short throw steeda - Mustang Evolution
Old 09-27-2010, 06:46 PM   #1
onequickR's Avatar
short throw steeda
hey guys how hard is it to put a short throw steeda in? any tricks i need to do or things i need to look for?
onequickR is offline   Reply With Quote
Old 09-27-2010, 07:31 PM   #2
02Nate281's Avatar
Send a message via AIM to 02Nate281 Send a message via MSN to 02Nate281 Send a message via Yahoo to 02Nate281 Send a message via Skype™ to 02Nate281
Re: short throw steeda
Even though you have a 5.0 and I have a 4.6, I'll give you my experience
It is very straight forward and simple. Just follow the directions given in the item description. It's one of the easiest mods I've done to mine so far. Install took me about 45 mins by myself. Just don't do any power-shifting for a day or so if you are using RTV sealant because your shift plate will slide if it hasn't fully dried and sealed yet. It is definitely worth doing. Much more comfortable than the stock shifter and shifting takes a fraction of the time with my short throw as opposed to stock.
"There is no love without sacrifice"
02Nate281 is offline   Reply With Quote
Old 09-28-2010, 07:20 AM   #3
its quite easy and wont take much time make sure the little plastic ball goes back in with the new one (its what the lever goes into in the trans)
also this is a GREAT time to change the trans fluid drain i under the bottom take shifter off poor into shifter hole slowly to given capacity.
Steeda is nice but I perfer MGW or pro 5.0 on the 5.0 mustangs, T-5s are noisy and the steeda makes it much worse where mgw helps
Old 09-28-2010, 01:19 PM   #4
onequickR's Avatar
thanks guys i don't do much car mods so i don't wanna screw it up just checking before i take it apart. if i woulda known i might had went mgw or pro 5.0 just got a better deal on the steeda and it was a better known co to me live and learn i guess but thanks again
Old 09-28-2010, 02:02 PM   #5
its a fine shifter, try it and if you like it all is well if not you can sell it and get another one, it will work great im sure.
Old 09-30-2010, 06:28 PM   #6
onequickR's Avatar
hey guys thanks for your input i got it in and so far i luv it the conv is kinda loud not nearly as quiet as the 03 and up models so that being said i don't really notice the shifter noise but i'll live with it nice to make a shift without moveing ur hand 12"
Old 10-25-2010, 07:12 PM   #7
silverstangboy's Avatar
never thought of that spec, but I suppose you are right, mine is somewhat unnaturally noisy.
The steeda has alot more spring to it, which is fun when you're in the heat of battle but on a daily driven car im not sure its as fun to drive as the others.
93 mustang notch
~450hp 331 stroker - Sold
which short throw to go with? kcfan_2004 General Mustang Discussion 6 09-12-2008 11:34 AM
Steeda Tri-Ax Short Throw Shifter for T-3550 USMCSS Mustang Parts for Sale and Wanted 4 04-23-2007 08:09 AM
Short-Throw Shifter for under $10!!! drummerstang98 The Bar 7 09-28-2004 05:09 PM
03:29 AM
