Building Engine from scratch Parts list - Mustang Evolution
Old 09-15-2010, 10:46 AM   #1
Ok, working on my parts list for building the 302 that's been sitting in my car port for almost a year now. Since I've never built a motor from scratch before, I want to come up with a list of parts I'll need to do it. I need to sit down and definitively say where I want to go with the motor before I assign actual part numbers to the various items...so I just need to make sure I'm not forgetting anything.
Ok, here's my list of parts needed so far. Some things are left off on purpose like gaskets, seals, and flywheel and what not.
Bottom End:
  • Engine Block
  • Crank
  • Balancer
  • Main Bearings
  • Cam
  • Cam Bearings
  • Push Rods
  • Lifters
  • Rods
  • Rob Bearings
  • Rod Bolts
  • Pistons
  • Rings
  • Wrist Pins
Top End:
  • Heads
  • Valves
  • Valve Guides
  • Valve Springs
  • Retainers
  • Rocker Arms
  • Lower Intake Manifold
  • Carb
Externals:
  • Water Pump
  • Oil Pump
  • Oil Pickup Tube
  • Oil Pan
  • Alternator
  • Distributor
  • Valve Covers
  • Timing Chain
  • Timing Cover
Old 09-15-2010, 05:57 PM   #2
Re: Building Engine from scratch Parts list
That would be the basic list...like you said, from here it all depends on where you want to go. Your heads will be the deciding factory on alot of those parts as well as the cam.
Personally...if you're gonna go from scratch I'd say Eagle stroker rotating assembly (I might can get you a deal on this), custom ground comp cam (again...could possibly get a deal on this), AFR heads (as wild as you feel like going) and enough parts to hold everything together to 7k in a pushrod.
Old 09-15-2010, 06:27 PM   #3
02Nate281's Avatar
Send a message via AIM to 02Nate281 Send a message via MSN to 02Nate281 Send a message via Yahoo to 02Nate281 Send a message via Skype™ to 02Nate281
Sounds like a good project. Can't wait to see it unfold.
"There is no love without sacrifice"
02Nate281 is offline   Reply With Quote
Old 09-15-2010, 09:05 PM   #4
upton7's Avatar
If i could go back and redo my engine build I would have organized better and made sure I had every single part I needed. And had alot more brake parts cleaner.
Building a parts list oaktonarcher 1996-2004 Mustang GT 2 08-21-2008 04:25 PM
Need a list of parts for a I4-v8 swap sonic04edge 1979-1995 Mustang GT 9 08-10-2007 08:29 AM
Building An Engine From Scratch OsirisGuy Classic Mustangs 10 07-08-2007 04:29 PM
Nice list of Engine Parts for V6 Mustangs: Heads, Cams, Intakes... Brent Mustang Parts for Sale and Wanted 22 04-21-2006 03:09 AM
List Of Parts I Need For A V6 hawks05 Mustang Parts for Sale and Wanted 7 03-05-2005 10:20 PM
12:28 PM
