1/4 primary and 2 1/2 secondary
Old 01-22-2007, 12:39 PM   #7
Justin's Avatar
should i buy it to put in a 95 gt?
Old 01-22-2007, 12:43 PM   #8
bluemustang's Avatar
honestly if you dont understand dont get that motor seriously carbs you always have to be ****ing with and after awhile it will get annoying.
Just save your money up and get a DSS short block or even a full crate motor if you really want a nice motor. just dont buy the first thing you think its a good deal. with foxes you really gotta plan this out and not just throw mods at you know.
i asked you this before but what do you want to accomplish with this car whether it be a street warrior or a weekend warrior what
personally id just save up for a h/c/i or a short block or work on your suspension, just figure out what end you wanna do first cause now things are gonna start to get expensive (unless you go over at corral and look around you'll find deals on parts trust thats how i bought my s/c setup)
Old 01-22-2007, 03:09 PM   #9
dont go carbed
Old 01-22-2007, 03:26 PM   #10
Taywi's Avatar
Send a message via AIM to Taywi
dont go carbed
x2... i've only got a 2barrel on my small v6 and i still get ****ty gas mileage
from old and busted to new hotness
Taywi is offline   Reply With Quote
Old 01-22-2007, 07:42 PM   #11
Thomas91169's Avatar
i dont think he could even go carb'd unless its a "Carb" but really has a fuel injector in it and was controlled by the ecu or a aftermarket unit, instead of the standard vacuum that pulls the fuel out of the resevoir or however they work. your ecu will try to control injectors when there are none, and your fuel pump setup is made for fuel injection, not for a mechanical style carburetor.
i would go with what spec said, the best way to gain up top is by getting heads/cam/intakes that can move the kind of air your engine needs at those rpm's. get yourself some GT40 heads, a good cam and upper/lower intake combo whatever and itll be very nice!
-Thomas-
Old 01-22-2007, 07:49 PM   #12
bbunt302's Avatar
It would take a little bit of work, but thousand upon thousands of people have put carbed engines in fox bodies. There's not that much to it.
Doesn't mean it's a good idea though. FI all the way.
Scary stuff.
Old 01-23-2007, 06:55 PM   #13
yea FI is alot more accurate too.
96 GT- Who knows what's in it.
NEED HELP WITH GEARS!! Motive 4.10 gears? Cant find ford racing? Camaro Eater Pre-2005 V6 Mustang 4 06-23-2010 11:57 AM
Whats Up Whats Up From Georgia ShesmuRa New Member Introductions & Greetings 6 11-02-2009 03:23 PM
Whats a good brand for gears..... douGT 1996-2004 Mustang GT 11 03-29-2005 06:49 PM
whats the better rpm curve?/whats a good car choice? Thomas91169 The Bar 7 12-05-2003 11:24 PM
Factory Gears Vs. Racing Gears tire Pre-2005 V6 Mustang 0 07-21-2003 05:02 AM
10:37 PM
