Sluggin - Mustang Evolution
Old 02-27-2007, 09:56 AM   #1
Justin's Avatar
Send a message via AIM to Justin Send a message via Yahoo to Justin
Sluggin
Ok i was puttin out in some traffic from my neighbor hood road. I pulled out and got straight on the high way and nailed it from about 15 i spun sideways a little bit and caught.I noticed in the higher rpms i can feel my car sluggin a little bit. Almost like tiny jerks you can barly feel. It act like it has a fuel problem. Lack of fuel at higher rpms maybe. Its from about 4k - redline. Anyone have any suggestions on what it might be.
http://www.mustangevolution.com/forum/signatureuploads/sigpic5474_2.gif
(Project "TORQUE"):burnout:
Mods - Off Road H w/ Flowmaster 40s and 3" x 22" Tips, Shiftkit, Shorties, and 4.10s
Soon to come - UDPs, Off Road X-Pipe, A/T Cooler, and 03' Cobra Rims
Club - Tha Crew Leader of Muscle Car Division
Justin is offline   Reply With Quote
Old 02-27-2007, 10:29 AM   #2
Re: Sluggin
Fuel filter...fuel pump dying...
Those are the best I can think of off the top of my head.
Old 02-27-2007, 12:28 PM   #3
Re: Sluggin
missing? that can also cause some jumpyness
Old 02-27-2007, 12:42 PM   #4
Justin's Avatar
Re: Sluggin
i had to fuel pump replaced about a year ago so i dont think thats it. where is the fuel filter located?
Old 02-27-2007, 01:05 PM   #5
bluemustang's Avatar
Re: Sluggin
fuel filter is towards the back near the gas tank, if you have a choltons book it'll tell you exactly where it is (good investment for our cars btw should consider buying one)
Old 02-27-2007, 01:14 PM   #6
Re: Sluggin
i'd replace the fuel filter then look at Spark Plugs and Spark Plug wires
Old 02-27-2007, 01:20 PM   #7
Re: Sluggin
fuel filter should be replaced every year
Old 02-27-2007, 01:39 PM   #8
rydog's Avatar
Send a message via MSN to rydog
Re: Sluggin
I just replaced mine its right behind the rear end on the underbody
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 02-27-2007, 02:18 PM   #9
Justin's Avatar
Re: Sluggin
Ill do the fuel filter first. I replaced the spark plugs about 6 months ago. Havent touched the wires but ill do that soon
Old 02-27-2007, 02:34 PM   #10
Re: Sluggin
you'd usually wanna do plugs and wires at the same time
Old 02-27-2007, 02:38 PM   #11
Re: Sluggin
on your year you can do the fuel filter pretty easy, some require a little tool to take the lines off. Just be prepared to catch some fuel with your mouth and all will be good.
Old 02-27-2007, 02:41 PM   #12
Re: Sluggin
yep 15 mins tops well thats how long it took me to do mine on my fox
Old 02-27-2007, 02:57 PM   #13
Justin's Avatar
Re: Sluggin
is there anything i can run through the lines to the injectors from there so it isnt deluted by gas as much?
Old 02-27-2007, 03:27 PM   #14
Re: Sluggin
just run injection cleaner on half a tank of gas, and get the good stuff (its expensive... like 8 bucks a bottle but its good)
you can get your injectors out pretty easy and clean them~ or replace them for cheap as well im sure.
Old 02-27-2007, 03:45 PM   #15
Re: Sluggin
I have some 39#'ers available for cheep.
Old 02-27-2007, 04:07 PM   #16
Justin's Avatar
Re: Sluggin
whats factory?
Old 02-27-2007, 04:08 PM   #17
Re: Sluggin
Originally Posted by Justin View Post
whats factory?
No idea...but they might be 24#'s...or 42#'s...
Mine were 39# factory...now they are 60#'ers...and the 39's are just sitting in a bag looking unhappy.
Old 02-27-2007, 04:10 PM   #18
Justin's Avatar
Re: Sluggin
would that help in performance or would i just have some larger than normal injectors
Old 02-27-2007, 04:13 PM   #19
Re: Sluggin
If you have 24's, it would just give you larger than stock injectors and require tuning to make things run right.
