5 lug conversion from 03 Cobra and 98 GT - Mustang Evolution
Old 02-18-2007, 11:28 AM   #1
Can I use the strut, lower control arm, spindles, rotors, ect.... out of a 03 Cobra for the front, and the axels, rotors, ect... out of a 98 GT to do my five lug conversion???
gatorphan13 is offline   Reply With Quote
Old 02-18-2007, 11:42 AM   #2
bbunt302's Avatar
Re: 5 lug conversion from 03 Cobra and 98 GT
Basically, all you'll be able to use from the 03 Cobra is the brakes (rotors and calipers). The rest of it won't work. You need spindles off a 94-95. 96-98 spindles will also work if you are only going to be running 8" wide wheels. I believe there are clearance issues if you go any larger.
Also, the struts may or may not work. I'm not 100% sure on that one. I think I've read that they will though.
Scary stuff.
Old 02-18-2007, 12:52 PM   #3
bluemustang's Avatar
Hey B what width tire can be used on the 94-95 spindle?
Old 02-18-2007, 02:33 PM   #4
bbunt302's Avatar
I've got 255s on a 9" wheel on mine. They rub at full lock, but it's not too bad. You could probably put 275s on there and sacrifice a little more turning radius. Mike (Silverstangboy) had some on his car for a while.
Scary stuff.
Old 02-18-2007, 03:12 PM   #5
So the rear won't work at all?
Old 02-18-2007, 03:13 PM   #6
and what are the differences in a 94/95, 96/98, and 99/04 spindles?
Old 02-18-2007, 04:39 PM   #7
I found this, 79-93 Disk Brake Upgrade but I know that Baer Brake Systems makes a complete kit thats suppose to be very good, but I can't find it on their site.
JROC is offline   Reply With Quote
Old 02-18-2007, 07:50 PM   #8
silverstangboy's Avatar
here is a good site that should help you out
Sn95 Brake upgrades
93 mustang notch
~450hp 331 stroker - Sold
quick! five lug conversion specialist? powerhungry966 1979-1995 Mustang GT 9 06-03-2007 10:14 AM
4-lug brake conversion Taywi General Car Discussion 4 01-13-2007 11:43 AM
5 lug conversion Fox Mustang Parts for Sale and Wanted 5 12-01-2006 06:24 PM
5 lug conversion cowboy72 Mustang Wheels & Tires 2 11-22-2006 08:41 AM
5 lug conversion Fox 1979-1995 Mustang GT 0 11-18-2006 06:59 PM
02:29 PM
