Please help need to know what stall converter to get for the twinturbo?!?!?!?!?!?! - Mustang Evolution
Old 08-08-2010, 10:08 PM   #1
turbofox's Avatar
Send a message via AIM to turbofox Send a message via Yahoo to turbofox
OK I AM CHANGING MY T5 TO A C4. GOT A LOT OF PEOPLE TELLING ME DIFFRENT STUFF. NOT SURE.RUNNIN WHAT KIND OF SPECS DOES FACTOR?
NEED TO KNOW PLEASE HELP... AND THANK YOU FOR YOUR TIME!!!!!!:tongue:
not a track car but im ganna take every once in a while
turbofox is offline   Reply With Quote
Old 08-09-2010, 07:05 AM   #2
hottcobra's Avatar
Re: Please help need to know what stall converter to get for the twinturbo?!?!?!?!?!?
Need to know BHP rear end gear and if the trans locks the converter or not.
The taller the rear gear the higher stall you can run, but you are limited by how much hp. Cause the higher the hp the lower the stall has to be.
As for the lockup. If a C4 is I non lockup trans you don't want your stall to be higher than your interstate cruising RPM or the converter will be slipping all the time and cause you to overheat and kill your trans.
Old 08-09-2010, 07:12 AM   #3
turbofox's Avatar
cool thanks
i have 355's in the rear and the trans is a nonlockup i think.i have a 2200 but im bein told if i put that in it im gana be dissapionted
Old 08-09-2010, 08:23 AM   #4
hottcobra's Avatar
I would say 2,500 stall is what your gonna need. Anything higher than that and the hp your pushing is gonna blow past the converter and cause you to slip the converter( just like a clutch slipping and making you hit the high rev on a hard take off)
Ran the twinturbo for the first time turbofox General Mustang Discussion 8 07-22-2010 12:24 PM
What programmer/stall? 01 PR RAGTOP 1996-2004 Mustang GT 3 07-18-2008 11:15 AM
stall converter???? stang_gang Classic Mustangs 6 05-01-2008 05:18 AM
stall converter Kyle Pre-2005 V6 Mustang 5 12-15-2006 05:50 PM
300 stall? midnightmustang Pre-2005 V6 Mustang 9 05-16-2005 10:12 PM
12:05 PM
