3.73's - Mustang Evolution
Old 04-13-2007, 02:27 AM   #1
Sassa Massa's Avatar
3.73's
So I finally got around to getting some 3.73's for my car.......my question is what speedo gear am I needing to get the speedometer back to normal? It's a 95 GT by the way.
Sassa Massa is offline   Reply With Quote
Old 04-13-2007, 06:17 AM   #2
SilentNoise's Avatar
Send a message via MSN to SilentNoise
Re: 3.73's
Automatic or standard tranny?
Manual: 8-Tooth 3.73 Ratio / White 23 Speedo Gear
Automatic: 8-Tooth 3.73 Ratio / Black 23 Speedo Gear
Steeda's site has all of the info you'll need: Speedometer Recalibration Gears - '79-'98
Manual Transmissions with 7 Tooth Drive Gear
  • 1983-1989 T-5 OEM
  • Pre 1993 T-5 Aftermarket
  • 1996-1998 Cobra T-45 OEM
  • All Tremec Transmissions
Manual Transmissions with 8 Tooth Drive Gear
  • 1990-1995 T-5 OEM
  • 1996-1998 T-45 OEM Except Cobra
Automatic Transmissions with 7 Tooth Drive Gear
  • 1983-1989 Automatic Transmissions
Automatic Transmissions with 8 Tooth Drive Gear
  • 1990-1998 Automatic Transmissions
Wolf Pack Car Club - Domestic V8 Performance Club (Edmonton, AB, Canada)
"If the automobile had followed the same development cycle as the computer, a Rolls-Royce would today cost $100, get a million miles per gallon, and explode once a year, killing everyone inside." -Robert X. Cringely
SilentNoise is offline   Reply With Quote
Old 04-13-2007, 10:00 AM   #3
Scut95's Avatar
Re: 3.73's
The white gear with the stock 8 tooth (Thats the one on the tranny output shaft) gets it close but not exact. If you want it exact change out the gear on the output shaft to either a 7 tooth and then a red 21 or a 6 tooth on the output shaft and the yellow 18 tooth gear. I have a 95 gt with 3.73 and i just went down to the black 6 tooth and the 18 because with the 6 tooth, you can still get your speedo right if you plan on changing gears to 4.10 or even 4.30's in the future.
Old 04-13-2007, 03:02 PM   #4
Talking Re: 3.73's
Mine is a manual, I guess I should have posted that huh? lol I don't plan on changing the gears again but I guess the option would be nice because ya never know what I might want to do someday. Thank you guys for replying with the good info. I can't wait until the gears come in and I can get them installed. Just one more weapon against those fools in the civics with the fart can mufflers
3.73's installed ( need speedometer help ) big show 98 Pre-2005 V6 Mustang 8 12-25-2009 06:33 PM
3.73's and T-Lock among other Q's dusty97 Pre-2005 V6 Mustang 7 09-10-2008 02:53 PM
how much will 3.73's do? bigpomps Pre-2005 V6 Mustang 13 01-07-2006 12:14 PM
Cleaning out the garage: 3.73's/Gauge cluster/trans cooler Suprman Mustang Parts for Sale and Wanted 10 10-08-2004 11:05 PM
03:55 AM
