92 won't idle after plenum reinstalled - Mustang Evolution
Old 09-10-2010, 09:30 PM   #1
onequickR's Avatar
hey guys were slowly getting car back together. bbk headers h pipe under drive pulleys bbk cold air in fender kit new valve covers but after all this and the plentium was painted we can't get the car to idle now anyone havde any thoughts, we did have the plentium painted before putting it back on
onequickR is offline   Reply With Quote
Old 09-21-2010, 07:04 AM   #2
95YellowGT_5.0's Avatar
Send a message via AIM to 95YellowGT_5.0
Re: 92 won't idle after plenum reinstalled
got to a be a vaccum leak somewhere, either a line or the gasket itself
1995 Mustang GT, 5.0 302 Cubic Inch, K&N filter, Short Throw Shifter, Off Road X-Pipe, Flowmaster American Thunder cat-back, MSD Cap and Rotor Kit, MSD Coil & Wires
95YellowGT_5.0 is offline   Reply With Quote
Old 09-21-2010, 07:40 AM   #3
SaleenFiend's Avatar
I agree. Check all your vacuum line routing and make sure the intake plenum isn't leaking.
Old 09-21-2010, 07:43 AM   #4
brian@afm's Avatar
If this was all done at one time, you may try to rotate, or clock, the mass air meter.
Brian Koestner
Anderson Ford Motorsport
Ph 217-935-2076
Roush Power Pipe Cold Air Intake PMS and Camshafts
Dyno Tuning since 1995
"The Other Brian"
brian@afm is offline   Reply With Quote
Old 09-21-2010, 02:13 PM   #5
Idle Air Control Valve plugged up or not working.
Straublittleman is offline   Reply With Quote
Old 09-21-2010, 02:31 PM   #6
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
Plug wires ran wrong, or distributor timing way off.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 09-22-2010, 01:34 AM   #7
MonteCitan's Avatar
Could be this.. OR.. what kind of paint was used? Did you get any on the gasket surfaces (where the gaskets sit?)
Is everything torqued properly? nothing OVERtorqued? Did you connect all the hoses/lines? Did anything drop in the way of the screen on the back bottom center of the manifold where the vacuum line goes in?
Will the car run if you're on the gas a little bit?
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 09-22-2010, 06:14 PM   #8
onequickR's Avatar
I'm happy to say the gasket had a very small knick in it at one of the ports 2nd one back from front to be exact. after a gasket change the car runs fine, and just dropped it off to get the 355 gear put in it tomorrow. thanks guys
Old 09-23-2010, 07:38 AM   #9
brian@afm's Avatar
Good to hear you found something.
Brian Koestner
Ph 217-935-2076
"The Other Brian"
Old 09-23-2010, 07:56 PM   #10
onequickR's Avatar
thanks guys for the info but were good now just waiting to drive it with the 3:55 gear in it going to paint on sunday then new top and seats
Need Plenum & TB rydog Mustang Parts for Sale and Wanted 2 01-11-2007 02:50 PM
75mm Plenum/Throttle Body installed Thomas91169 1996-2004 Mustang GT 20 10-18-2005 06:28 PM
Plenum question + more ;) nickpeck28 1996-2004 Mustang GT 33 12-14-2004 12:28 PM
Wanting to replace my upper intake plenum. Black00GT 1996-2004 Mustang GT 17 03-02-2004 11:56 AM
Pro Ported upper intake plenum on my 4.6L 99+.... Rick0636 The Bar 8 01-15-2004 07:43 AM
01:44 PM
