header install - Mustang Evolution
Old 02-17-2007, 07:22 AM   #1
header install
I was just wondering how much it should cost to get shorties installed or should I brave it and do it myself? I did my catback but this looks alot more complicated.
-Doug
'95 Mustang GT
Rocket50 is offline   Reply With Quote
Old 02-17-2007, 10:23 AM   #2
MonteCitan's Avatar
Re: header install
It's not all that complicated, however you might have issues with rust/etc
Not sure on price, but unless you have a lot of patience and/or tricks up your sleeve (torch?), you might want to take it somewhere's
I put them on my 89 in the driveway with no problems, not sure how much different the strut tower clearance would be on yours, mine came close to the steering shaft (MAC headers) but it cleared it...
Do you still have all the smog pump stuff? If all your bolts break loose, that might be your last hold-up
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 02-17-2007, 02:11 PM   #3
Scut95's Avatar
Re: header install
I did my shorties on my 95. It was a pain to do/fun at the same time (i like turning wrenches). I had to disconnect my steering shaft and remove the metal bar that goes across the k-member. The easiest way to get them out is to slide them out through the bottom. The most difficult part to do is get the headers in place, get the gasket in there and tightening the bolts. The tightening is the definately the hardest because space is ridiculously tight. On the passenger side i found it easier to get at the front bolts from below. The driver side front bolts have the power steering pump interfere but you can still get in there an make it tight, just takes a lot of short turns. I also had to bend my dipstick tube a little bit. These are just some things i ran into, plus some rust but nothing a little penetrating oil couldn't handle. I don't know how much it would cost for a shop to do it but i'm guessing it wouldn't be cheap. Btw, the way to tighten header bolts is to do it initially, warm the engine up/cool down, warm up again then tighten them while hot. They're going to back out and doing this 2 or 3 times should stop that from happening. I would recommend buying the bolts from summit that lock in. They're expensive (like $50) but worth it so you done have a header leak.
Old 02-17-2007, 02:31 PM   #4
bbunt302's Avatar
Re: header install
Back in the day, I paid $100 to have MAC shorties and a ProChamber put on my '91 GT.
Scary stuff.
Old 02-18-2007, 06:53 PM   #5
silverstangboy's Avatar
Re: header install
WHAAAA???!!!?
you paid for that
93 mustang notch
~450hp 331 stroker - Sold
Old 02-19-2007, 08:01 PM   #6
79Ghia50Stang's Avatar
Re: header install
hou think installing headers on a stang is hard? try doing it on a camaro that has a freaking 5.7L 350 stuffed nearly into the dash... that is freaking hard... the LS1's are a little easier but the LT1's and 3.8L V6's are a pain... so i am told lol... i wouldnt do the headers swap on my camaro because i would get mad and break something lol... but i would do it on the 79
79Ghia50Stang is offline   Reply With Quote
Old 02-19-2007, 08:07 PM   #7
Scut95's Avatar
Re: header install
I probably wouldn't do it on the F-bodies either, their ridiculously stuffed in there....Foxes have more room in the engine bay than sn95 cars. The 5.0 is really stuffed in the engine bay on the 94-95's atleast with clearance on the sides.
Old 02-20-2007, 08:56 AM   #8
ridenmystang's Avatar
Re: header install
Ok so im installing my mine this week. Its goin to be close to $300 at the shop or my bf and his friend were thinking about doing it. I believe the starter is in the way and will have to be takin off. Any how to do it on here haha
One wicked 03 GT FOBRA
ridenmystang is offline   Reply With Quote
Old 02-20-2007, 09:16 AM   #9
MonteCitan's Avatar
Re: header install
done it... didn't have to remove the starter, did have to loosen the drivers side motor mount completely, and loosen the passenger side, and jack the motor up to clear the steering crap
Old 02-20-2007, 09:37 AM   #10
rydog's Avatar
Send a message via MSN to rydog
Re: header install
A tip buy some penetrating oil for 5 bucks and put it on all of your header bolts and collector bolts and let them soak for about 24 hours and they will break loose alot easier
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 02-20-2007, 09:53 AM   #11
Re: header install
Yeah we did that last night. Im just wondering how long it will take for us to do it.
Old 02-20-2007, 10:01 AM   #12
MonteCitan's Avatar
Re: header install
without a lift, figure on 4-5 hours your first time - takes some finessing
Old 02-20-2007, 05:39 PM   #13
bullitt482's Avatar
Re: header install
Hell, I wouldn't even change sparkplugs on an F-body......
