manual trans question - Mustang Evolution
Old 04-26-2007, 09:48 AM   #1
Region: Utah
I have a t-5 that is dead. Everything that I have read says that the 94-95 manuals have an input shaft that is 3/4 inch longer than the earlier t-5.
Could anyone answer this question as to why the longer input shaft, and is it enough to make an older transmission not engage properly if used in my application. I am just looking for something to get the car driving. Just wanted to be able to get it back on the road and state inspected. It won't be an everyday driver for quite sometime.
andreas is offline   Reply With Quote
Old 04-26-2007, 09:57 AM   #2
Re: manual trans question
any 94-04 T-5 should work with out an issue as far as bolting it up goes. The issue is in 99+ the T-5s went to a magnet instead of a speedo gear~ so if you obtain one of them you will need to swap tailshafts.
Old 04-26-2007, 11:19 AM   #3
Region: Utah
That is some good info. Thanks.
Do you know of any issues if I were to try to put a t-5 in from a car that is older than a 94?
Those seem to be the most plentiful.
I just need to move the car around, no serious driving.
Old 04-26-2007, 12:25 PM   #4
Scut95's Avatar
The only thing i can think of thats a big difference is that the new trannies are world class which just means they're stronger. Otherwise i think they're virtually the same
'04 GT Swap-out automatic trans for 6-speed manual ctogni1 1996-2004 Mustang GT 1 01-14-2010 01:29 AM
manual trans oil 00stang3.8 Pre-2005 V6 Mustang 4 12-28-2006 03:28 PM
Just bought a 2006 V6 Manual trans Pony pkg Rick0636 Pre-2005 V6 Mustang 17 02-22-2006 08:18 AM
2006 V6 Manual Trans - Bucks in 1st Gear in AM lovcom Pre-2005 V6 Mustang 9 11-20-2005 09:08 AM
05 v6 manual trans.. MonteCitan Pre-2005 V6 Mustang 29 01-07-2005 04:40 PM
05:32 PM
