3G Upgrade - Mustang Evolution
Old 05-10-2007, 10:55 AM   #1
bluemustang's Avatar
3G Upgrade
Just wondering if anybody on this board have done this swap? Any input on doing the swap or is it honestly really easy? Suggestions and so forth?
Im gonna be using this as my guideline. The 3G Alternator Project / Mustang Central.net 130 amp alternator upgrade
Gonna just go to the JY and find a 94+ Alt., Also just ordered my PA Perf. Wire upgrade kit Welcome To PA-Performance 1.877.471.8010
Old 05-10-2007, 11:35 AM   #2
Send a message via AIM to A5295
Re: 3G Upgrade
Its not bad at all... I actually did a 6G (2000 V6) Upgrade... The 3G isnt much different - the reason i went with the 6G was because there isnt supposed to be any kind of bracket modifying to be done. I still did some on mine, but it works just fine. Good luck, and post if you have any trouble, or let us know how it goes!
A5295 is offline   Reply With Quote
Old 05-10-2007, 04:04 PM   #3
bbunt302's Avatar
Re: 3G Upgrade
I've done it. Grinding the bracket was a pain, but other than that it wasn't bad. I got mine from PA Performance with their wiring kit as well.
Scary stuff.
Old 05-11-2007, 07:32 AM   #4
Titus Wadicus
svtlx's Avatar
Re: 3G Upgrade
both of my 5.0's have 3g's. i used an electric grinder with a 1/2" thick wheel, took less than 2 min. to grind clearance in the bracket...not sure y it was a pain in the *** for bbunt. i had the bracket ground down, alt. wired and installed in less than 30 min. it's very easy. u will have to use your original pulley if u use a junk yard unit. the 3g pulley uses a wider belt. i paid $15 dollars for mine at "pick-n-pull"...it's freak'n awsome. i would cut the plugs from the donor car if i were u. i forgot to and had to make my own harness when i got home. i got enough juice for my subs and msd...best $15 bucks i spent.
Old 05-11-2007, 09:30 AM   #5
SilentNoise's Avatar
Send a message via MSN to SilentNoise
Re: 3G Upgrade
I know a couple of guys who did it to their old 5.0s and absolutely loved it once it was done. One of them said it was the best upgrade he did next to subframes.
Wolf Pack Car Club - Domestic V8 Performance Club (Edmonton, AB, Canada)
"If the automobile had followed the same development cycle as the computer, a Rolls-Royce would today cost $100, get a million miles per gallon, and explode once a year, killing everyone inside." -Robert X. Cringely
SilentNoise is offline   Reply With Quote
Old 05-14-2007, 06:25 AM   #6
silverstangboy's Avatar
Re: 3G Upgrade
im about to do mine, i went with a remanu, 150amp unit. just because its pretty and looks new, you can pull them from junk yards as SVT said
this site helped me alot so far
http://www.geocities.com/smithmonte/...or_Upgrade.htm
not that this guy has said anything that everyone else didn't, but he has very detailed electrical scematics, and goes into much detail about 3G itself.
93 mustang notch
~450hp 331 stroker - Sold
Old 05-14-2007, 06:32 AM   #7
Titus Wadicus
svtlx's Avatar
Re: 3G Upgrade
i'll say again...the best 15 bucks i ever spent. no more run'n rich at idle...saved me money on plugs too...lol
Old 05-16-2007, 11:33 PM   #8
Re: 3G Upgrade
It's a good way to go. I got rid of a lot of little gremlins with the 3G upgrade in my 90 coupe. Just some comments:
- If you get a 3G for a 94/95 Mustang the pulley it comes with will be correct. The original pulley is not correct on the 3G and will not line up quite right.
- You can buy a remanufactered alternator at an auto parts store with a warranty, then when you run 8000 RPM a few times and burn it up, you can get a new one for free.
- You should use a fuse or breaker in the main power harness in case something goes wrong.
- Whatever you do, don't use the factory 10 gauge power wires, or you run a serious risk of a wiring fire. Run a new 4 gauge wire over to the starter solenoid.
- The bracket modification takes about 2 minutes with a carbide bit on a die grinder - No problem.
- If you are desperate to save weight, like a road racer friend of mine, the 6G is a little lighter. You can get one out of a super coupe.
Good luck.
-Matthew
90 LX Coupe
02 GT Convertible
03 F-250 PSD
06 SRT8 Magnum
http://www.tecmotion.ca
Matthew is offline   Reply With Quote
Old 05-17-2007, 11:41 AM   #9
Titus Wadicus
svtlx's Avatar
Re: 3G Upgrade
damn, matt knows his ****. my motor won't see more than 6250rpm...but kudos to the guy dats tach'n out @ 8 grand. now, all we have to do is start a thread for doing a formula 1 motor swap into a fox..dat's like 25,000rpm...kinda of a mind blow'n #.
Old 05-17-2007, 01:42 PM   #10
Re: 3G Upgrade
Good luck.
-Matthew
sweet deal thanks for all the info there
Old 06-03-2007, 09:04 AM   #11
Re: 3G Upgrade
Got mine out of the junkyard for dirt cheap, and works great. Another vote for the Smithmonte site, lots of good info there.
1992 GT
Edelbrock Performer Heads/RPM II intake
Vortech S-trim/Aftercooler
Kenny Brown suspension
Too many mods to list
480rwhp/480rwt
1hawaii50 is offline   Reply With Quote
Old 06-06-2007, 09:54 PM   #12
Re: 3G Upgrade
You can see it run 8000 RPM in every gear here:
Tecmotion - Race Program
-Matthew
90 LX Coupe
02 GT Convertible
03 F-250 PSD
06 SRT8 Magnum
help with new upgrade upton7 1996-2004 Mustang GT 0 03-28-2009 07:19 PM
Next Upgrade?? 2kslvrgt 1996-2004 Mustang GT 6 02-07-2009 02:56 PM
Upgrade Stang02021 Pre-2005 V6 Mustang 34 02-05-2009 09:54 AM
brake upgrade meteorachick Mustang Wheels & Tires 19 09-01-2007 03:33 AM
Nitrous Upgrade?? TafoyaMNAA Pre-2005 V6 Mustang 32 06-05-2007 10:31 PM
04:28 AM
