estimated horse power - Mustang Evolution
Old 02-02-2007, 07:13 AM   #1
i am new to this forum so i will tell you what i have so far, its a 1986 mercury capri, it hase the following done to it
- a cold air kit
- an adjustable fuel pressure regulator
- aluminum drive shaft
- center force clutch
- hurst short shifter
- underdrive pulleys
- 3.55 gears
i plan on doing some work around april i was just wondering if you could estimate my horsepower i am adding the following
- a motor out of a 95 mustang w/ GT-40p heads
- making the car mass air w/ a 70mm mass air meter
- 30 lbs injectors
- 1.6 rockers
- subframe connectors
- rear upper and lower control arms
- bigger fuel pump
iam hoping to run mid to low 13s how much hp do you think i will get
fast86capri is offline   Reply With Quote
Old 02-02-2007, 07:56 AM   #2
Re: estimated horse power
with the mods listed I would say you are 8-14hp and 7-12tq over stock
Old 02-02-2007, 04:24 PM   #3
bullitt482's Avatar
I wouldn't recommend the 30 pounders unless you were spraying or going with a stroker kit with big heads.... 24's are plenty.
01 Bullitt
Old 02-05-2007, 08:51 PM   #4
silverstangboy's Avatar
the stock 19's will be enough for your combo
24's would be enough for my 331 with portmatched AFR's, im doing 30's for some lead way..... (and im running a .600 lift cam as well)
93 mustang notch
~450hp 331 stroker - Sold
Old 02-05-2007, 09:26 PM   #5
MonteCitan's Avatar
I have a 331 (see link in signature...) I run up to 6300-6400 RPMs and I still have plenty of fuel left with the mere 24s..
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
300 NA horse power a myth? 67mustang97 1996-2004 Mustang GT 51 06-15-2010 08:54 AM
V6 Loss of horse power wyatt-00' Pre-2005 V6 Mustang 19 01-27-2010 09:29 AM
How much horse power do you have? lthlsnake The Bar 48 05-16-2006 01:08 PM
Estimated Numbers Justin 1979-1995 Mustang GT 7 05-10-2006 04:46 PM
how much horse power mtchll50 1996-2004 Mustang GT 14 07-09-2004 12:09 AM
01:04 PM
