T-56 Conversion - Mustang Evolution
Old 03-08-2007, 09:33 PM   #1
T-56 Conversion
I can't figure out if there is a special t-56 that is needed for a swap or what is needed to complete a t-56 for a t-5 swap.
If there is anybody out there that has successfully completed this conversion, let me know what I can do to make it happen.
BTW, I have a 1991 GT with a stock t-5.
sir2much is offline   Reply With Quote
Old 03-08-2007, 09:38 PM   #2
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
Re: T-56 Conversion
I'm pretty sure that all you need is to have the correct bellhousing. As a big auto advocate, however, I'm not absolutely sure.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 03-08-2007, 09:43 PM   #3
Question Re: T-56 Conversion
I know the transmission that I buy will have to be from a ford, more than likely.
Can I use a t-56 from a 2003-04 cobra?
Old 03-10-2007, 11:08 PM   #4
silverstangboy's Avatar
Re: T-56 Conversion
yes, I however don't know what all it takes, nose around on some of the other v8 sites and find out.
it'll be much cheaper to go TKO
93 mustang notch
~450hp 331 stroker - Sold
Old 03-11-2007, 12:17 PM   #5
Re: T-56 Conversion
It just takes the tranny, shorter drive shaft, and then to fab the tranny supports. It's not a ton of work really once you have the parts. Being a fox though, you MIGHT have to make some room in the tranny tunnel....but other than that, it shouldn't be too bad.
Old 03-11-2007, 06:58 PM   #6
Re: T-56 Conversion
you also have to ask yourself the question as to why you want a 6 speed. It really doesnt make the car faster in a straight line and its heavier and the ford version is not geared as good as the GM version etc etc.
Old 03-11-2007, 09:13 PM   #7
Scut95's Avatar
Re: T-56 Conversion
I'd even consider using the Viper spec T56.....but thats alot more price wise
Old 03-11-2007, 09:31 PM   #8
Re: T-56 Conversion
The gearing really isnt super amazing or anything on the ford spec ... they moved the 1 to 1 ratio to 5th and 4th is like .86 then 6th is .63 or something... just imagine if 6th was .50 I would probably pick up 3mpg.
Old 03-11-2007, 09:46 PM   #9
Re: T-56 Conversion
Who put 1:1 to 5th?
I think you have your numbers backwards though.
4 = .86
5 = 1.0
6 = .63
That would make no sense at all.
Ford is 1.0 in 4th gear...don't know the viper spec off the top of my head, but I am 99% sure 4th is 1.0 there as well just with a .5 6th instead of a .63.
Old 03-11-2007, 09:50 PM   #10
Re: T-56 Conversion
sorry thats what I ment 1.0 in 4th for a T-5 etc vs 1.0 in a 5th
BTW did you hit 500rwhp/tq as your avatar suggests or a future goal for your next dyno now that you have your new mods?
Old 03-11-2007, 10:00 PM   #11
Re: T-56 Conversion
At 500 rwhp now...just not quite the 520 I wanted. TQ is 487 I think...I don't remember, dude hasn't sent my damn graph yet.
And, T5 and T56 are both 1.0 in 4th...your car, my car, my buddies car with a cobra spec T56....are all 1.0 in 4th.
Old 03-11-2007, 10:32 PM   #12
Re: T-56 Conversion
I plan to do head/cam/intake swap on the car and a few other things like fuel pump and injectors. Its my daily driver so I would like to get the best gas mileage possible.
Plus it would be cool to have a t-56 in a fox. Nobody around here has one in their's.
Old 03-12-2007, 07:13 AM   #13
bbunt302's Avatar
Re: T-56 Conversion
If you really want better gas mileage, get the Viper Spec with the .50 overdrive. Otherwise, you are pretty much wasting your time.
Scary stuff.
Old 03-12-2007, 08:19 AM   #14
Re: T-56 Conversion
But will that extra .13 really make that much difference? What are we talking, about 50 rpms maybe?