01 Bullitt
Old 02-20-2007, 05:49 PM   #14
Re: header install
yea i did that but once you get the back ones the others seem extremely easy to change...
Old 02-21-2007, 05:47 PM   #15
Re: header install
personally on some cars it would be alot easier just to lift the motor, its not like you have to take it all the way out.
this is what the dealerships do with alot of new cars in order to change the plug's ( a good example would be the LT1's everyone meantioned)
93 mustang notch
Old 02-21-2007, 08:37 PM   #16
Re: header install
and that is why the dealerships and auto shops charge so much to do plug changes on f-bodies... they think that if the shop manual says to lift the engine a little they have to do it or it will not work at all... it is easy to change the first 4 on a v6 and the first 6 on the v8... it is the back two that are the problems but those are easily changed from under the car... but if i had the cash to let a dealer do it i would let them just to avoid the hassle but once you get the hang of everything it does not take over 30 minutes top...
Old 02-27-2007, 09:04 PM   #17
Re: header install
well, it only takes about 15 minutes to lift the motor and do it... (with dealership tools at hand anyways)
93 mustang notch
Old 02-27-2007, 09:27 PM   #18
Re: header install
It took longer than that to do mine. It was a freakin pain.
Old 02-28-2007, 04:41 PM   #19
bullitt482's Avatar
Re: header install
/\ Really? Changing plugs on a modular motor with COP's is a cakewalk. 20 minutes max without using electric or air tools.
01 Bullitt
Old 05-21-2007, 07:32 AM   #20
redmustang95's Avatar
Re: header install
On my 95, i did my plugs within 30. And thats removing the egr hoses and the CAI.
redmustang95 is offline   Reply With Quote
Old 05-21-2007, 04:05 PM   #21
bullitt482's Avatar
Re: header install
You still have EGR?
01 Bullitt
Old 05-21-2007, 05:29 PM   #22
rocknbronco's Avatar
Re: header install
Thts just do to the angle on the plugs my Bronco and Mother In Laws F150 are the same way.
rocknbronco is offline   Reply With Quote
Old 05-21-2007, 05:32 PM   #23
bullitt482's Avatar
Re: header install
Yup, that's also the reason why I shy away from advising people putting GT40 heads on their stang, cause finding headers that compensate for the angle of the sparkplugs is few and far between. There just isn't much to choose from, plus changing plugs is a *****.
01 Bullitt
Old 05-21-2007, 05:36 PM   #24
Re: header install
Yeah but still not as bad as a WS6.....
Old 05-21-2007, 05:43 PM   #25
bullitt482's Avatar
Re: header install
No ****
01 Bullitt
Old 05-21-2007, 05:48 PM   #26
Re: header install
Had one kid in clas alught casue of a 150 thats was giving me a fight then he worked on his WS6 I got my revenge back....
Old 05-22-2007, 04:51 PM   #27
bullitt482's Avatar
Re: header install
what the ****?
01 Bullitt
Old 05-22-2007, 10:17 PM   #28
Re: header install
yeah, i still got egr . i just picked up this mustang recently and work has been hell.
Old 05-23-2007, 05:12 PM   #29
bullitt482's Avatar
Re: header install
Just ribbin' yah. I feel you on the work part. I have yet to put a clutch in. Hopefully will have a SPEC 2 in the Bullitt friday
01 Bullitt
Old 05-23-2007, 05:14 PM   #30
Re: header install
Well before I typed to fast I had a classmate whom had a WS6 he laughted at me about changing spark plugs in # 4 and #8 for taking so long. Well when he changed the plugs on his LS1 I got the last laugh of course this is the guy whom drilled into his computer installing neons
Old 05-23-2007, 05:15 PM   #31
bullitt482's Avatar
Re: header install
Umm.. DAM I'd say karma is a *****, but dam, that just dumb luck.
01 Bullitt
Header Help 1234 1996-2004 Mustang GT 8 05-08-2008 05:54 AM
header help Sublime782 Pre-2005 V6 Mustang 6 08-08-2005 03:01 PM
Header Gaskets? Kiljosh Mustang Parts for Sale and Wanted 0 02-23-2005 01:56 AM
Header Install help Kiljosh Pre-2005 V6 Mustang 13 10-23-2004 11:32 AM
Some pics of my long tube header install... Junior2561 The Bar 8 02-23-2004 03:29 PM
06:34 AM
