Trying to Save Stock Motor - Mustang Evolution
Old 04-03-2007, 09:31 PM   #1
bluemustang's Avatar
So I figured I ask here for some advice.
2 summers ago I felt I blew the motor when I had a supercharger on it had it spill all the oil and whatever what nots. So I turned the car back motor wise back to stock.
Just recently I figured out what blew was the oil sending pressure unit. Fixed it also did a tune up on it and she was back to purring.
Only thing is if I get to stop sign or something my car instantly shuts off. I thought it was the battery cause the tray was broken but I ghetto rigged it and got new terminals on the battery cables and still does the same thing
I was saving for a new block but just had some things come up that I had to use a good amount of it. So im ****ed and just trying to make this motor back to the norm so to speak so I can actually cruise damnit.
So any ideas of what I should look at would be great honestly.
Old 04-03-2007, 09:32 PM   #2
Cajun JungleBoy's Avatar
Send a message via AIM to Cajun JungleBoy Send a message via Yahoo to Cajun JungleBoy
Re: Trying to Save Stock Motor
yea i got a good idea... give me the old blower.
Cajun JungleBoy is offline   Reply With Quote
Old 04-03-2007, 09:32 PM   #3
ill throw it on the '81 8)
Old 04-03-2007, 09:35 PM   #4
yeah ah if you were around here 2 years ago or so you'd know i sold it then
Old 04-03-2007, 09:43 PM   #5
damnit... only been here a year
Old 04-03-2007, 10:19 PM   #6
Try setting your throttle body up as follows:
- Let the car idle, and while idling, pull the wiring harness from the IAC valve.
- If the car continues to idle at about the same speed, it's set fine.
- If the car stalls when you disconnect the IAC, adjust the throttle body using the throttle stop screw until the car idles at the target speed with the IAC disconnected.
- Once the throttle adjustment is complete, use a voltmeter to help you adjust the TPS sensor to read a little below 1V at idle. I like .95V, but bear in mind that the voltage will increase slightly as the sensor heats up.
- Once the TPS adjustment is complete, you are done.
This procedure often helps with the "stalls at traffic lights" problem. There are also settings in the computer to help deal with it, but if you have a more or less stock engine and throttle body setup, you should not need a reprogrammed computer to make it work right.
Good luck.
-Matthew
90 LX Coupe
02 GT Convertible
03 F-250 PSD
06 SRT8 Magnum
http://www.tecmotion.ca
Matthew is offline   Reply With Quote
Old 04-04-2007, 07:23 AM   #7
yea, thats the problem buying a blower from a guy for a car that you wouldnt have had....
Old 04-04-2007, 08:18 AM   #8
Titus Wadicus
svtlx's Avatar
like matt said...check the iac...idle air control. check with voltmeter like matt said. however, u may not have an adjustable tps. i wouldn't advise messing with it till u know wut u r doing and exactly wut a tps does. u shouldn't have to touch the throttle stop unless it has backed out on its' own. if you do adjust the throttle stop, i would advise u to put some thread tape on the bolt so it doesn't back out on u later....you can get a i.a.c. from a junk yard just see if it is the iac before u spend big money for a new one. it doesnt have to come off of a 5.0, they are very interchangable...i have used escort iac's and currently running one from an expedition. if all the holes are in the right place and the plug is tthe same u can use it.....i'm almost positive you have an iac issue..........
thanks matt,...now i know wut voltage to set my tps @
Old 04-04-2007, 09:22 AM   #9
Good luck.
-Matthew
Ill have to try this out this weekend then.
also got suggested these things too
look into wiring... loose coil wires? loose ground?
You're motor isn't the issue... if you are doing hard braking and it's stalling it could be a power issue like tony is saying... check grounds, check the voltage that your ALT is giving out... You gotta remember when you are hard on those brakes, that's all vac... could be a vac related issue as well... If your motor was on it's way out, you would be having other symptoms...
Check the air inlet tract for damage, cracks, etc. Most common cause in my experience.
One thing is the hard stop idle setting proceedure and cleaning the throttle body and the IAC or a new IAC.
Old 04-05-2007, 12:03 AM   #10
Come to think of it, the other typical problem is that the IAC valve is gummed up and won't move correctly. If you pull it off and spray it with carb cleaner and ensure that it moves freely you may also solve the problem. You can usually get the gasket at Ford or any parts store.
Really, the problem you have sounds like a control problem, not a fundamental issue with the motor, so it's either a gummed up IAC, throttle position setup problem, or something similar.
It seems like the throttle stop wouldn't back out, but a wrong setup on the throttle body is typical if the car has been modified, and especially when an aftermarket throttle body is used. That doesn't mean the stop backed off, just that it is not right for the rest of the setup. I've owned quite a few of these cars, and I tune a lot of them on the dyno, and the first step is always to check the throttle setup because if that is not right, you will just chase your tail with the computer setup.
Good luck.
-Matthew
90 LX Coupe
02 GT Convertible
03 F-250 PSD
06 SRT8 Magnum
Old 04-05-2007, 12:36 PM   #11
you know I tried getting off the throttlebody before and it would not come off for the life of me. it looked like it was literally glued on the intake.
Ive cleaned the IAC because the car sat and it wouldnt idle for the life of me but once I did that and few things the car actually idles fine without dieing like it did before.
Old 04-05-2007, 06:13 PM   #12
bbunt302's Avatar
Here's the correct way to reset your idle by the way:
1. Disconnect the battery's negative terminal to reset/clear the computer's memory. Leave it disconnected for 30 minutes. WARNING: Whenever removing your battery cables ALWAYS disconnect the negative battery cable first and reconnect it last. Otherwise you could destroy your computer or cause a battery explosion.
2. Disconnect the plug going to your idle motor which is located on the front of your throttle body.
3. Reconnect your battery's negative terminal.
4. Start the engine, and set the idle to the rpm you want with the stop screw on the bottom of the throttle body.
5. Turn off the engine.
6. Reconnect the plug on the idle motor
7. Make sure all accesories (radio, blower motor, a/c, lights, etc) are off and start the engine.
8. Let engine run for two minutes.
9. Turn engine off and wait two minutes then restart engine and let idle for two minutes with all accesories on.
Scary stuff.
hot to tell the dif between PI motor and reg motor Keto77 1996-2004 Mustang GT 13 07-29-2009 12:03 AM
anyone have a stock 00 gt motor for sale stockgt 1996-2004 Mustang GT 0 04-08-2008 10:02 PM
Psi rating on stock motor fasternu_674 Pre-2005 V6 Mustang 7 03-05-2008 10:58 AM
385RWHP / 428RWTQ 00 V6 5spd stock motor my old TT kit justin00stang Pictures and Videos 16 11-07-2004 11:50 PM
why would modest psi and 35 shot be so bad on stock motor? tire Pre-2005 V6 Mustang 14 12-21-2003 10:41 PM
07:52 PM
