Fox Body mustang... HELP! - Mustang Evolution
Old 04-08-2007, 10:57 AM   #1
Cajun JungleBoy's Avatar
Send a message via AIM to Cajun JungleBoy Send a message via Yahoo to Cajun JungleBoy
Okay, I have a 1981 fox hatch. I basically need to replace everything. I'm planning on dropping in a 5.0 EFI engine in the car, and want to run low compression so I can boost it down the road.
What are some sites to get alot of replacement parts? 5.0resto doesn't have anything regarding 81's from what I saw.
Cajun JungleBoy is offline   Reply With Quote
Old 04-09-2007, 05:12 AM   #2
SilentNoise's Avatar
Send a message via MSN to SilentNoise
Re: Fox Body mustang... HELP!
Finding parts for an 81 is getting hard to do, but the good thing is, many things can be grabbed from Foxes up to 93 and then there's always the options to upgrade to newer stuff up to 2004..... it all depends on what you want to do.
Wolf Pack Car Club - Domestic V8 Performance Club (Edmonton, AB, Canada)
"If the automobile had followed the same development cycle as the computer, a Rolls-Royce would today cost $100, get a million miles per gallon, and explode once a year, killing everyone inside." -Robert X. Cringely
SilentNoise is offline   Reply With Quote
Old 04-09-2007, 09:16 PM   #3
silverstangboy's Avatar
ebay is probably going to be your best freind.
93 mustang notch
~450hp 331 stroker - Sold
Old 04-09-2007, 09:31 PM   #4
MonteCitan's Avatar
gut it, make sure the body/unibody is clean/solid -- weld in roll cage, install seat... remove all useless electronics, throw in carb'd 351 mated to a tko 600, throw on a 200 shot and call it a day
oh you're gonna have to upgrade that 7.5" rear, too
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 04-10-2007, 05:47 AM   #5
you forgot redo the suspension, redo brakes, redo body work... bleh
Old 04-10-2007, 07:08 AM   #6
bluemustang's Avatar
I dont know try Mustangs Unlimited - The Source for Mustang Parts, Shelby Parts, Cougar Parts and Accessories or something
Old 04-10-2007, 07:12 AM   #7
if you want to do it right rip everything off of it and do it right from the ground up. If you want to cut corners then im sure you can just to rebuilt it for a fun car.
Old 04-10-2007, 07:35 AM   #8
Trying to explain this very thing to him...think I finally nipped the bondo talk in the bud...
Old 04-10-2007, 11:19 AM   #9
powerhungry966's Avatar
Send a message via AIM to powerhungry966
PonyPerformance.com I'VE done business with this guy. hes very trust worthy.. he might be able to help.. only thing is he's in cali .. =)
1989 coupe 5.0 yeessur.
"Shake n bake"
powerhungry966 is offline   Reply With Quote
Old 04-10-2007, 12:31 PM   #10
yeah how many dings and dents does it have?
and if your gonna use anything 1/8 inch thick duraglass is all thats needed
Old 04-10-2007, 12:33 PM   #11
Honestly, I didn't look it over that closely to see exactly. I was more concerned with getting it running and driving it to his house. Won't really know the deal until we tear down everything we know he is ditching...like carpet, headliner, seats, etc, etc....
Then, to wash it up to get the years of dust/sap that have accumulated off it...then get the rust off it and sealed...then see where we are.
Old 04-10-2007, 12:39 PM   #12
Yeah I feel you on just getting it running how I been there.
BTW if it has rust which im sure it will (floor panels, rockers, inside doorjams, trunk area, wheel wells) I highly recomend looking into PPGs rust products they are life savers if you prep the area right (thats if its not decayed rust cause then your screwed till you replace the whole paneled area)
Old 04-10-2007, 01:08 PM   #13
My instructions have been....
Strip off everything that will be going in the garbage for sure...
Find and remove rust...seal areas that have been treated.
See where you stand...create plan of attack...desired goal.
Start executing plan.
Old 04-10-2007, 01:12 PM   #14
yeah in a car like that def sounds like a game plan for sure.
and start watching those dollar signs fly away
Old 04-10-2007, 01:13 PM   #15
The best part...they will not be my $$$ ...
Old 04-10-2007, 01:21 PM   #16
no doubt. should be lucky hes in the south cause on my car I had to replace the whole damn floor panel. which worked out cause I ended up getting full length subframes welded in at the same time
dude needs to get some damn pics up already sheesh
Old 04-10-2007, 02:35 PM   #17
lmao rob has the pics hahaha i don't have my cameras at my house 8P
Old 04-11-2007, 02:33 PM   #18
Thomas91169's Avatar
time to buy a really nice compressor and a DA sander. start taking out the rust down to bare metal, apply a slight coat of body filler (Rage Gold if at all possible) and then more sanding and then a good coat of hi-build primer, more sanding.
or you can always strip EVERYTHING out and send the whole chassis to one of those anti-rust tanks where they drop the car and the chemicals eat away the rust and any oxidized metal, which might be bad cause they might pull the chassis back up and have nothing attached to the chains.
-Thomas-
Old 04-11-2007, 05:43 PM   #19
yeah id do it a bit differ in all honesty if I were doing his car id take it down to bare metal and do as much hammer and dollying as possible to get whatever dents and dings out whatever that cant be hammered out Id do a slight thin coat of duraglass (holds better, is stronger and doesnt flake away like bondo does) sand that nice and even then apply PPGs rust spray (contains rust to where its at with no more spreading) then go with a nice high build primer (house of kolor has a GREAT high build primer)
Thats the way id go about it. thats pretty much what Im gonna be doing to my car
fox body
Do these Fox body Mustang 5.0 cars have a high rate of theft? Mercedez L. 1979-1995 Mustang GT 17 06-05-2010 12:21 AM
fox body alternator to classic mustang wiring harness ericgreen29 Classic Mustangs 0 07-18-2009 07:35 PM
06:16 PM
