Transmission trouble - Mustang Evolution
Old 03-10-2007, 03:46 PM   #1
I have a 93 gt automatic. The transmission is starting to slip in second and third. The car didn't see much action the last two years. What simple steps can I take to try and fix this. I am not much of a car guy but will try anything before I pay someone a ton of money. Thanks
chemimblc is offline   Reply With Quote
Old 03-10-2007, 10:14 PM   #2
silverstangboy's Avatar
Re: Transmission trouble
don't replace the fluid, that will make things worse
you could replace the filter, but I don't think thats going to help...
sorry man, I know you don't want to hear it but drive it till its dead, then pay someone an insane amount of money to incorrectly rebuild it for you
if anything I hate its a damn transmission shop, they're all losers
93 mustang notch
~450hp 331 stroker - Sold
Old 03-10-2007, 10:31 PM   #3
MonteCitan's Avatar
Depending on how bad your case is, though...
Installing a 'shift kit' (which bumps up all the pressures in the trans) MIGHT help, if the trans isn't entirely fried, that much more pressure working to engage the clutch packs might work out..
How is it slipping? is it actually not engaging as you rev up? or is it not shifting? is your throttle line attached properly? is the bushing at the throttle body okay?
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 03-11-2007, 06:23 AM   #4
powerhungry966's Avatar
Send a message via AIM to powerhungry966
i replaced my fluid and it runs good. better then when i first got her. its been a while though since i changed it. ahha i think its on how badly your transmission is fried. from what i know trans slip, means eventual death. so just dont drive it hard a lot and make sure when it does slip you ket go of the gas and wait for it.
1989 coupe 5.0 yeessur.
"Shake n bake"
powerhungry966 is offline   Reply With Quote
Old 03-11-2007, 06:33 PM   #5
It shifts still just slips a bit when driving. Anybody know of a good place to get a used rebuild or is that a bad idea?
Old 03-12-2007, 01:02 PM   #6
Titus Wadicus
svtlx's Avatar
dude, my best friend rebuilds aod &(e) for police and taxi. he usualy charges $650 plus parts to bench one. i'm still runn'n the aod he built me 2 yrs ago. it's held up to lots of burn outs and 130-140mph runs...of course i'm run'n one 8 core and one 6 core trans cooler...it's a lil over kill but my trans fluid is still bright red after more than 2 yrs. and the tranny tends not to exceed the ambient temp. regardles of drive time....good luck with a used unit...you got a 50/50 chance of getting a good one.
Old 03-12-2007, 01:25 PM   #7
rydog's Avatar
Send a message via MSN to rydog
That and add some of this. This stuff is the greatest
Lucas Oil
97 V6-GT40 turbo-42#rs-BA2800 MAF-4.10's & tlok-254rwhp-369rwtq
Turbo'd by-TMA Turbo(http://www.tmaturbo.com/)
Tuned by-Dyno Tuned Performance(http://www.dtpracing.com/)
rydog is offline   Reply With Quote
Old 03-15-2007, 05:48 PM   #8
Where is your friend located
Old 03-16-2007, 08:15 AM   #9
Titus Wadicus
svtlx's Avatar
COLUMBUS, OHIO.....DEPENDING ON HOW MUCH LOCAL PEOPLE ARE CHARGING YOU, IT MAY BE WORTH YOUR TIME TO PAY FOR SHIPPING...I DUNNO. i don't know wut state u r in. if u want i can ask him if he has any aod's sitt'n around and perhaps he can swap u a built one for yours...it would speed things up....he has a few aod(e) already built but i know u don't need an (e)...if it sounds like something u wanna do just let me know and i will pass his # to u.....i realize distance is a factor.
Old 03-16-2007, 03:29 PM   #10
bullitt482's Avatar
Well hello fellow white notch.
01 Bullitt
Old 03-17-2007, 05:15 AM   #11
Titus Wadicus
svtlx's Avatar
ahh ****, do i know u? u hang out wit the columbus racing clique? if u did u know my car....very loud...won a few races...suffered some idle problems...loud stang wit crappy idle..yea dats me...anyway, if u got a white notch get at me...later this year we can cruise as a team. such as fuk'n wit those guys when "return to brice rd." comes back around. i'm always look'n for non-stuck up stangers to kik it wit.
Old 03-17-2007, 06:04 AM   #12
Titus Wadicus
svtlx's Avatar
ooops sorry...just seen u r in columbus, mississippi
Old 03-18-2007, 12:54 PM   #13
what kind of kit would you suggest
Old 03-18-2007, 12:55 PM   #14
i guess i need to check into shipping charges
Old 03-18-2007, 05:40 PM   #15
Titus Wadicus
svtlx's Avatar
i am almost positive it would be under a hundred dollars.
Old 03-31-2007, 07:28 AM   #16
So how hard is it to remove a transmission? Can two guys who don't know **** about them be able to remove them.
Old 04-04-2007, 08:50 AM   #17
Titus Wadicus
svtlx's Avatar
1.get car in the air...2-4 jack stands...4 is better (all wheels off the ground)
2.get a large floor jack
3.disconnect drive shaft from rear end and remove drive shaft.
4.remove h or xpipe to gain access to transmission
5.put car in nuetral and remove torque converter bolts, or bump the starter to rotate the torque converter so u can remove bolts. there may be a converter shield, u will have to remove this to get to converter bolts (2 or 4 bolts)
6.once converter bolts are removed from flywheel, rotate the converter clockwise by hand and push toward the transmission. this will cause the converter to back itself flush against the trans bell housing.
