Why Bent Exhaust Valves? - Mustang Evolution
Old 02-01-2007, 11:17 AM   #1
jwyche's Avatar
Got a call from my engine builder today saying that all eight of the exhaust valves in my Edelbrock Performer heads were bent. At least they were so wobbly on the valve machine that repairing them was questionable on a performance engine. Intake valves, seats, guides were all good.
So, why bent exhaust valves? Could it be that the exhaust is closer to the piston top? Could they have kissed the piston tops? (Interestingly, neither the valves nor the piston tops are marked from collision.)
The rev limiter is off via the Diablo Three-Way chip. Although I try to shift the car at 5800 (E303/1.7 Crane Rockers) I've missed more than one shift and seen it zing up to about 7,000...but with no load.
If you've had any experience with this, or read about it, I'd like to hear so I can avoid it the next time.
Jim
Jim Wyche:Senior Citizen. 1992 Mustang GT with a few mods. See webpage http://web.mac.com/jwyche or my garage. 2002 Mustang GT with a few mods. Collegedale, Tennessee.
jwyche is offline   Reply With Quote
Old 02-01-2007, 11:32 AM   #2
Re: Why Bent Exhaust Valves?
edelbrock is junk no JK sounds like an over rev. it could possible be that you have to much lift with the e303 and the 1.7's you might want to drop back down to the 1.6's.
trickflow5 is offline   Reply With Quote
Old 02-01-2007, 08:15 PM   #3
rydog's Avatar
Send a message via MSN to rydog
He should be fine with th e303 and the 1.7's if its a stock bottom end. I have only seen fly cutting of the piston for clearence for the x303 and up.I dont think the valves hit the piston there would def be marks. My timing chain broke once and I bent a couple of valves and you could clearly tell
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 02-04-2007, 12:45 AM   #4
Exhaust valves are subjected to more heat in an open state than intake valves, warping will occur. This doesn't sound so much like they actually got bent, just warped from the constant heat change.
Not really an uncommon thing, valves are generally tossed on race motors.
sportsoutlaw is offline   Reply With Quote
Old 02-04-2007, 01:17 PM   #5
jwyche's Avatar
Thanks! That makes sense to me.
Jim
Old 03-17-2007, 08:59 AM   #6
Titus Wadicus
svtlx's Avatar
ok, im late on this thread, but anyone that knows me knows i cant keep my mouth shut. dude i got the same set up except with stock e7 heads, no valve reliefs in the pistons though..true flat tops....stock bottom...i had something real similar happen to me. my valves got into the pistons and made its' own reliefs. my buddy said it was cause my motor got hot, and bout three rod bearings gave way in the process. i still have factory rev of 6250 on my car, so i don't think itsa high rev issue....mine popped at 5800 in third gear at 116mph...i shift into 4th at 120mph but it didnt make it that far cause i had a leaky heater core, and it got hot..and well u know. unlike u my valves were fine. wut happend to you is as puzzling as wut happend to me....dont think i was any help here, but when u find out wut happend let me know.
exhaust
valves upton7 1996-2004 Mustang GT 3 11-24-2009 12:39 PM
Questions about pcv valves zack1134 1996-2004 Mustang GT 1 02-20-2009 03:20 PM
WTB 1.89/1.59 SS valves for 4 cylinder 2.3 Ford RGR Mustang Parts for Sale and Wanted 0 06-19-2006 09:45 PM
IAC Valves 97Stallion Pre-2005 V6 Mustang 4 08-30-2004 12:35 PM
Valve springs and stock valves Tbird232ci 1979-1995 Mustang GT 17 04-26-2004 03:03 PM
11:22 PM