Old 03-12-2007, 11:45 AM   #15
Re: T-56 Conversion
The T-5 has a 1.0 4th the T-56 has a 1.0 5th.
Old 03-12-2007, 11:48 AM   #16
Re: T-56 Conversion
Don't make me prove you wrong again Spec. 4th is 1.0 in our cars. We have 2 overdrive gears.
We had this discussion in another thread a long time ago...and I gave you a link to the site will all the ford tranny gear ratios.
The craparo version of the T56 is also a 1.0 4th. I am quite sure the viper spec is as well since Cody @ Stang Hi has a viper spec T56 is his 95 cobra and his 4th is 1.0.
:beer:
Old 03-12-2007, 11:49 AM   #17
MarkuzLS1's Avatar
Re: T-56 Conversion
All the T56s in the F-Bodies and the 'vettes have a 1:1 4th gear, and two overdrives.
I like turtles.
Old 03-12-2007, 11:49 AM   #18
Re: T-56 Conversion
I'm not alone!!!!
Old 03-12-2007, 11:55 AM   #19
Re: T-56 Conversion
Here are a couple of sources...more could be found if wanted...but...here you go:
Borg Warner 6sp T-56 Gear Ratios (GM T56 I believe)
1st 2.66:1
2nd 1.78:1
3rd 1.30:1
4th 1.00:1
5th 0.74:1
6th 0.50:1
Source: Borg Warner T-56 Gear Ratios
Ford T-56
T56 Gear Ratios
1 2.97
2 2.07
3 1.43
4 1.00
5 0.80
6 0.62
Reverse 2.90
Source: Tremec T56 Install - StangNet - The Mustang Network
Old 03-12-2007, 12:46 PM   #20
Re: T-56 Conversion
damn it I knew all of this and you just got me confused....
Old 03-12-2007, 04:51 PM   #21
bbunt302's Avatar
Re: T-56 Conversion
Try about 400 @ 70 mph with 3.73s and a 25.6" tire.
Scary stuff.
Old 03-12-2007, 06:22 PM   #22
Re: T-56 Conversion
400? I drop about 200 or so from 5th to 6th...and that is about twice that difference. I guess maybe with 3.73 it could be different.
Old 03-12-2007, 06:35 PM   #23
bbunt302's Avatar
Re: T-56 Conversion
Even with 3.27s, it's a drop of 360 RPM.
Engine RPM Calculator
Scary stuff.
Old 03-12-2007, 06:36 PM   #24
Re: T-56 Conversion
Well, I am just basing it on my Tach...:dunno:
Old 03-12-2007, 10:56 PM   #25
Scut95's Avatar
Re: T-56 Conversion
400 RPM is a pretty big drop...i know i'd like that when im crusin on the highway....the least i do on the highway is 70, im usually crusin 80-85...i have 3.73's and at 80 im turnin 2700-2800 RPM
Old 04-16-2007, 11:21 PM   #26
unstopablestang's Avatar
Region: Arkansas
Send a message via AIM to unstopablestang Send a message via Yahoo to unstopablestang
Re: T-56 Conversion
there is a tech in muscle mustangs and fast fords on how to install a t56 in a fox it don't look to be to badd i prefur a tko 600
bulit not bought
unstopablestang is offline   Reply With Quote
T-5 Conversion jxville Classic Mustangs 2 03-14-2008 10:06 PM
v8 conversion help, please. blown347ranger 1979-1995 Mustang GT 2 12-16-2007 02:29 PM
V-8 Conversion?? wonton68 Pre-2005 V6 Mustang 2 07-06-2004 07:08 AM
5.0 TB conversion how to? TheSarge Pre-2005 V6 Mustang 6 02-27-2004 08:03 AM
96 v6 to 99+ v6 conversion Aesthetics Pre-2005 V6 Mustang 7 02-15-2004 06:20 PM
01:58 AM
