NOTCH UP - Mustang Evolution
Old 05-12-2007, 03:36 AM   #1
powerhungry966's Avatar
Send a message via AIM to powerhungry966
NOTCH UP
alright as some of you know, i've gotten some work done and converted my auto to stick. I have only one complaint. Reverse. It seems to grind no matter what i do.. How could i correct this? If i got a short throw shifter would it cure it? I dont know if its the tranny, we had a 92 gt a while back and it did the same thing. Well my setup came off of a car with "38k" miles on it, it was an 90 gt vert. I must say though, I'm one happy camper with the five speed swap, this thing hauls some ***! i will have pic up shortly.
1989 coupe 5.0 yeessur.
"Shake n bake"
powerhungry966 is offline   Reply With Quote
Old 05-12-2007, 10:50 AM   #2
bbunt302's Avatar
Re: NOTCH UP
Reverse in a T5 is gonna grind. I think they are designed to do that so you don't accidentally put it in reverse without getting the pleasure of a horrible sounding grind. Because that would be terrible.
I used to always do the 1-5-1-R shuffle when putting mine in reverse. It seems to help.
Scary stuff.
Old 05-12-2007, 01:36 PM   #3
Re: NOTCH UP
car on or off?
"Shake n bake"
Old 05-12-2007, 04:21 PM   #4
bbunt302's Avatar
Re: NOTCH UP
On.
Scary stuff.
Old 05-13-2007, 03:07 AM   #5
Re: NOTCH UP
turns out i need to kick the **** out of my clutch, haha. My mat made it a real pain in the *** to shift it in R. B, i must say patna, you was riighht.. I'm happy as hell i went with a 5spd.
"Shake n bake"
Old 05-13-2007, 10:50 AM   #6
Titus Wadicus
svtlx's Avatar
Re: NOTCH UP
ahhh, snap!!!...i lost another automatic comrad to those cursed t-5's...lmfao....lol, i thought the reverse grind was normal...i see more cars with reverse grind than without...especialy cars with newer clutches...i'm not a t-5 or manual trans guru by any means...and most likely have to ask all u guys on here how to change a clutch if i had one.
Old 05-13-2007, 01:19 PM   #7
Re: NOTCH UP
my trans does the same ish i thought my syncros were going but it seems its a mustang thing im gana try that 1-5-1-R
87lx50 is offline   Reply With Quote
Old 05-13-2007, 02:46 PM   #8
bullitt482's Avatar
Re: NOTCH UP
I would love to see a t-5 go straight in reverse. If I could find one, I'd buy and I'd put it on display at borg warner
I just stick it third, roll forward, then it pops right in. My wife can put it and third and it goes in reverse right after that almost every time. Then again, her first manual was a T-5 so she has me on experience.
01 Bullitt
Old 05-13-2007, 03:57 PM   #9
Titus Wadicus
svtlx's Avatar
Re: NOTCH UP
tell her i said, "you go girl!!!"
Old 05-13-2007, 06:44 PM   #10
Re: NOTCH UP
if you have to push your clutch in really hard to get it to go into reverse without grinding then your clutch is not adjusted right and you need to take some of the slack out of it.
Old 05-14-2007, 01:50 AM   #11
Re: NOTCH UP
what i found to work really good was to put it in 5th first then go into reverse.. sorry the 1-5-1-r dint do it for me
"Shake n bake"
Old 05-14-2007, 06:40 AM   #12
silverstangboy's Avatar
Re: NOTCH UP
reverse doesn't have any syncro, but shares some of the gears that 1rst uses, if you sync the gears in first and then go to reverse your odds of not grinding are greatly improved.
93 mustang notch
~450hp 331 stroker - Sold
Old 05-14-2007, 01:29 PM   #13
bluemustang's Avatar
Re: NOTCH UP
damn that was quick, didnt waste time doing the swap huh
Old 05-14-2007, 03:27 PM   #14
bullitt482's Avatar
Re: NOTCH UP
No joke, that would have taken me a couple of weekends and a lift. :yup:
01 Bullitt
Old 05-14-2007, 04:58 PM   #15
rocknbronco's Avatar
Re: NOTCH UP
Yeah I would have to say the same time is rather short for me right now I would do the 5-R shift in my friends Foxand keep his comp clutch pressed down hard .
rocknbronco is offline   Reply With Quote
Old 05-15-2007, 09:05 AM   #16
Titus Wadicus
svtlx's Avatar
Re: NOTCH UP
No, Shyt, Dat Was Quick
top notch!!!!! turbofox Pictures and Videos 8 06-17-2010 09:15 PM
My new 90 notch oatburner99 Pictures and Videos 17 03-03-2010 10:19 PM
notch down powerhungry966 1979-1995 Mustang GT 40 05-11-2007 07:48 PM
will this fit in the notch...? Taywi Mustang Audio & Video 5 03-26-2007 11:56 AM
Picked up a notch. MonteCitan The Bar 16 08-26-2005 03:17 PM
02:18 PM
