Grinding/Bearing noise from 88 GT - Mustang Evolution
Old 08-23-2010, 03:37 PM   #1
My aunt has an 88 GT 5.0 auto; it has had a rather...rough life...and I'm doing what I can to help her and keep it on the road.
I drove it yesterday; and there is what I'd figure a bearing noise from the right rear, i've read that it can be part of the rear diff, or possibly the bearings, or I even read it could be something to do with shims?
What I know:
1. Grinds from the right side
2. Grinds when going straight, and when turns (at speeds below 25 mph)
3. When I put in Neutral while rolling, the grinding stops
4. When driving double footed brake, it doesn't clear up (the re-seat the pads by braking theory).
Again, this Mustang hasn't had the easiest life, it gets alot of freeway miles and lots of abuse; I replaced the headlights, am going to replace the ragtop, and other tickytacky things I think need to be done to maintain roadworthiness.
Before I go all 'bearing' on this car, is that usually the problem?
ANy help would be GREATLY appreciated.
Jeffrey
Jeffrey2 is offline   Reply With Quote
Old 08-23-2010, 04:26 PM   #2
SaleenFiend's Avatar
Re: Grinding/Bearing noise from 88 GT
Step one, sell me your complete wiring harness for cheap.
Old 08-23-2010, 04:46 PM   #3
allllright
Old 08-23-2010, 05:38 PM   #4
Originally Posted by Jeffrey2 View Post
allllright
I'm serious...
although I would pull the rear diff cover and check spider gears and bearings for any abnormal wear or cracking. Also check both axle seal near the wheels.
Grinding Noise From Gears parkerr1 General Mustang Discussion 5 12-16-2008 05:34 PM
loud grinding noise! roach 1996-2004 Mustang GT 13 03-24-2008 10:01 AM
grinding noise from pass. front jimmy_beaner 1996-2004 Mustang GT 3 12-17-2006 07:37 AM
Rod bearing noise? OH NO!!! In2dreamingbig 1996-2004 Mustang GT 12 04-28-2006 12:22 PM
grinding noise from diff. Horse Pre-2005 V6 Mustang 8 04-27-2004 04:47 PM
02:24 AM
