5 lug conversion - Mustang Evolution
Old 08-15-2010, 06:33 PM   #1
5 lug conversion
i have a 79 pace car that has a 2.3t and 4 lug. what would i need to do to convert it to a 5 lug?
Roger24 is offline   Reply With Quote
Old 08-15-2010, 08:59 PM   #2
Re: 5 lug conversion
There are companies out there that make a conversion kit.
Or you can do it the junkyard way. 5 lug axles from a ranger and Sn95 front spindles. I'm sure there are more parts to it but those are the major parts.
Old 08-16-2010, 02:33 AM   #3
SaleenFiend's Avatar
You will need different brackets for the brakes. I just ordered mine from ebay.
Old 08-16-2010, 07:17 AM   #4
my friend did it, you have to use the correct spindles and such else the center caps wont go back on etc etc. He used 94/95 GT spindles I believe. Not sure what else had had to do.
Old 08-16-2010, 12:26 PM   #5
Would the ranger gears work witth the hp ill be making? and anyone know where I could find the companies that make the kits?
Old 08-16-2010, 04:13 PM   #6
If I remember correctly the ranger axles are 28 spline which is what the GT's come with from the factory. The reason I said ranger axles is simply they are the same length.
Old 08-16-2010, 04:55 PM   #7
I kinda figured. I'm guessing I would get one from a 4×4? And would it bolt right in?
Old 08-19-2010, 04:42 PM   #8
Yes, I forgot to add you need the 94-95 Spindles.
Also, aren't you supposed to use two of the same side axles from a ranger? I think it's the passenger side axles. I know I have Ranger axles going in my swap but I thought they were both passenger side axles.
Old 08-25-2010, 12:38 PM   #9
Yeah if you want both wheels to spin then you would need both passenger side
Old 09-01-2010, 08:33 AM   #10
banzaibullitt's Avatar
Driver's side Ranger, or passenger side Aerostar.
banzaibullitt is offline   Reply With Quote
Old 10-25-2010, 07:01 PM   #11
silverstangboy's Avatar
Red face Re: 5 lug conversion
I know this thread is from way back, but having done so myself if I were to re-do the 5-lug conversion on a fox I would order the custom made spindles just for that purpose...
I had used the ranger axle method and once I got around to putting cobra brakes on the rear of the car to replace the drums I had a heck of a time trying to source the retrofit rings to center the SN95 rear cobra hubs (GT has the same problem FYI)
I ended up welding 1/8" aluminum stock into a circle which works fine, but was a pita.
oh and for anyone considering using cobra brakes on the lighter fox, I can SERIOUSLY stop now!
93 mustang notch
~450hp 331 stroker - Sold
Old 10-25-2010, 07:24 PM   #12
I believe you can use 1/8" wall thickness tubing to make them, or get them from discbrakesrus.com, or possibly Factory 5.
Old 10-26-2010, 06:34 AM   #13
Glad you guys bumped that. I never remember which axles out of the Ranger/Aerostar to use.
Old 11-23-2010, 11:45 AM   #14
Send a message via AIM to JohnnyGunz
I would recommend using the cobra master cyl. and brake booster also. The bigger calipers will need more fluid than the old master can supply. Are you going to keep the drum setup in the rear? I would highly recommend swapping to disc. I have this setup on my 90 coupe and it stops well, almost too well.
JohnnyGunz is offline   Reply With Quote
5 lug conversion from 03 Cobra and 98 GT gatorphan13 1979-1995 Mustang GT 7 02-18-2007 06:50 PM
4-lug brake conversion Taywi General Car Discussion 4 01-13-2007 10:43 AM
5 lug conversion Fox Mustang Parts for Sale and Wanted 5 12-01-2006 05:24 PM
5 lug conversion cowboy72 Mustang Wheels & Tires 2 11-22-2006 07:41 AM
5 lug conversion Fox 1979-1995 Mustang GT 0 11-18-2006 05:59 PM
01:22 AM
