Cam a stock 5.0 - Mustang Evolution
Old 02-05-2007, 08:16 AM   #1
Justin's Avatar
Send a message via AIM to Justin Send a message via Yahoo to Justin
Cam a stock 5.0
Ok I want to cam my 5.0... Which cam should I get and why?
Im cam stupid so some explainin on how cams work would be greatly appriciated.
http://www.mustangevolution.com/forum/signatureuploads/sigpic5474_2.gif
(Project "TORQUE"):burnout:
Mods - Off Road H w/ Flowmaster 40s and 3" x 22" Tips, Shiftkit, Shorties, and 4.10s
Soon to come - UDPs, Off Road X-Pipe, A/T Cooler, and 03' Cobra Rims
Club - Tha Crew Leader of Muscle Car Division
Justin is offline   Reply With Quote
Old 02-05-2007, 09:06 AM   #2
Herbstang's Avatar
Re: Cam a stock 5.0
I'm also a member of the cam stupid club this might help some Howstuffworks "How Camshafts Work" or contact Delk Performance
Old 02-05-2007, 09:12 AM   #3
Re: Cam a stock 5.0
That was an interesting read.
Old 02-05-2007, 09:17 AM   #4
Justin's Avatar
Re: Cam a stock 5.0
Ok well I am cam retarted because i only understood a lil bit of that shuff... Im at work to so i was readin fast
Old 02-05-2007, 09:21 AM   #5
Justin's Avatar
Re: Cam a stock 5.0
Im lookin to pic up some power in the higher rpms.
Old 02-05-2007, 09:31 AM   #6
Zim
You want to **** me?
Zim's Avatar
Re: Cam a stock 5.0
if you do a cam, do a head and intake swap at the same time... just a cam wont you net you much power since your heads wont flow much anyway
I like toys
Old 02-05-2007, 09:39 AM   #7
Justin's Avatar
Re: Cam a stock 5.0
If i didnt do a head and intake swap..What would just a cam get me?
Old 02-05-2007, 10:02 AM   #8
Zim
Zim's Avatar
Re: Cam a stock 5.0
depends on the cam, but probably 30hp or so..
I like toys
Old 02-05-2007, 10:12 AM   #9
Justin's Avatar
Re: Cam a stock 5.0
i want to do that upper lower typhoon intake and a c-6 tanny....anyone ever heard anything on the typhoon intakes?
Old 02-05-2007, 11:00 AM   #10
Herbstang's Avatar
Re: Cam a stock 5.0
Bout all I know is the the typhoon upper is similar to RPM upper intakes and people seems to like'em ,try 50resto - America's #1 Ford Mustang Parts Source, they have the cheapest prices I've come across
Old 02-05-2007, 11:02 AM   #11
MonteCitan's Avatar
Re: Cam a stock 5.0
If he DIDN'T do heads/intake?
No where's near 30 HP
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 02-05-2007, 11:30 AM   #12
Justin's Avatar
Re: Cam a stock 5.0
i found them cheaper on blueovalendustries...how much you think monte?
Old 02-05-2007, 11:33 AM   #13
MonteCitan's Avatar
Re: Cam a stock 5.0
Chances are, the cam you get will simply bump the HP and torque curve up in the RPM range a bit, torque will be about the same, + or - 5 ft lbs, HP, due to slightly better efficiency at a higher RPM, you might see 10 HP or so (that's if you do nothing else...) Just my $.02...
Old 02-05-2007, 11:35 AM   #14
Re: Cam a stock 5.0
That is the initial goal that he has. Since the 4.10's, he has lost top end power. He is trying to regain that.
Old 02-05-2007, 11:37 AM   #15
Justin's Avatar
Re: Cam a stock 5.0
well i am lookin to gain some power back in the higher rpms.... before i do a cam though i plan on gettin a C-6 and puttin in it....ill prolly get the Typhoon upper and lower then the cam.... im just lookin to gain a little of my topend power back.... I cant handle anymore power of the line right now because all i do is spin through first
Old 02-05-2007, 11:44 AM   #16
bluemustang's Avatar
Re: Cam a stock 5.0
im intrigued to know why you would be going with a C6 tranny
personally just do the h/c/i all at once then from there you can upgrade springs, rockers you know all the smaller things that needs to be done
Old 02-05-2007, 11:48 AM   #17
Re: Cam a stock 5.0
Well, he wants more than 4 gears...and, well, the only thing that popped into my mind for a more than 4 gear auto was the C6...that I could remember anyhow. Could be wrong though...not up on cams nor autos.
EDIT: And well, making the assumption the 6 meant 6 speeds since the C4 is 4 speed...well...looks like I be wrong on that assumption. C6 = 3 speed? That blows. lol
EDIT2: Looks like maybe the Ford 6F transmission might be a good option...assuming you could get a bellhousing that will bolt up to the 5.0.
Old 02-05-2007, 12:00 PM   #18
Justin's Avatar
Re: Cam a stock 5.0
Well screw a C-6... Mine and Robs assumptions were wrong..
Old 02-05-2007, 12:09 PM   #19
Justin's Avatar
Re: Cam a stock 5.0
Ok...I know ford makes a 6 speed auto transmission... Whats the model number of it.... Or what tranny would yall recomend?