If you find everything in working order and for some reason your stock injectors aren't able to provide enough fuel up top anymore, then they would give you the room you need now, and possibly in the future if/when you go SC/Nitrous...assuming stockers are 24#....and would require tuning to make sure stuff doesn't blow up.
If stockers are 42#...then the 39s would do nothing for you. lol
Old 02-27-2007, 04:16 PM   #20
bullitt482's Avatar
Re: Sluggin
19's are factory. The only cars to get 24's are the 93-99 and 01 Cobra. Correct me if I'm wrong.
01 Bullitt
Old 02-27-2007, 04:19 PM   #21
Re: Sluggin
I wouldn't have a clue honestly...I was just pulling numbers out of the air as to what they might be.
So, if they are 19s, then you would get really big injectors...bragging rights for having such big injectors...all the girls would swarm to you because your injectors are so huge...and most importantly, they would leave my place of residence.
However, they would be usefull if there was some power added going on the car soon.
Old 02-27-2007, 05:02 PM   #22
Send a message via MSN to 1996stang Send a message via Yahoo to 1996stang
Re: Sluggin
Im positive his car is factory 19#'s why upgrade too a bigger injector if you dont need it?
1996stang is offline   Reply With Quote
Old 02-27-2007, 05:06 PM   #23
Re: Sluggin
Bullitt's right. 19# factory for GT's.
Old 02-27-2007, 05:18 PM   #24
bbunt302's Avatar
Re: Sluggin
Putting 39# injectors on a stock 5.0L is not going to be pretty. Good luck getting it to idle.
Scary stuff.
Old 02-27-2007, 05:54 PM   #25
Re: Sluggin
Just for the record...I wasn't suggesting he move up to 39's...just suggesting I had them collecting dust.
Old 02-27-2007, 06:02 PM   #26
MonteCitan's Avatar
Re: Sluggin
a 5.0 is supposed to have top end!? :pnoid:
erm yeah... clean your mass air lately?
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 02-27-2007, 09:40 PM   #27
Justin's Avatar
Re: Sluggin
i clean my stuff every month.. i clean it when i get off work every second weekend i work and i work every other weekend
Old 02-27-2007, 09:43 PM   #28
MonteCitan's Avatar
Re: Sluggin
what do you clean it with?
Old 02-27-2007, 09:45 PM   #29
Justin's Avatar
Re: Sluggin
im not real sure... my friends dad gave it to me... he works at a ford dealership... its what they use to clean parts with
Old 02-27-2007, 10:13 PM   #30
silverstangboy's Avatar
Re: Sluggin
the 5.0's have problems with TFI's, Pickup's, DPS's and such and so.
if you have over 100K on the clock then consider replaceing the fuel filter as suggested along with a rebuilt factory distributer, new plugs and wires if you need them... and all shall be well.
use autolites, 5.0's don't like fancy plugs, the autolites are the best
cleaning the mass air sensor isn't a bad idea
setting the TPS voltage isn't a bad one either
hope you have a timing light set.
93 mustang notch
~450hp 331 stroker - Sold
Old 02-28-2007, 06:29 AM   #31
MonteCitan's Avatar
Re: Sluggin
Cleaning the mass air with anything other than no residue electrical contact cleaner... could definitely be your problem...
Old 02-28-2007, 07:38 AM   #32
rydog's Avatar
Re: Sluggin
exactly I caught it all downmy arm and in my hair...
Old 02-28-2007, 08:30 AM   #33
Justin's Avatar
Re: Sluggin
So right now im lookin at replacing
Plugs
Wires
Filter
What cleaner do you suggest for the mass air.
Also Silver suggest i change some things if im over 100k.. Im over 200k anything else yall suggest id do. Its gonna take time due to a ticket and some other debts that i have to deal with right now but i can order something thats not expensive every 2 weeks.
Old 02-28-2007, 08:43 AM   #34
MonteCitan's Avatar
Re: Sluggin
Electrical contact/no residue cleaner... can be found at parts stores -> Don't use brake clean, its much rougher on sensitive electronic components..
Old 03-01-2007, 09:26 PM   #35
Re: Sluggin
nah, i'd do the things suggested here, and then go from there
changing out the distributer will probably make a nice difference if its showing 200K
93 mustang notch
09:11 AM
