aftermarket rear control arms...who's got'em? - Mustang Evolution
Old 04-30-2007, 06:59 AM   #1
Titus Wadicus
svtlx's Avatar
who's got after market rear control arms?....just want to get some opinions on wut they do and everyone's experiences. do they really help with traction?...launches?...cornering?...i'm just try'n to figure out wut to expect.
Old 04-30-2007, 07:56 AM   #2
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
Re: aftermarket rear control arms...who's got'em?
I had a set of lakewood lca's on the back of my old Camaro. I was having serious issues with wheel-hop, and they fixed it. They weren't real expensive, either.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 04-30-2007, 08:13 AM   #3
Titus Wadicus
svtlx's Avatar
honestly, i don't think my car makes enough horse to utilize them...i get excessive wheel spin on launch. i have to run with a half tank of gas or more to get traction...i picked a set of upper and lowers from the ford swap meet here in columbus, ohio a few weeks ago. $135.00 for the upper and lower.."new". i haven't putte'm on yet, but i am hope'n they help with my traction issues. also, ima relocate my battery to the trunk and hope that the few extra pounds help.
Old 04-30-2007, 08:20 AM   #4
MarkuzLS1's Avatar
Get you some good tires. That'll help more than anything.
I like turtles.
Old 04-30-2007, 08:55 AM   #5
I installed a set of south side machine lift bars on my 01 and it really helped traction... but ONLY in a straight line. Going with upgraded OEM style (not altering the geometry) LCAs also help but wont make as much of an impact as a good set of tires will.
I would go maximum motorsport LCA due to their spherical design allows the rotation of the rear end to be less binding. When one side of the rear axle raises and the other lowers this creates bind. Urathane bushings are stiffer but cause more bind. The reason the rubber OEM bushings are used is to prevent bind... at the same time they cause other side effects I am sure you are familiar with. They do not keep the rear end planted very well and allow side to side movement. Maximum Motorsports piece prevent the rear from moving side to side nearly as much and also help to eliminate the rear end binding by allowing the LCA to twist side to side without causing a bind in the tq boxes.
With bind you gain uneven and dangerous handling characteristics. The overall design of the OEM 4 link leaves much to be desired.
Old 04-30-2007, 09:39 AM   #6
stanger99's Avatar
Send a message via MSN to stanger99
someone from ohio........... columbus here
stanger99 is offline   Reply With Quote
Old 04-30-2007, 04:06 PM   #7
bbunt302's Avatar
I've had both the SSM lift bars and the Maximum Motorsports lowers. I liked the MM stuff better. I didn't really have wheel hop with either, despite other serious traction issues. The MMs were so much nicer though. The SSMs always made a horrible popping noise at low speeds.
Maximum Motorsports all the way.
Scary stuff.
Old 04-30-2007, 04:08 PM   #8
bullitt482's Avatar
Got southside now and hate 'em. They were on the car when we got it. Looking at some UPR's or some MM. Your car can ALWAYS use aftermarket UCA's and LCA's.
01 Bullitt
Old 05-02-2007, 08:04 AM   #9
Titus Wadicus
svtlx's Avatar
taylor & broad....columbus racing clique
Old 05-02-2007, 08:07 AM   #10
Titus Wadicus
svtlx's Avatar
got sum after market uca & lca w/greasable rubber bushings...everyone told me to stay away from the urethane cause they r too rough on th car.
Old 05-02-2007, 08:08 AM   #11
Titus Wadicus
svtlx's Avatar
dude hit me up...dat way we can represent "mustang evolution" of columbus. get sum window stickers or something!
Old 05-02-2007, 05:16 PM   #12
bullitt482's Avatar
Have urethanes here, aren't too TOO bad, but they are rougher than stock. JUST BE SURE TO GREASE THE EVER LOVING PISS OUT OF THEM. OR they'll squeak and creak like hell.
01 Bullitt
Old 05-06-2007, 09:15 AM   #13
Titus Wadicus
svtlx's Avatar
one more stupid question yall...there r 2 bolt holes on the lca...does which one does the sway bar bolt too...front holes..or rear?....i have a sway bar, but haven't installed it yet...mt stang was a 4 cyl and never came with a rear sway bar...so ima lil confused as to which holes to bolt it in. there's only one set of holes on the stock lca....im stupid stuck on this...however i may find that it is self explanatory when i get under the car but that's y i have u guys
affordable control arms flying5 2005-2010 Mustang GT 10 06-26-2007 11:26 PM
Control Arms Y2E0L0L5OGWT 2005-2010 Mustang GT 5 06-20-2007 09:57 PM
98 cobra upper control arms? SpectorV Pre-2005 V6 Mustang 6 08-21-2005 07:46 PM
which lower control arms to get? mild2002gt 1996-2004 Mustang GT 11 01-16-2005 11:54 PM
Lower control arms Rick0636 Pre-2005 V6 Mustang 10 07-15-2003 03:43 PM
06:22 PM
