Oh How My Car Keeps 0wning Me - Mustang Evolution
Old 05-03-2007, 01:38 PM   #1
bluemustang's Avatar
Went and check the codes that the car was throwing....
Got a cylinder issue (8th cylinder)
Code 22 - manifold absolute pressure or BARO sensor out of range
Code 29 - insufficient input from the vehicle speed sensor (VSS)
Code 34 - insufficient EGR flow or EVP voltage (SONIC) or PFE sensor voltage high or out of specification
Code 66 - VAF/mass air flow sensor fault, below minimum voltage
So if anybody can let me know how to go about fixing these problems that would be great :approve:
Old 05-03-2007, 01:39 PM   #2
Re: Oh How My Car Keeps 0wning Me
I think the best fix would be to put your car on a truck and ship it to me...and then look into another car.
Old 05-03-2007, 01:43 PM   #3
Stumpy's Avatar
x2. it's time to get another.
~Roman~
2003 Mustang V6 Vert with a Flowmaster Super 40 series dual exhaust
I'm not a target in the sights of your mercy. I've never asked for anything. I'm not asking now.
Stumpy is offline   Reply With Quote
Old 05-03-2007, 01:45 PM   #4
nah Ive had this car paid off and Ive slowly been fixing all the issues out of it but for once Id like to be issue free but it doesnt seem to be that way at all......
i am trying to find a close to stock short block (for now) been looking for awhile but the prices some people are charging is so beyond me.
Old 05-03-2007, 01:52 PM   #5
MonteCitan's Avatar
I have a complete 92 shortblock
needs rings, but it had no noises/etc and had great oil pressure... all cylinder walls are ok
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 05-03-2007, 01:54 PM   #6
how many miles? how much you looking to get for it?
Old 05-03-2007, 02:00 PM   #7
MonteCitan's Avatar
112k miles previous owner had had a ford crank kit put into it, with new bearings/et al a few years back but he hadn't driven it much since
Old 05-03-2007, 03:56 PM   #8
Tape's Avatar
code 22 manifold absolute pressure or BARO sensor out of range
MAP/MAF sensor bad... , the MAP reads barometric(BARO) pressure
TRY CLEANING FIRST
code 29 insufficient input from the vehicle speed sensor (VSS)
sensor bad, located on transmission
code 34 insufficient EGR flow or EVP voltage (SONIC) or PFE sensor voltage high or out of specification
Remove the EGR valve and clean it with carbon remover. Prior to re-installing see if you can blow air through the flange side of the EGR by mouth. If it leaks, there is carbon stuck on the pintle valve seat, replace the EGR valve.
code 66 VAF/mass air flow sensor fault, below minimum voltage.
MAF bad TRY CLEANING FIRST
This is what I would do if it were me, Good luck!!
Tape is offline   Reply With Quote
Old 05-06-2007, 11:02 AM   #9
Titus Wadicus
svtlx's Avatar
did all these codes pop up at once or did they creep up one at a time?...the last time my car poped all those...the battery and alt. were bad. replaced them and all the codes went away and the car ran like a champ. my pontiac formula did the same thing...whole lotta codes at once..replaced the **** and the codes were still there...new battery...codes disappeared, car ran fine.........this was weird ****, cause in both cases car started normaly and gave me no indication that voltage was low.....all the low voltage codes makes me think u got a power issue.....start the car and hook up a battery charger to it while it is running...if the idle smoothes out and picks up, then u know u got a low voltage problem. it's just an idea...perhaps all that crap is really bad on your car..i dunno
1990 LX show car being auctioned off on ebay CHECK THIS CAR OUT! fordguy23 Mustangs for Sale and Wanted 0 10-11-2006 10:03 AM
Pics of the car with fresh coat of water less car wash SpectorV Mustang Audio & Video 22 02-23-2004 08:12 PM
08:38 AM