7.remove shift linkage and kick down cable from trans.
8.place jack under transmission pan...i would use a board under the pan so that the jack cups dont push holes/dents into your trans pan...place the jack flush against the tranny pan...do not put pressure on the pan...
9.remove bell housing bolts
10.remove cross member bolts
11.pull trans back half an inch or so to clear dowel pins and the trans will drop onto your jack.
12.slowly let down trans and pull from under car
13. oh yea, disconnect tranny cooling lines from passenger side of tranny and the electric plugs, and dipstick tube before u let tranny down......
14. i would disconnect cooling lines first and make sure u have pan to catch the fluid cause its' gonna pour...then remove the bell bolt that holds the dipstick in place and remove it from trans..pull on it...pops right out.
i think i told u everything but i'm sure someone here will have something to add....send me a private message and i will give u my # if u need more in depth advice
Old 04-04-2007, 05:50 PM   #18
So do you think it can be done by two rookies. What kind of shift kit would you suggest.
Old 04-06-2007, 07:16 AM   #19
Titus Wadicus
svtlx's Avatar
absolutley two rookies can do it....worse comes to worse, buy a haines manual for mustangs...they give better instructions than me...i have a performance automatic "p/a" valvebody. it holds second gear without u having to shift from 1 to 2 and back to 1...basicaly it will hold wutever gear u put the shifter into. u can manual shift any tranny but it ususally isnt good for them. the p/a changes that....it was described as a autoshift/manual shift valvebody. and it gives you harder/faster shifts...not the typical aod shift delay. i think i paid around $200 with tax from jegs....i also got a 2500 stall to complete the drivetrain...i coulda went with a bigger stall but traction has always been a problem with my coupe....i wouldnt advise installing the valvebody yourself unless you are feel'n brave...but the tranny should be a piece of cake.
Old 04-06-2007, 07:20 AM   #20
me and silverstangboy removed his T-5 in his mustang... he did drop it on himself while under the car and spilled his expensive *** GM syncromesh but other than that its not hard.
Old 04-06-2007, 08:07 PM   #21
I think we will give it a shot what do I have to loose. I think I will find a professional to rebuild everything.
Old 04-06-2007, 08:08 PM   #22
did he replace it or rebuild it
Old 04-16-2007, 05:26 PM   #23
Is it true that when you pull the transmission out that the engine will move on you
Old 04-16-2007, 05:32 PM   #24
it does a little bit as the points that hold it down are the engine and tranny mounts and with out the tranny mounts only two mounts are holding it in so it will wiggle a bit~
Old 04-16-2007, 06:11 PM   #25
is it difficult to get everything lined back up
Old 04-17-2007, 08:02 AM   #26
Titus Wadicus
svtlx's Avatar
no, there are dowel pins. they will be stuck in the tranny bell housing or the motor bellhousing. these dowel pins will assist u lineing up the transmission to the motor.
Old 04-18-2007, 06:58 PM   #27
so really this will not be to bad. how tuff is it to rebuild them
Old 04-19-2007, 10:28 AM   #28
Chris's Avatar
Send a message via Yahoo to Chris
Sounds like a good time to switch to a 5-speed to me. I just converted my 95 to a stick car and fell in love with the car all over again.
Chris is offline   Reply With Quote
Old 04-19-2007, 11:22 AM   #29
Titus Wadicus
svtlx's Avatar
a t-5 or an aod?.......i'm pretty sure u can do a t-5 yourself...my friend and i replaced some gears in one before...aod, u will need some specialty tools, i wouldn't advise trying to take one apart. believe it or not, u can rebuild an engine faster and easier than u can build an aod...there are so many parts it's mindboggling...i've been help'n my buddy build aod's..aod(E)..700r4's.. for the past two years and i can say with confidence, i still won't attempt by myself. as much as i loved legos as a kid, i just don't have the aptitude to rebuild an automatic trans...soooo many parts and pieces.......i just bought a 90 gt with a bad aod, so i will be right with u on r & r...it suks, cause i still have to put the valvebody and stall in my '92 coupe.
Old 04-19-2007, 08:39 PM   #30
ah, the good ole days!
no, I didn't spill that GM syncromesh, I bathed in it..
and it was expensive, but the T-5 hasn't shifted like that since...
93 mustang notch
Old 04-21-2007, 03:36 PM   #31
I think it is an aod but im not real sure whatever was factory back then
Old 08-06-2007, 08:38 AM   #32
Finally got this project going. The H pipes and drivetrain are off.
Old 11-01-2007, 04:59 PM   #33
MustangBlondieZ's Avatar
Lucas Oil
Ahhhh...Lucas Oil is the greatest!!!
MustangBlondieZ is offline   Reply With Quote
Too much trouble? upton7 1996-2004 Mustang GT 4 07-15-2009 08:31 PM
So...how much trouble am I going to get into? lowflyn The Bar 12 04-14-2009 06:33 PM
Transmission Trouble strokestang408w 1979-1995 Mustang GT 2 08-23-2008 08:04 PM
Looks Like some of us are going to be in trouble!! ComputerGuy The Bar 23 01-16-2006 08:49 AM
Transmission Question: 1997 V6 Automatic Transmission ?? svtmustang88 Pre-2005 V6 Mustang 4 12-09-2003 04:49 PM
08:22 PM