Old 02-05-2007, 12:10 PM   #20
Re: Cam a stock 5.0
Old 02-05-2007, 12:16 PM   #21
Re: Cam a stock 5.0
Im glad you owned yourself seriously I see nothing grand about the C6 unless the car is ONLY gonna be for drag racing.
im not a 100% sure when the transition went from AOD to AODE but why not find a shop near your area that deals with just transmission? I went and got my AOD done up real nice. and it was actually cheaper for me.
Didnt that new 6 speed auto just come out? isnt on the fusion? I dont see that tranny at all holding any type of power.
But who knows
Old 02-05-2007, 12:22 PM   #22
Justin's Avatar
Re: Cam a stock 5.0
im lookin for a 5 - 6 speed auto.. doesnt have to be 6 speed... just more than 4...i need one more gear to wind out before OD....when i his OD at 85is...Its almost like i taped the brakes goin into it and crusin...A 6 speed would be great if it could handle the power... so suggestions would be great
Old 02-05-2007, 12:23 PM   #23
Re: Cam a stock 5.0
Yes, and it is rumored that it, or a version of it, is going to go into the new F-series. Next F-150 will get 6-Speed Automatic - AutoWeek
And, like I said, he only wanted the C6 because he wants more than 4 gears and we both figured the 6 meant 6 speeds since the C4 is a 4 speed.
Old 02-05-2007, 12:30 PM   #24
Re: Cam a stock 5.0
well hell if it comes out for the F150 im def gonna look into it myself
Only thing I can think of if you can get a 99+ stang auto trans
Old 02-05-2007, 12:31 PM   #25
Re: Cam a stock 5.0
Still only a 4 speed...maybe an 05+ auto which is a 5 speed...
Old 02-05-2007, 12:33 PM   #26
Re: Cam a stock 5.0
Yeah well there ya go then didnt even know the autos were 5 speed
Old 02-05-2007, 12:48 PM   #27
Justin's Avatar
Re: Cam a stock 5.0
Me either...would it bolt up?
Old 02-05-2007, 12:52 PM   #28
Re: Cam a stock 5.0
Me either...would it bold up?
Well, I am basing the statement of it being a 5 speed on stuff kyle spews out all the time about auto transmissions...but, like I said, I am not an auto fan (think they are for girls :box: )
Guess I need to kill some more time looking up info again...
And, no, it won't just "bolt right up"...unless the bolt pattern on the bell housing matches that of a 5.0...which I doubt. However, making it fit would not be a massive undertaking to my knowledge...would just take an adaptor plate or something I believe.
EDIT: Verified 05+ auto is in fact 5 speeds.
Old 02-05-2007, 12:57 PM   #29
Herbstang's Avatar
Re: Cam a stock 5.0
Ford-AODE.com the Ultimate AODE / 4R70W Performance Transmission Website GM-Ford 6-speed automatic transmission - Wikipedia, the free encyclopedia
Old 02-05-2007, 01:05 PM   #30
Re: Cam a stock 5.0
That transmission site is def the win kinda wish i seen that a while ago
Old 02-05-2007, 01:21 PM   #31
Justin's Avatar
Re: Cam a stock 5.0
Well i might be able to get the adapter for free...and free labor.. g/fs dad owns a transmission shop.....
Old 02-05-2007, 03:48 PM   #32
Justin's Avatar
Re: Cam a stock 5.0
any word on the 07 gt tranny? i cant find any info on it... went to fords website and only found what we knew already...5 speed auto
Edit: I did find out its a 44L 5 Speed Auto Transmission if yall would like to do any reasearch.
Old 02-05-2007, 04:36 PM   #33
MonteCitan's Avatar
Re: Cam a stock 5.0
The new 6 speed auto is in a transaxle configuration... won't bolt up in any way to a RWD car (unless it was AWD )
the 5 speed autos in the mustangs/etc are completely electronically controlled I also don't see any way you can adapt it to your car
Old 02-05-2007, 05:07 PM   #34
bullitt482's Avatar
Re: Cam a stock 5.0
I don't know why you would want a 5 or even a 6 speed automatic... They aren't very capable of high hp/tq applications.... More moving parts/clutchpacks/etc=more chance for breakage..... The C4 and C6 are both 3 speeds( I know the C6 has already been addressed). The C6 was used on the higher hp and bigger cube motors in the 67 area. The C4 was mostly mated up to the 302 and 289 depending on the models...
Basically the question is, what are your goals? What do you want the car to do? Autox car? Drag car? Aggressive street car?
*edit* What you are talking about doing is like trying to skin a live Bobcat with a plastic spoon that cost several thousand dollars....
01 Bullitt
Old 02-05-2007, 05:10 PM   #35
Justin's Avatar
Re: Cam a stock 5.0
Im lookin for a Aggresive street car.... I want to be able to have power in the topend... I shift out of 1st at 35ish, 2nd at 60is and into OD at 85 then its hardly no power after that... I was really wanting to have a tranny with another gear so i would have one more to wind out before OD
What u suggest i do bullitt?
3.8 V6 Comp Cam Performance Cam nmaraijko Mustang Parts for Sale and Wanted 0 11-15-2006 07:11 AM
FS: BV Heads, 173's,Cam, and Stock Heads petrey10 Mustang Parts for Sale and Wanted 4 06-26-2006 11:15 PM
stock mustang cam shaft? bigpomps Pre-2005 V6 Mustang 3 03-15-2005 01:02 PM
Cam Cores needed for RDMotorsport cam GP RGR Mustang Parts for Sale and Wanted 3 03-05-2005 05:53 AM
02:09 AM
